Still image sizes in Premiere Pro CS5.5
Kurt Lang Jun 27, 2011 10:02 AMI've been looking for quite a while on Adobe's help pages, these forums, and also the PDF manual, but can't find the info I'm looking for.
I'm moving from Final Cut Studio to the Adobe suite of video production for various reasons. I've purchased (though not yet received) the Production Premium upgrade. I have a new project I'm starting, and want to correctly size my images for Premiere Pro. For instance, Final Cut Studio has this handy chart:
The video sequence frame size
If you are using this format is Use graphics with this frame size
CCIR 601 NTSC 4:3 720 x 486 720 x 547
CCIR 601 NTSC 16:9 anamorphic 720 x 486 853 x 486
DV NTSC 4:3 720 x 480 720 x 540
DV NTSC 16:9 anamorphic 720 x 480 853 x 480
CCIR 601/DV PAL 4:3 720 x 576 768 x 576
CCIR 601/DV PAL 16:9 anamorphic 720 x 576 1024 x 576
720p HD 1280 x 720 1280 x 720
1080i or 1080p HD 1920 x 1080 1920 x 1080
So for a standard 4:3 DV NTSC video, I make my still images 720 x 540 pixels. 16:9 anamorphic, 853 x 480.
For whatever reason, this type of information is completely missing in the manuals for CS5.5. I did however find this information related to Premiere Pro 4:
4:3 DV (NTSC) or ATSC SD—create and save the square-pixel file at 720x534.
4:3 D1 (NTSC)—create and save the square-pixel file at 720x534.
4:3 DV or D1 (PAL)—create and save the file at 788x576.
16:9 DV (NTSC)—create and save the file at 864x480.
16:9 D1 (NTSC)—create and save the file at 872x486.
16:9 DV or D1 (PAL)—create and save the file at 1050x576.
16:9 1080i HD—create and save the file at 1920x1080.
16:9 720p HD—create and save the file at 1280x720.
So did this apply to CS5.5 as well? Meaning if I'm creating a standard 4:3 DV NTSC video, my still images should be 720 x 534, and 16:9 anamorphic 864 x 480? Not quite sure what the distinction is between DV and D1, other than the anamorphic sizes are different.
I also know these are different from Final Cut Studio. In Apple's manuals, they come right out and say the pixel sizes FCS uses for stills are different from most video editing software. So I'm not surprised to see 720 x 534 for for 4:3 NTSC in Premiere Pro rather than Apple's size of 720 x 540.
Thanks.
