0 Replies Latest reply on Jun 27, 2011 2:32 PM by VeenaChezhian
    Library Projects compiled using Flash Builder and ANT have different outputs
    VeenaChezhian
      Hi Guys.,
      I am really having hard time to get something work right with RSL projects in Flex 3.2 SDK. Here is my weird problem.
      I have a library projects which has the following settings in Flash Builder
      Link Type : External
      airglobal.swc
      framework.swc
      datavisualization.swc
      rpc.swc
      utilites.swc
      applicationupdater.swc
      applicationupdater_ui.swc
      Link Type: Merged into code
      airframework.swc
      servicemonitor.swc
      Compiler settings
      -directory=true -output=../../lib/core -debug=true -optimize=false -define+=CONFIG::bindingdebug,false -define+=CONFIG::frameworkdebug,false -define+=CONFIG::flexspy,true -define+=CONFIG::debug,true -define+=CONFIG::release,false -define+=CONFIG::logtoconsole,false -allow-source-path-overlap=true  -keep-as3-metadata+=Metadata,DefaultProperty,Required,Event,AssignableTo,Inject,InjectCon structor,Publish,Subscribe,PublishSubscribe,Factory,Init,Destroy,Observe,AsyncInit,Managed Events,MessageDispatcher,MessageHandler,MessageBinding,MessageInterceptor,MessageError,Com mand,CommandComplete,CommandResult,CommandError,CommandStatus,ResourceBinding,Selector,Tar get,Autoremove,Internal,ObjectDefinition,DynamicObject
      When I compile my library projects I get a MyLibraryproject.swc. The SWC has the following files in it
      mx/controls/HTML.png
      mx/core/Windows.png
      library.swf
      Note: airframework.swc and servicemonitor.swc has a many png files and properties files in it. But these properties and png files are not included when compiled in Flash builder.
      But when the same project is compiled using ANT compc task, i get all the png and properties files from airframework.swc and servicemonitor.swc files into my library project SWC file.
      Here is the ANT version which is used to compile the library project
      <compc output="${project.output.dir}/${project.name}.swc"
         include-classes="${as} ${mxml}"
         use-network="false"
         directory="false"
         allow-source-path-overlap="true"
         incremental="${build.incremental}"
         debug="${build.debug}"
         locale="${build.locale}"
         optimize="false"
      <define name="CONFIG::bindingdebug" value="${build.bindingdebug}" />
      <define name="CONFIG::logtoconsole" value="${build.logtoconsole}" />
      <define name="CONFIG::frameworkdebug" value="${build.frameworkdebug}" />
      <define name="CONFIG::flexspy" value="${build.flexspy}" />
      <define name="CONFIG::debug" value="${build.debug}" />
      <define name="CONFIG::release" value="${build.release}" />
      <keep-as3-metadata name="Metadata" />
      <keep-as3-metadata name="DefaultProperty" />
      <keep-as3-metadata name="Required" />
      <keep-as3-metadata name="Event" />
      <keep-as3-metadata name="AssignableTo" />
      <keep-as3-metadata name="Inject" />
      <keep-as3-metadata name="InjectConstructor" />
      <keep-as3-metadata name="Publish" />
      <keep-as3-metadata name="Subscribe" />
      <keep-as3-metadata name="PublishSubscribe" />
      <keep-as3-metadata name="Factory" />
      <keep-as3-metadata name="Init" />
      <keep-as3-metadata name="Destroy" />
          <keep-as3-metadata name="Observe" />
          <keep-as3-metadata name="AsyncInit" />
          <keep-as3-metadata name="ManagedEvents" />
          <keep-as3-metadata name="MessageDispatcher" />
          <keep-as3-metadata name="MessageHandler" />
          <keep-as3-metadata name="MessageBinding" />
          <keep-as3-metadata name="MessageInterceptor" />
          <keep-as3-metadata name="MessageError" />
          <keep-as3-metadata name="Command" />
          <keep-as3-metadata name="CommandComplete" />
          <keep-as3-metadata name="CommandResult" />
          <keep-as3-metadata name="CommandError" />
          <keep-as3-metadata name="CommandStatus" />
          <keep-as3-metadata name="ResourceBinding" />
      <keep-as3-metadata name="Selector" />
      <keep-as3-metadata name="Target" />
      <keep-as3-metadata name="Autoremove" />
      <keep-as3-metadata name="Internal" />
      <keep-as3-metadata name="ObjectDefinition" />
      <keep-as3-metadata name="DynamicObject" />
      <load-config filename="${air.config}"/>
      <compiler.include-libraries dir="${flex.frameworks.dir}/libs/air" append="true">
           <include name="servicemonitor.swc" />
           <include name="airframework.swc" />
      </compiler.include-libraries>
      <external-library-path dir="${build.compc.dir}" append="true">
           <include name="TriGeoFlexFramework/TriGeoFlexFramework.swc" />
           <include name="TriGeoLibrary/TriGeoLibrary.swc" />
           <include name="TriGeoRPCFramework/TriGeoRPCFramework.swc" />
           <include name="Degrafa_Beta3.1_Flex3" />
           <include name="parsley-flex3-2.4.0.swc" />
           <include name="spicelib-flex-2.4.0.swc" />
      </external-library-path>
      <external-library-path dir="${flex.frameworks.dir}/libs" append="true">
           <include name="framework.swc" />
           <include name="datavisualization.swc" />
           <include name="utilities.swc" />
           <include name="rpc.swc" />
           <include name="air/airglobal.swc" />
           <include name="air/applicationupdater.swc" />
           <include name="air/applicationupdater_ui.swc" />
      <source-path path-element="${basedir}/src" />
      </compc>
      </target>
      </project>
      Any insights is greatly appreciated.!
