5 Replies Latest reply on Jun 28, 2011 8:39 AM by Flex harUI
    Keyboard shortcut difficulties
    tehxike1 Level 1
      I'm not sure what to do about this...  If my component implements IFocusManagerContainer, I can tab from field to field.  If it implements IFocusManagerComponent, keyUpHandler is called, so I can handle keyboard shortcuts.  But they're mutually exclusive- I can't have both.  Either tabbing works, or keyUpHandler works.  Implementing both interfaces still prevents tabbing from working.  How can I get both of these rather basic features to work at the same time?
        • 1. Re: Keyboard shortcut difficulties
          Flex harUI Adobe Employee
          Most folks use keyDown.  Why are you using keyUp?  KeyUp should still work
          for IFocusManagerComponent.  When does it not work?
          • 2. Re: Keyboard shortcut difficulties
            tehxike1 Level 1
            Not sure why I picked keyUp...  keyDown does work as well...  But this is a really easy problem for me to reproduce.  Running the following application...  If I implement the IFocusMangerComponent interface, keyDown is called, but tabbing doesn't work.  If I don't, keyDown isn't called, but tabbing works.
            <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               implements="mx.managers.IFocusManagerComponent">
            <fx:Script>
            <![CDATA[
            override protected function keyDownHandler(event:KeyboardEvent):void
            super.keyDownHandler(event);
            if (event.ctrlKey && event.keyCode == Keyboard.S)
            label.text = "Save Detected";
            </fx:Script>
            <s:layout>
            <s:VerticalLayout />
            </s:layout>
            <s:TextInput />
            <s:TextInput />
            <s:Label id="label" />
            </s:WindowedApplication>
            • 3. Re: Keyboard shortcut difficulties
              A container (like the app) should not normally be an IFocusManagerComponent
              because it should never really have focus, its children like the TextInputs
              should.
              Keyboard events bubble, so once a TextInput has focus, they keyDownHandler
              should be called in the application.
              If nothing has focus, keyboard events are dispatched from the stage, so you
              may also need to listen there.
              • 4. Re: Keyboard shortcut difficulties
                tehxike1 Level 1
                Ah, makes sense.  Is adding/removing the stage event listener in added_to_stage/removed_from_stage the best way to implement this and avoid a memory leak?
                • 5. Re: Keyboard shortcut difficulties
                  I use a weak reference listener to systemManager.stage during app
                  initialization.
