18 Replies Latest reply on Jul 7, 2011 11:52 AM by Jon Chappell
    PrPro 5.5 crashing EVERY time.
    tylerscott899 Level 1
      just updated from production premium CS5 to CS5.5 (did a complete clean install after lots of unistalling).
      brand new project. added clips, did some basic edits. clicked a clip in the timeline > After Effects linked composition. Once AE loaded up, both programs crashed. Upon every successive attempt to reopen PrPro, it would load up, give a blip of all the windows, then crash again. Only way to fix this was to shift+alt click on PrPro to clear the prefs, and then it would re-open and run alright. Figured out part of the issue was having Colorista II and Looks both applied to the clip I was trying to export for stabilization... However, those plugins all run in AE, so it should not be an issue, IMO. AE even loaded the same plugins right before crashing, so I know they're there. Finally got it to link without crashing by just removing those plugins, exporting for stabilization, then adding the coloring back onto the linked comp later on.
      second issue:
      import a CS5 project. immediately crash upon opening. crash instantly upon every successive attempt to re-open. shift+alt click to clear prefs, finally opened and ran correctly.
      I don't understand the issue... why is it crashing so much? clearing my prefs seems to fix it on a per-project basis, but not a universal fix, and it's a huge pain in the butt to do this every. single. time.
      macosx 10.6.8
      3.06 core 2 duo
      8gb ram
      ATI radeon HD 4670 256mb ram
      OSX and production premium are both installed on the internal 1TB HDD, w/roughly 300-400gb free space, depending on the day.
      project files all run from an external Lacie 1TB HDD via FW800 w/roughly 200gb free
      i'm 21, and a genuine PAYING customer of all the software I use, because I value integrity and honesty above an easy hack, especially as I'm trying to make my living off of this work.
        • 1. Re: PrPro 5.5 crashing EVERY time.
          Todd_Kopriva Level 8
          Has this only been happening since the Mac OSX v10.6.8 update? We've been seeing a lot of reports of crashes and other problems with that update.
          • 2. Re: PrPro 5.5 crashing EVERY time.
            I had 10.6.8 before I upgraded to 5.5, so I don't have a point of reference there.
            • 3. Re: PrPro 5.5 crashing EVERY time.
              just spoke with a friend who is running cs5.5 on both a 27" imac and a 13"mbp, both current gen, both running 10.6.8, and he said everything adobe is running flawlessly...
              • 4. Re: PrPro 5.5 crashing EVERY time.
                js_newyork Level 1
                I am having the same problem. OSX 10.6.8 with Premiere 5.5 crashes every time I try and go back and open a project I created before. I can make brand-new projects, but when I close them and want to open it again it crashes.
                • 5. Re: PrPro 5.5 crashing EVERY time.
                  Pharther Phurther Level 1
                    My first crashing issues were solved by replacing the ATI card with a Nvidia 285 GTX.
                  This was with Master Suite 5.0 Demo and Mac OS X 10.6.5.
                  • 7. Re: PrPro 5.5 crashing EVERY time.
                    js_newyork Level 1
                    Thanks, but didn't work for me. I'm on the NVIDA GeForce 7300 GT.
                    • 8. Re: PrPro 5.5 crashing EVERY time.
                      As already stated, I have an ATI card, not NVIDIA...
                      • 9. Re: PrPro 5.5 crashing EVERY time.
                        Kevin-Monahan Adobe Employee
                        Right.
                        Your first issue seems to be related to Colorista and Warp Stabilizer. Can you please file a bug report with the exact steps you mentioned here? http://www.adobe.com/go/wish
                        For your second issue, I would suspect that the OS X update is what is giving you fits. It's recent update, so there may be issues that are just emerging. Is it possible to roll back to 10.6.7 for a test? http://support.apple.com/kb/dl1363
                        Further, I would recommend using a faster processor. A Core2 Duo is supported, but most users are using quad core or better with HD footage.
                        • 10. Re: PrPro 5.5 crashing EVERY time.
                          js_newyork Level 1
                          I figured it out. I deleted the preferences in a different location than I was thinking I needed to. Here's where I trashed the 5.5 prefs: User/Library/Application Support/Adobe/Premiere Pro/5.5
                          • 11. Re: PrPro 5.5 crashing EVERY time.
                            Cool, I'm glad that worked for you!
                            • 12. Re: PrPro 5.5 crashing EVERY time.
                              Submitted a bug report a week ago. Crash happened before I ever got to apply warp stabilizer, so that was not the problem.
                              I have no way to roll back to 10.6.7, as I updated to 10.6.8 BEFORE I installed CS5.5 (otherwise time machine would be an option).
                              If my processor is supported, then the software should work. Period.
                              • 13. Re: PrPro 5.5 crashing EVERY time.
                                Wil Renczes Adobe Employee
                                I suggest posting the contents of a mac crash log, that'll give us a hint as to what's blowing up.
                                Cheers
                                • 14. Re: PrPro 5.5 crashing EVERY time.
                                  kickstand_digital
                                  If you don't mind me asking, where did you find that new card and how much was it?
                                  • 15. Re: PrPro 5.5 crashing EVERY time.
                                    eBay .. .. $200 + .... It's may not be the best .. but it's much cheaper than the 4000 ...
                                    • 16. Re: PrPro 5.5 crashing EVERY time.
                                      kickstand_digital Level 1
                                      I have experienced the same problem and after hours on the phone with Adobe support the problem seems to be the video card.
                                      Adobe told me to update the ATI drivers but the latest you can find is for Mac OS X 10.5 and these updates are sent out buy Apple in your system software updates.  So we are caught in a loop where Apple says it is up to date and ATI says that it is up to Apple to do the updates.  The only option seems to be either return Production Premium or get a new graphics card.
                                      • 17. Re: PrPro 5.5 crashing EVERY time.
                                        Process:         Adobe Premiere Pro CS5.5 [94210]
                                        Path:            /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/MacOS/Adobe Premiere Pro CS5.5
                                        Identifier:      com.adobe.AdobePremierePro
                                        Version:         5.5.0 (5.5.0)
                                        Code Type:       X86-64 (Native)
                                        Parent Process:  launchd [173]
                                        Date/Time:       2011-07-07 13:30:04.370 -0500
                                        OS Version:      Mac OS X 10.6.8 (10K540)
                                        Report Version:  6
                                        Interval Since Last Report:          157632 sec
                                        Crashes Since Last Report:           12191
                                        Per-App Interval Since Last Report:  156663 sec
                                        Per-App Crashes Since Last Report:   3
                                        Anonymous UUID:                      67D1ED21-85E9-41A6-B4B6-6C0B603A0942
                                        Exception Type:  EXC_CRASH (SIGABRT)
                                        Exception Codes: 0x0000000000000000, 0x0000000000000000
                                        Crashed Thread:  21  Dispatch queue: com.apple.root.default-priority
                                        Application Specific Information:
                                        abort() called
                                        Thread 0:  Dispatch queue: com.apple.main-thread
                                        0   com.apple.AppKit              0x00007fff80bd300c -[NSCell setObjectValue:] + 145
                                        1   com.apple.AppKit              0x00007fff80bd2726 -[NSCell setStringValue:] + 126
                                        2   com.apple.AppKit              0x00007fff80c8d8fd -[NSControl setStringValue:] + 115
                                        3   com.adobe.dvaui.framework     0x00000001032222ae dvaui::controls::OS_TextField_MAC::SetText(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 110
                                        4   com.adobe.dvaui.framework     0x000000010320ac2f dvaui::controls::UI_TextEdit::SetValue(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 159
                                        5   ...adobe.UIFramework.framework 0x000000010389c487 UIF::EditControl::SetText(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >) + 55
                                        6   ...HandlerAudioMixer.framework 0x00000001083dd9bf HandlerAudioMixer::MasterView::FinishCreateSelf(ASL::ParamRect<int> const&) + 4879
                                        7   ...adobe.UIFramework.framework 0x000000010396074d UIF::SubViewImpl::Create(UIF::ViewBase*, ASL::ParamRect<int> const&) + 157
                                        8   ...HandlerAudioMixer.framework 0x00000001083ea8c1 HandlerAudioMixer::ScrollableContainerView::SetMasterTrack() + 529
                                        9   ...HandlerAudioMixer.framework 0x00000001083b85c7 HandlerAudioMixer::MixerView::SetSequence(ASL::InterfaceRef<BE::ISequence, BE::ISequence>) + 2023
                                        10  ...HandlerAudioMixer.framework 0x00000001083b8fb7 HandlerAudioMixer::MixerView::BuildMixerView(ASL::InterfaceRef<BE::ISequence, BE::ISequence>, bool) + 279
                                        11  ...HandlerAudioMixer.framework 0x00000001083b939f HandlerAudioMixer::MixerView::ActivateSequence(ASL::InterfaceRef<BE::ISequence, BE::ISequence>) + 703
                                        12  ...HandlerAudioMixer.framework 0x00000001083b9581 HandlerAudioMixer::MixerViewHost::ActivateSequence(ASL::InterfaceRef<BE::ISequence, BE::ISequence>) + 49
                                        13  ...HandlerAudioMixer.framework 0x00000001083af32b HandlerAudioMixer::MixerHandler::OnSequenceActivated(ASL::InterfaceRef<BE::ISequence, BE::ISequence>) + 203
                                        14  ...HandlerAudioMixer.framework 0x00000001083b0632 HandlerAudioMixer::MixerHandler::ListenToMessage(ASL::Message const&) + 498
                                        15  ...dobe.ASLMessaging.framework 0x00000001005d708c ASL::Broadcaster::BroadcastMessage(ASL::Message const&) + 1484
                                        16  ...dobe.ASLMessaging.framework 0x00000001005e2211 ASL::StationUtils::BroadcastMessage(ASL::ImmutableString const&, ASL::Message const&) + 65
                                        17  com.adobe.Mezzanine.framework 0x0000000105e9fe7c MZ::ActivateSequence(ASL::InterfaceRef<BE::ISequence, BE::ISequence>, bool) + 956
                                        18  ...e.HandlerTimeline.framework 0x000000010980dbda HandlerTimeline::TimelineHandler::OnWorkspaceEndLoading() + 2074
                                        19  ...e.HandlerTimeline.framework 0x000000010980b265 HandlerTimeline::TimelineHandler::ListenToMessage(ASL::Message const&) + 645
                                        20  ...dobe.ASLMessaging.framework 0x00000001005d708c ASL::Broadcaster::BroadcastMessage(ASL::Message const&) + 1484
                                        21  ...dobe.ASLMessaging.framework 0x00000001005e2053 ASL::StationUtils::PostMessageToUIThread(ASL::ImmutableString const&, ASL::Message const&, bool) + 115
                                        22  ...adobe.UIFramework.framework 0x00000001039de8f3 UIF::WorkspaceImpl::NotifyRestoreWorkspaceEnd() + 67
                                        23  ...dobe.dvaworkspace.framework 0x0000000106c1f6f8 dvaworkspace::workspace::RestoreWorkspace(dvaworkspace::workspace::Workspace&, dvacore::proplist::PropList const&, bool, bool, bool) + 1064
                                        24  ...dobe.dvaworkspace.framework 0x0000000106c26a57 dvaworkspace::workspace::ManagerBase::AddWorkspace(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::proplist::PropList&, bool) + 183
                                        25  com.adobe.premiere.frontend   0x000000010c74cac9 FE::Application::InstallWorkspace(ASL::InterfaceRef<BE::IWorkspaceSettings, BE::IWorkspaceSettings>) + 217
                                        26  com.adobe.premiere.frontend   0x000000010c7959da FE::DocumentManager::OpenDocument(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool) + 6666
                                        27  com.adobe.premiere.frontend   0x000000010c791e2f FE::DocumentManager::ShowQuickStart() + 527
                                        28  com.adobe.premiere.frontend   0x000000010c7bcdc9 HandleIdle(NSTimer*) + 169
                                        29  com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
                                        30  com.adobe.dvacore.framework   0x000000010011cfd9 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 9
                                        31  com.adobe.premiere.frontend   0x000000010c775cae boost::function0<int>::operator()() const + 46
                                        32  com.adobe.premiere.frontend   0x000000010c775063 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 35
                                        33  com.adobe.dvacore.framework   0x000000010011bbf5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 197
                                        34  com.adobe.dvacore.framework   0x000000010011e773 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 99
                                        35  com.adobe.premiere.frontend   0x000000010c7bc1d8 -[PremiereCocoaMacApplication idle:] + 152
                                        36  com.apple.Foundation          0x00007fff84faacb5 __NSFireTimer + 114
                                        37  com.apple.CoreFoundation      0x00007fff844e0be8 __CFRunLoopRun + 6488
                                        38  com.apple.CoreFoundation      0x00007fff844dedbf CFRunLoopRunSpecific + 575
                                        39  com.apple.HIToolbox           0x00007fff869e87ee RunCurrentEventLoopInMode + 333
                                        40  com.apple.HIToolbox           0x00007fff869e85f3 ReceiveNextEventCommon + 310
                                        41  com.apple.HIToolbox           0x00007fff869e84ac BlockUntilNextEventMatchingListInMode + 59
                                        42  com.apple.AppKit              0x00007fff80be7eb2 _DPSNextEvent + 708
                                        43  com.apple.AppKit              0x00007fff80be7801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
                                        44  com.apple.AppKit              0x00007fff80bad68f -[NSApplication run] + 395
                                        45  com.adobe.premiere.frontend   0x000000010c7bbaa4 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 164
                                        46  com.adobe.premiere.frontend   0x000000010c7691a7 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 2503
                                        47  com.adobe.premiere.frontend   0x000000010c7bec1d AppMain + 253
                                        48  com.adobe.premiere.startup    0x000000010c93c3e8 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 232
                                        49  com.adobe.AdobePremierePro    0x0000000100003540 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 288
                                        50  com.adobe.AdobePremierePro    0x0000000100003ac7 main + 167
                                        51  com.adobe.AdobePremierePro    0x00000001000033a8 start + 52
                                        Thread 1:  Dispatch queue: com.apple.libdispatch-manager
                                        0   libSystem.B.dylib             0x00007fff8196cc0a kevent + 10
                                        1   libSystem.B.dylib             0x00007fff8196eadd _dispatch_mgr_invoke + 154
                                        2   libSystem.B.dylib             0x00007fff8196e7b4 _dispatch_queue_invoke + 185
                                        3   libSystem.B.dylib             0x00007fff8196e2de _dispatch_worker_thread2 + 252
                                        4   libSystem.B.dylib             0x00007fff8196dc08 _pthread_wqthread + 353
                                        5   libSystem.B.dylib             0x00007fff8196daa5 start_wqthread + 13
                                        Thread 2:
                                        0   libSystem.B.dylib             0x00007fff8198ea6a __semwait_signal + 10
                                        1   libSystem.B.dylib             0x00007fff81992881 _pthread_cond_wait + 1286
                                        2   com.adobe.amt.services        0x000000012148c247 C_AMTUISwitchSuppressUpdates + 16439
                                        3   com.adobe.amt.services        0x000000012148539e C_EULA_SetState + 1742
                                        4   com.adobe.amt.services        0x000000012148c2b2 C_AMTUISwitchSuppressUpdates + 16546
                                        5   libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        6   libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 3:
                                        2   ...ple.CoreServices.CarbonCore 0x00007fff85299d87 TSWaitOnCondition + 118
                                        3   ...ple.CoreServices.CarbonCore 0x00007fff85208ff8 TSWaitOnConditionTimedRelative + 177
                                        4   ...ple.CoreServices.CarbonCore 0x00007fff85202efb MPWaitOnQueue + 215
                                        5   ...obe.ASLFoundation.framework 0x00000001004a6450 ASL::(anonymous namespace)::TaskProc(void*) + 96
                                        6   ...ple.CoreServices.CarbonCore 0x00007fff851db0d1 PrivateMPEntryPoint + 63
                                        7   libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        8   libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 4:
                                        5   com.adobe.dvacore.framework   0x000000010018e2bf dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
                                        6   com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
                                        7   com.adobe.dvacore.framework   0x00000001001866a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
                                        8   ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
                                        9   libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        10  libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 5:
                                        Thread 6:
                                        1   ...dobe.dvatransport.framework 0x000000010069896e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
                                        2   ...dobe.dvatransport.framework 0x0000000100699a25 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 517
                                        3   ...dobe.dvatransport.framework 0x0000000100676abc SkyConnectionEnv::MainLoop() + 76
                                        4   ...dobe.dvatransport.framework 0x0000000100676b29 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                                        5   ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
                                        6   libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        7   libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 7:
                                        2   ...dobe.dvatransport.framework 0x0000000100699b5f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 831
                                        3   ...dobe.dvatransport.framework 0x000000010069a755 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 53
                                        4   ...dobe.dvatransport.framework 0x000000010067f6a9 asio_detail_posix_thread_function + 25
                                        Thread 8:
                                        Thread 9:
                                        Thread 10:
                                        Thread 11:
                                        Thread 12:
                                        Thread 13:
                                        0   libSystem.B.dylib             0x00007fff81953d7a mach_msg_trap + 10
                                        1   libSystem.B.dylib             0x00007fff819543ed mach_msg + 59
                                        2   com.apple.CoreFoundation      0x00007fff844df932 __CFRunLoopRun + 1698
                                        3   com.apple.CoreFoundation      0x00007fff844dedbf CFRunLoopRunSpecific + 575
                                        4   com.apple.audio.CoreAudio     0x00007fff85989786 HALRunLoop::OwnThread(void*) + 152
                                        5   com.apple.audio.CoreAudio     0x00007fff85976755 CAPThread::Entry(CAPThread*) + 125
                                        Thread 14:
                                        4   ...ple.CoreServices.CarbonCore 0x00007fff8526f617 MPWaitForEvent + 199
                                        5   ...obe.ASLFoundation.framework 0x00000001004ba51c ASL::WaitableObject::WaitForSignal(int) + 44
                                        6   ...obe.VideoRenderer.framework 0x0000000103f74964 ML::RenderFrame::Render(dvamediatypes::TickTime const&, dvamediatypes::FrameRate const&, ASL::InterfaceRef<BE::IVideoSegments, BE::IVideoSegments>, std::vector<dvamediatypes::PixelFormat, dvacore::utility::SmallBlockAllocator::STLAllocator<dvamediatypes::PixelFormat> > const&, bool, unsigned int, void*, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&, unsigned int*) + 1412
                                        7   com.adobe.PlayerHost.framework 0x00000001047d8e38 ML::VideoPlayer::RenderVideoFrame(long long, PPix***, PrPixelFormat const*, int, Rect const*, unsigned int, unsigned int, PrRenderQuality, int, bool) + 792
                                        8   com.adobe.PlayerHost.framework 0x00000001047ff429 ML::SDKCallbackPlayModuleRenderSuite_RenderVideoFrame(int, long long const*, PPix***, PrPixelFormat const*, int, Rect const*, unsigned int, unsigned int, PrRenderQuality, int, int) + 137
                                        9   ...e.PlayerMediaCore.framework 0x0000000125740f77 AdobePlayer::RenderRequestQueue::RenderRequestSync(ASL::ObjectPtr<AdobePlayer::RenderRequ est, ASL::AtomicValue> const&) + 743
                                        10  ...e.PlayerMediaCore.framework 0x00000001257376a2 AdobePlayer::RenderDevice::RenderImmediate(ASL::ObjectPtr<AdobePlayer::RenderRequest, ASL::AtomicValue>&, long long const&, int, pmPlayMode) + 82
                                        11  ...e.PlayerMediaCore.framework 0x00000001257249b4 AdobePlayer::PlayerMain::ShowFrameAtTime(long long, pmPlayMode) + 1252
                                        12  ...e.PlayerMediaCore.framework 0x00000001257254e1 AdobePlayer::PlayerMain::ShowCurrentFrame() + 49
                                        13  ...e.PlayerMediaCore.framework 0x000000012572bea8 AdobePlayer::PlayerMain::OnSetDisplay(pmDisplayPos const*) + 296
                                        14  ...e.PlayerMediaCore.framework 0x000000012573290c PrPlayModule<AdobePlayer::PlayerMain>::PlayEntry(int, pmStdParms*, void*, void*) + 636
                                        15  ...e.PlayerMediaCore.framework 0x0000000125732267 xPlayEntry + 23
                                        16  com.adobe.PlayerHost.framework 0x00000001047b7a1f ML::CallPlayerModuleGuarded(int (*)(int, pmStdParms*, void*, void*), int, pmStdParms*, void*, void*, int*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 159
                                        17  com.adobe.PlayerHost.framework 0x00000001047b8b19 ML::PlayerModule::CallPlugin(int, void*, void*) + 153
                                        18  com.adobe.PlayerHost.framework 0x00000001047dc703 ML::VideoPlayer::CallPlayModuleSelector_SetDisplay(NSView*, int, int, int, int) + 147
                                        19  com.adobe.PlayerHost.framework 0x00000001047ccae4 ML::VideoPlayer::SetViewAndDisplay(ASL::ParamRect<float> const&, NSView*, ASL::ParamRect<int> const&) + 292
                                        20  com.adobe.PlayerHost.framework 0x00000001047bd911 ML::PlayModuleThreadQueue::ExecuteDeferredCall(ASL::ObjectPtr<ML::DeferredCallBase, ASL::AtomicValue>) + 49
                                        21  com.adobe.PlayerHost.framework 0x00000001047bf69c ML::PlayModuleThreadQueue::ServiceQueue() + 444
                                        22  ...obe.ASLFoundation.framework 0x000000010049658a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf0<void, ASL::IThreadedQueueRequest>, boost::_bi::list1<boost::_bi::value<ASL::InterfaceRef<ASL::IThreadedQueueRequest, ASL::IThreadedQueueRequest> > > >, void>::invoke(boost::detail::function::function_buffer&) + 74
                                        23  com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
                                        24  com.adobe.dvacore.framework   0x000000010018e33b dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 267
                                        25  com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
                                        26  com.adobe.dvacore.framework   0x00000001001866a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
                                        27  ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
                                        28  libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        29  libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 15:
                                        Thread 16:
                                        4   com.apple.CoreFoundation      0x00007fff844deb46 CFRunLoopRun + 70
                                        5   com.adobe.dvacore.framework   0x0000000100178c59 dvacore::threads::RunPlatformEventLoop() + 89
                                        6   com.adobe.dvacore.framework   0x000000010017e831 dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPoint&) + 177
                                        7   com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
                                        8   com.adobe.dvacore.framework   0x00000001001866a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
                                        9   ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
                                        10  libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        11  libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 17:
                                        1   libSystem.B.dylib             0x00007fff8198e8f9 nanosleep + 148
                                        2   ...e.ScriptLayerPPro.framework 0x0000000106e7c8ab ScObjects::Thread::sleep(unsigned int) + 59
                                        3   ...e.ScriptLayerPPro.framework 0x0000000106e67403 ScObjects::BridgeTalkThread::run() + 163
                                        4   ...e.ScriptLayerPPro.framework 0x0000000106e7c9a6 ScObjects::Thread::go(void*) + 166
                                        Thread 18:
                                        0   libSystem.B.dylib             0x00007fff81997956 recvfrom + 10
                                        1   ServiceManager-Launcher.dylib 0x0000000125fa6562 Invoke + 54020
                                        2   ServiceManager-Launcher.dylib 0x0000000125fa56bf Invoke + 50273
                                        3   ServiceManager-Launcher.dylib 0x0000000125fa4706 Invoke + 46248
                                        4   ServiceManager-Launcher.dylib 0x0000000125fa4761 Invoke + 46339
                                        5   ServiceManager-Launcher.dylib 0x0000000125fa47e2 Invoke + 46468
                                        6   ServiceManager-Launcher.dylib 0x0000000125f9eeed Invoke + 23695
                                        7   ServiceManager-Launcher.dylib 0x0000000125f9f086 Invoke + 24104
                                        8   ServiceManager-Launcher.dylib 0x0000000125f9fb0f Invoke + 26801
                                        9   ServiceManager-Launcher.dylib 0x0000000125f9fbfd Invoke + 27039
                                        10  ServiceManager-Launcher.dylib 0x0000000125fa2eff Invoke + 40097
                                        11  ServiceManager-Launcher.dylib 0x0000000125fa31a5 Invoke + 40775
                                        12  ServiceManager-Launcher.dylib 0x0000000125fa3764 Invoke + 42246
                                        13  ServiceManager-Launcher.dylib 0x0000000125fa3951 Invoke + 42739
                                        14  ServiceManager-Launcher.dylib 0x0000000125f9567f Login + 1773
                                        15  ServiceManager-Launcher.dylib 0x0000000125f96d01 Login + 7535
                                        16  ServiceManager-Launcher.dylib 0x0000000125fa3e88 Invoke + 44074
                                        17  ServiceManager-Launcher.dylib 0x0000000125fa62a1 Invoke + 53315
                                        18  libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        19  libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 19:
                                        0   libSystem.B.dylib             0x00007fff81953dda semaphore_timedwait_signal_trap + 10
                                        1   libSystem.B.dylib             0x00007fff81992772 _pthread_cond_wait + 1015
                                        2   ...ple.CoreServices.CarbonCore 0x00007fff85209018 TSWaitOnConditionTimedRelative + 209
                                        3   ...ple.CoreServices.CarbonCore 0x00007fff85202efb MPWaitOnQueue + 215
                                        4   com.adobe.dvacore.framework   0x000000010018e2bf dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
                                        Thread 20:
                                        2   ...ple.CoreServices.CarbonCore 0x00007fff852974df TS_exception_listener_thread + 126
                                        3   libSystem.B.dylib             0x00007fff8198cfd6 _pthread_start + 331
                                        4   libSystem.B.dylib             0x00007fff8198ce89 thread_start + 13
                                        Thread 21 Crashed:  Dispatch queue: com.apple.root.default-priority
                                        0   libSystem.B.dylib             0x00007fff819c69ce __semwait_signal_nocancel + 10
                                        1   libSystem.B.dylib             0x00007fff819c68d0 nanosleep$NOCANCEL + 129
                                        2   libSystem.B.dylib             0x00007fff81a233ce usleep$NOCANCEL + 57
                                        3   libSystem.B.dylib             0x00007fff81a429a1 __abort + 113
                                        4   libSystem.B.dylib             0x00007fff81a42a05 abort_report_np + 0
                                        5   ...oftware.MBLooksRenderLibCPU 0x000000012e4d20d2 __kmp_do_abort + 42
                                        6   ...oftware.MBLooksRenderLibCPU 0x000000012e4c5801 __kmp_msg + 531
                                        7   ...oftware.MBLooksRenderLibCPU 0x000000012e4d2b4e __kmp_do_serial_initialize() + 662
                                        8   ...oftware.MBLooksRenderLibCPU 0x000000012e4d212f __kmp_serial_initialize + 85
                                        9   ...oftware.MBLooksRenderLibCPU 0x000000012e4c3e56 __kmpc_global_thread_num + 32
                                        10  ...oftware.MBLooksRenderLibCPU 0x000000012e4525f7 GetOmpNumThreads() + 55
                                        11  ...oftware.MBLooksRenderLibCPU 0x000000012e41c915 Pipeline::GetCpuContextRef() + 69
                                        12  ...oftware.MBLooksRenderLibCPU 0x000000012e42ec63 RenderEngine::RenderFrame(BufferDesc const*, BufferDesc const*, unsigned char const*, unsigned int, unsigned int, unsigned int) + 99
                                        13  com.redgiantsoftware.Looks3_AE 0x000000012de9e65b AELookSuitePlugin::render() + 2187
                                        14  com.redgiantsoftware.Looks3_AE 0x000000012dea3bb5 AEPluginBase::doCmd(int) + 709
                                        15  com.redgiantsoftware.Looks3_AE 0x000000012de9b794 EntryPointFunc + 52
                                        16  ...e.VideoFilterHost.framework 0x0000000104a40c9a ML::(anonymous namespace)::CallAEFilterModuleGuarded(int (*)(int, PF_InData*, PF_OutData*, PF_ParamDef**, PF_LayerDef*, void*), int, PF_InData*, PF_OutData*, PF_ParamDef**, PF_LayerDef*, void*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 170
                                        17  ...e.VideoFilterHost.framework 0x0000000104a41744 ML::AEVideoFilterModule::CallModule(int, PF_InData*, PF_OutData*, PF_ParamDef**, PF_LayerDef*, void*, bool) + 164
                                        18  ...e.VideoFilterHost.framework 0x0000000104a25152 ML::AEVideoFilter::CallAEFilter(int, PF_InData*, PF_OutData*, PF_ParamDef**, PF_LayerDef*, void*, bool) + 434
                                        19  ...e.VideoFilterHost.framework 0x0000000104a2d7b0 ML::AEVideoFilter::DoRender(dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, long long, long long, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&, ML::TemporalField, bool, bool, std::vector<ASL::InterfaceRef<BE::IComponentParam, BE::IComponentParam>, std::allocator<ASL::InterfaceRef<BE::IComponentParam, BE::IComponentParam> > > const&, bool, ASL::InterfaceRef<BE::IAction, BE::IAction>&, bool&) + 6368
                                        20  ...e.VideoFilterHost.framework 0x0000000104a2ec48 ML::AEVideoFilter::RenderFilterInternal(dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, dvamediatypes::FrameRate const&, long long, long long, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>, ASL::InterfaceRef<ASL::ASLUnknown, ASL::ASLUnknown>, BE::FilterRenderParameters&, std::vector<ASL::InterfaceRef<BE::IComponentParam, BE::IComponentParam>, std::allocator<ASL::InterfaceRef<BE::IComponentParam, BE::IComponentParam> > > const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 2264
                                        21  ...e.VideoFilterHost.framework 0x0000000104a2fbe3 ML::AEVideoFilter::RenderFilter(dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, dvamediatypes::FrameRate const&, long long, long long, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>, ASL::InterfaceRef<ASL::ASLUnknown, ASL::ASLUnknown>, BE::FilterRenderParameters&, std::vector<ASL::InterfaceRef<BE::IComponentParam, BE::IComponentParam>, std::allocator<ASL::InterfaceRef<BE::IComponentParam, BE::IComponentParam> > > const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 659
                                        22  ...obe.VideoRenderer.framework 0x0000000103f348ed ML::EffectNodeOperator::OperateOnFrame(MF::FrameTime const&, MF::FrameTime const&, ML::CutlistRenderParams const&, dvamediatypes::FrameRate const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame> const&, ASL::InterfaceRef<ML::SubTreeRender, ML::SubTreeRender> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) const + 685
                                        23  ...obe.VideoRenderer.framework 0x0000000103f20222 ML::ClipNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) const + 1538
                                        24  ...obe.VideoRenderer.framework 0x0000000103f2e573 ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) const + 259
                                        25  ...obe.VideoRenderer.framework 0x0000000103eebf7c ML::ProduceFrame(ASL::InterfaceRef<ML::IRenderableNodeProducer, ML::IRenderableNodeProducer> const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector<dvamediatypes::PixelFormat, dvacore::utility::SmallBlockAllocator::STLAllocator<dvamediatypes::PixelFormat> > const&, bool) + 300
                                        26  ...obe.VideoRenderer.framework 0x0000000103f9b933 ML::RenderFrameRequest::Render(dvamediatypes::PixelFormat) + 531
                                        27  ...obe.VideoRenderer.framework 0x0000000103f800eb ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) const + 363
                                        28  ...obe.VideoRenderer.framework 0x0000000103f80571 ML::RenderFrameQueue::ServiceQueue(bool) + 129
                                        29  ...obe.VideoRenderer.framework 0x0000000103f84417 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, ML::RenderFrameQueue, bool>, boost::_bi::list2<boost::_bi::value<ASL::InterfaceRef<ML::RenderFrameQueue, ASL::ASLUnknown> >, boost::_bi::value<bool> > >, void>::invoke(boost::detail::function::function_buffer&) + 87
                                        30  com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
                                        31  com.adobe.dvacore.framework   0x0000000100176c91 dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr<dvacore::threads::(anonymo us namespace)::SubExecutorImpl> const&) + 81
                                        32  com.adobe.dvacore.framework   0x0000000100190b3e dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT<boost::fun ction<void ()()> > const&) + 46
                                        33  com.adobe.dvacore.framework   0x0000000100190438 dvacore::threads::(anonymous namespace)::WrapGCDAsyncCall(void*) + 24
                                        34  libSystem.B.dylib             0x00007fff8196e2d1 _dispatch_worker_thread2 + 239
                                        35  libSystem.B.dylib             0x00007fff8196dc08 _pthread_wqthread + 353
                                        36  libSystem.B.dylib             0x00007fff8196daa5 start_wqthread + 13
                                        Thread 22:
                                        0   libSystem.B.dylib             0x00007fff8196da2a __workq_kernreturn + 10
                                        1   libSystem.B.dylib             0x00007fff8196de3c _pthread_wqthread + 917
                                        2   libSystem.B.dylib             0x00007fff8196daa5 start_wqthread + 13
                                        Thread 23:
                                        5   ...oftware.MBLooksRenderLibCPU 0x000000012e42eb10 RenderTask(void*) + 48
                                        Thread 24:
                                        5   ...tsoftware.ColoristaRenderer 0x000000012ec599c0 RenderTask(void*) + 48
                                        Thread 25:
                                        2   ...tsoftware.ColoristaRenderer 0x000000012ed29c02 __kmp_launch_monitor(void*) + 474
                                        Thread 26:
                                        2   ...tsoftware.ColoristaRenderer 0x000000012ed26d36 __kmp_suspend + 208
                                        3   ...tsoftware.ColoristaRenderer 0x000000012ed0a5ae __kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, void*) + 442
                                        4   ...tsoftware.ColoristaRenderer 0x000000012ed0c122 __kmp_fork_barrier(int, int) + 200
                                        5   ...tsoftware.ColoristaRenderer 0x000000012ed0bf1d __kmp_launch_thread + 89
                                        6   ...tsoftware.ColoristaRenderer 0x000000012ed2ae50 __kmp_launch_worker(void*) + 184
                                        Thread 27:
                                        2   com.apple.audio.CoreAudio     0x00007fff8597668c CAGuard::WaitFor(unsigned long long) + 168
                                        3   com.apple.audio.CoreAudio     0x00007fff85978c1b CAGuard::WaitUntil(unsigned long long) + 185
                                        4   com.apple.audio.CoreAudio     0x00007fff85976d85 HP_IOThread::WorkLoop() + 1369
                                        5   com.apple.audio.CoreAudio     0x00007fff85976827 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
                                        6   com.apple.audio.CoreAudio     0x00007fff85976755 CAPThread::Entry(CAPThread*) + 125
                                        Thread 21 crashed with X86 Thread State (64-bit):
                                          rax: 0x000000000000003c  rbx: 0x0000000125e26390  rcx: 0x0000000125e26348  rdx: 0x0000000000000001
                                          rdi: 0x0000000000000c03  rsi: 0x0000000000000000  rbp: 0x0000000125e26380  rsp: 0x0000000125e26348
                                           r8: 0x0000000000000000   r9: 0x0000000000989680  r10: 0x0000000000000001  r11: 0x0000000000000246
                                          r12: 0x0000000000000000  r13: 0x000000012ff150b5  r14: 0x0000000000030005  r15: 0x0000000000000002
                                          rip: 0x00007fff819c69ce  rfl: 0x0000000000000247  cr2: 0x000000013531100e
                                        Binary Images:
                                               0x100000000 -        0x100003fff +com.adobe.AdobePremierePro 5.5.0 (5.5.0) <2DAF1480-B633-192E-D640-5498244937DC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/MacOS/Adobe Premiere Pro CS5.5
                                               0x100008000 -        0x10000dffd +com.adobe.AdobeCrashReporter 3.0 (5.5.20101001) <5625AF72-323C-27C5-0094-213D09698D11> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                               0x100011000 -        0x100083ff7 +com.adobe.amtlib amtlib 4.0.0.21 (4.0.0.21) <E604CBB8-A3F0-69D1-510B-3D8156D37D29> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                               0x10009a000 -        0x1000a1fff +com.adobe.boost_date_time.framework boost_date_time version 5.5.0 (5.5.0.233) <575000B6-FC00-DBF0-75B4-9406D5EE1ADF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                                               0x1000bc000 -        0x1000c4ff7 +com.adobe.boost_threads.framework boost_threads version 5.5.0 (5.5.0.233) <9BFFD349-156E-69D5-C0EF-954FEE1C0706> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                                               0x1000da000 -        0x100268fe7 +com.adobe.dvacore.framework dvacore version 5.5.0 (5.5.0.233) <13CC32EF-EB9D-AEC6-F42A-0858A5E30234> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                               0x100419000 -        0x10043afef +com.adobe.dvamediatypes.framework dvamediatypes version 5.5.0 (5.5.0.233) <BA3B2A94-959B-6D5A-870A-36C4CDF0E3F9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                                               0x100465000 -        0x100466fff +com.adobe.PRM.framework PRM version 5.5.0 (5.5.0.0) <AD3E526D-FB0F-4C09-837C-0B61984BCEF5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                                               0x10046c000 -        0x1004d3ff7 +com.adobe.ASLFoundation.framework ASLFoundation version 5.5.0 (5.5.0.0) <84C8706F-621E-5633-6DC7-09517E8CE7D3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                                               0x1005d2000 -        0x1005e8fff +com.adobe.ASLMessaging.framework ASLMessaging version 5.5.0 (5.5.0.0) <394C6ED9-ADDE-663D-4E2A-CA030DFC99AE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                                               0x10060d000 -        0x10060efff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <D9747273-37A6-4D7B-A28F-CDDC14CADF14> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                                               0x100615000 -        0x100627ff7 +com.adobe.ASLUnitTesting.framework ASLUnitTesting version 5.5.0 (5.5.0.0) <02CAA5AF-EC36-3E87-243D-2592FC36D3CD> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
                                               0x100645000 -        0x100646fff +com.adobe.boost_system.framework boost_system version 5.5.0 (5.5.0.233) <8D01B0C5-1D9A-114A-996A-9683400D4987> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                                               0x10064f000 -        0x1006c7fff +com.adobe.dvatransport.framework dvatransport version 5.5.0 (5.5.0.233) <0B9D3E2F-4F4D-695E-B219-57A67E5EEA49> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                                               0x10075f000 -        0x10079ffff +com.adobe.dvamarshal.framework dvamarshal version 5.5.0 (5.5.0.233) <A946A5E7-FE0D-264F-F7A8-270ABD744D50> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                                               0x10083c000 -        0x100a2cfe7 +com.adobe.dynamiclink.framework dynamiclink version 5.5.0 (5.5.0.233) <2AA1175D-0572-242A-98ED-8B4153F4A7E1> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                                               0x100baa000 -        0x100be9fe7 +com.adobe.MediaFoundation.framework MediaFoundation version 5.5.0 (5.5.0.0) <7A20BCB7-0D45-A0E6-7D8E-8583E3D97386> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                                               0x100c48000 -        0x100cc6fe7 +com.adobe.AudioRenderer.framework AudioRenderer version 5.5.0 (5.5.0.0) <24E78936-3C2E-607C-668C-631287050D8B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                                               0x100d78000 -        0x100da2fff +com.adobe.dvacaptioning.framework dvacaptioning version 5.5.0 (5.5.0.233) <D353C687-8E04-6800-7924-FBFF73E71C40> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
                                               0x100dd0000 -        0x10190bfe7 +com.adobe.Backend.framework Backend version 5.5.0 (5.5.0.0) <A1A3642F-319E-1431-AEA7-60582C6DFCAB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                                               0x102818000 -        0x1029e8fe7 +com.adobe.ImageRenderer.framework ImageRenderer version 5.5.0 (5.5.0.0) <4CED009C-05FA-164F-5A10-4729B727B40B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                                               0x102af1000 -        0x102b32ff7 +com.adobe.MLFoundation.framework MLFoundation version 5.5.0 (5.5.0.0) <16822B47-71BB-4FFF-403D-7F14E56DFDAB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                                               0x102b98000 -        0x102bf3ff7 +com.adobe.VideoFrame.framework VideoFrame version 5.5.0 (5.5.0.0) <291C329E-02B3-CD6F-C892-04028E456556> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                                               0x102c75000 -        0x102cafff7 +com.adobe.PluginSupport.framework PluginSupport version 5.5.0 (5.5.0.0) <E3EFEC9F-1610-7313-8F5D-190C39EDD9FD> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                                               0x102cff000 -        0x102d3ffff +com.adobe.SweetPeaSupport.framework SweetPeaSupport version 5.5.0 (5.5.0.0) <7EF8F6EB-9AA8-D321-674B-67A6DCEC55FB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                                               0x102da0000 -        0x102de2ff7 +com.adobe.AudioSupport.framework AudioSupport version 5.5.0 (5.5.0.0) <B9FD71E8-C2E9-D623-B0CB-7E70267912D9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                                               0x102e36000 -        0x102e39ff7 +com.adobe.MediaUtils.framework MediaUtils version 5.5.0 (5.5.0.0) <00B41115-09AE-8B82-7E39-319E5E46D357> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                                               0x102e40000 -        0x102e5dff7 +com.adobe.AudioFilterHost.framework AudioFilterHost version 5.5.0 (5.5.0.0) <8ED1DD51-2219-327B-BC5C-EE4F26C4709A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                                               0x102e8d000 -        0x102eebffd +com.adobe.AdobeXMPCore Adobe XMP Core 5.2 -c 3 (61.141987) <37A7128D-857A-F1CF-A00D-497983A42017> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                               0x102efb000 -        0x102f9ffef +com.adobe.AdobeXMPFiles Adobe XMP Files 5.2 -f 17 (61.141987) <C504760D-5727-CC17-08BD-74688712F2C4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                                               0x102fd2000 -        0x10300bfef +com.adobe.AudioFilters.framework AudioFilters version 5.5.0 (5.5.0.0) <BDD4D962-A84F-CDE6-16BC-537132DDCF50> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                                               0x103085000 -        0x103091ff7 +com.adobe.boost_signals.framework boost_signals version 5.5.0 (5.5.0.233) <80163CD8-3F67-4877-1CE4-CBE99E3160F7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                                               0x1030aa000 -        0x10340ffef +com.adobe.dvaui.framework dvaui version 5.5.0 (5.5.0.233) <0565C197-3CF1-EFD3-3316-A65B8A574AF5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                                               0x103831000 -        0x103ae0fff +com.adobe.UIFramework.framework UIFramework version 5.5.0 (5.5.0.233) <47121FC6-287C-9636-2D58-5144C691716B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
                                               0x103ece000 -        0x103ffafff +com.adobe.VideoRenderer.framework VideoRenderer version 5.5.0 (5.5.0.0) <5354E859-1C3A-A80D-8DF0-58E3357460E9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                                               0x104195000 -        0x104366fff +com.adobe.ImporterHost.framework ImporterHost version 5.5.0 (5.5.0.0) <C0070B85-AD71-DB00-31B4-4E7F94314A53> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                                               0x104592000 -        0x10465fff7 +com.adobe.ExporterHost.framework ExporterHost version 5.5.0 (5.5.0.0) <9134EAAC-FA20-3B98-ABF7-D90F6A801215> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                                               0x10479e000 -        0x104821fff +com.adobe.PlayerHost.framework PlayerHost version 5.5.0 (5.5.0.0) <2913DCA7-2A38-0D9A-C54B-30FF66DFFFCE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                                               0x1048e4000 -        0x104956ff7 +com.adobe.RecorderHost.framework RecorderHost version 5.5.0 (5.5.0.0) <1B0C1090-5865-9400-7E03-C8F060F25B54> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
                                               0x1049ee000 -        0x1049fdff7 +com.adobe.ProjectConverterHost.framework ProjectConverterHost version 5.5.0 (5.5.0.0) <F540E650-57F6-DA03-74AE-5AA1684F2811> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterH ost
                                               0x104a15000 -        0x104aeffff +com.adobe.VideoFilterHost.framework VideoFilterHost version 5.5.0 (5.5.0.0) <EB7740FF-3A76-9532-92F2-D10DF0A677C9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                                               0x104bcb000 -        0x104bdaff7 +com.adobe.ProjectSupport.framework ProjectSupport version 5.5.0 (5.5.0.0) <615322FC-88BF-E5BF-E4A7-29FA5390AA1F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                                               0x104bf3000 -        0x104c0bff7 +com.adobe.AMEAppFoundation.framework AMEAppFoundation version 5.5.0 (5.5.0.0) <D0DFB126-503D-2B37-D474-2142C9F82CE4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                                               0x104c35000 -        0x104c58fff +com.adobe.PostEncodeHost.framework PostEncodeHost version 5.5.0 (5.5.0.0) <739DE9CD-A999-E201-C4C4-7476ABA7C535> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
                                               0x104c8d000 -        0x104cccff7 +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.5.0 (5.5.0.233) <360ED464-77B2-BE6D-6929-51DBC5379518> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                                               0x104ce8000 -        0x104d05fff +com.adobe.BIB AdobeBIB 1.2.02.12659 (1.2.02.12659) <6819BA1B-DF86-5EE8-C777-4E011D616A39> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                               0x104d10000 -        0x104db0fef +com.adobe.AdobeScCore ScCore 4.1.28 (4.1.28.13048) <83CA2291-5B56-AB69-AF81-A1FBD64AA937> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                                               0x104df9000 -        0x104e9dffb +com.adobe.AdobeExtendScript ExtendScript 4.1.28 (4.1.28.13048) <3022B3E5-07EC-A68B-5E75-41996620745F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                                               0x104f02000 -        0x104f59fff +com.adobe.BravoInitializer.framework BravoInitializer version 5.5.0 (5.5.0.0) <07C40DB8-B9AA-F6C7-6594-B8C5ABD27D43> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
                                               0x104fde000 -        0x10511cff7 +com.adobe.ACE AdobeACE 2.18.00.12659 (2.18.00.12659) <50F24A33-D8E9-5F39-22C8-75B097EE97B8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                               0x105146000 -        0x105490fe7 +com.adobe.AGM AdobeAGM 4.20.70.12659 (4.20.70.12659) <085E87D9-3079-EA53-25DC-85800CCBB0DF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                               0x105569000 -        0x10589afe7 +com.adobe.CoolType AdobeCoolType 5.07.124.12659 (5.07.124.12659) <C36D0E60-9ACD-1302-CBDC-07722DD97DE9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                               0x10593c000 -        0x1059ffff7 +com.adobe.AMEWrapper.framework AMEWrapper version 5.5.0 (5.5.0.0) <3E1C898E-A5CA-631E-04D1-254B7485D790> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
                                               0x105ad5000 -        0x105beefff +com.adobe.EncoderHost.framework EncoderHost version 5.5.0 (5.5.0.0) <A7CD8C66-0392-711D-DEF2-58FBA614784F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                                               0x105d10000 -        0x105da7ff7 +com.adobe.MBCProvider.framework MBCProvider version 5.5.0 (5.5.0.233) <300CD412-82B9-5CAE-D7F4-13E92E0D75E7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
                                               0x105e41000 -        0x10653afff +com.adobe.Mezzanine.framework Mezzanine version 5.5.0 (5.5.0.233) <3EDBE5B6-F6F4-F610-3C77-688DB69C2EA6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
                                               0x106b88000 -        0x106b99ff8 +com.adobe.ahclientframework 1.6.0.20 (1.6.0.20) <AD464E16-20D1-A4FC-878D-CF44322F72BC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                               0x106ba6000 -        0x106c5bff7 +com.adobe.dvaworkspace.framework dvaworkspace version 5.5.0 (5.5.0.233) <80D3EE09-5D72-E780-CA49-E8E47D07A30E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                                               0x106d58000 -        0x106ee7fff +com.adobe.ScriptLayerPPro.framework ScriptLayerPPro version 5.5.0 (5.5.0.233) <30A28312-6604-37F8-C434-F7B8654C645E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
                                               0x107127000 -        0x1071fefe7 +com.adobe.dvaeve.framework dvaeve version 5.5.0 (5.5.0.233) <61FA5D63-DB8B-8D0F-9B96-7D70451B46F0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                                               0x10735c000 -        0x1073d8ff7 +com.adobe.MediaCoreUI.framework MediaCoreUI version 5.5.0 (5.5.0.0) <160AAABC-2145-6A08-69FC-46E4E13515AA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                                               0x107460000 -        0x107657ff7 +com.adobe.SettingsUI.framework SettingsUI version 5.5.0 (5.5.0.0) <4D18628F-3FCB-7382-8171-0A24D7BD43D3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                                               0x1078f3000 -        0x107a72fef +com.adobe.HSL.framework HSL version 5.5.0 (5.5.0.233) <C0DC5FA7-4CFD-ED51-5C06-9B62FCFEA22E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
                                               0x107c56000 -        0x107fe0fff +com.adobe.Dialogs.framework Dialogs version 5.5.0 (5.5.0.233) <3CB7833A-9B3F-612E-8357-52CBF42B9F84> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
                                               0x108369000 -        0x108379fff +com.adobe.HandlerAudioMiniMixer.framework HandlerAudioMiniMixer version 5.5.0 (5.5.0.233) <F1B6A9AE-6F31-C517-6EC2-DA704FB51AB5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMini Mixer
                                               0x10839e000 -        0x108437fff +com.adobe.HandlerAudioMixer.framework HandlerAudioMixer version 5.5.0 (5.5.0.233) <27A0308A-099E-59C9-27FF-6EDE9C4B2849> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
                                               0x10850e000 -        0x1085a3fff +com.adobe.HandlerCapture.framework HandlerCapture version 5.5.0 (5.5.0.233) <04CB52A5-B067-29EB-D899-88D036D19F13> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
                                               0x10867c000 -        0x108697ff7 +com.adobe.HandlerCSXS.framework HandlerCSXS version 5.5.0 (5.5.0.233) <3D4E335B-368B-056D-0C77-5EA1E89D43DB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
                                               0x1086d4000 -        0x108908fff +com.adobe.HandlerEffectControls.framework HandlerEffectControls version 5.5.0 (5.5.0.233) <FA9EA28F-A97E-62D2-4D90-C32532F47FB2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectCon trols
                                               0x108b71000 -        0x108bd5fff +com.adobe.HandlerEffects.framework HandlerEffects version 5.5.0 (5.5.0.233) <F4C48E7E-0FEB-BF62-F4EA-376F2F6E84BA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
                                               0x108c50000 -        0x108c5cfff +com.adobe.HandlerEvents.framework HandlerEvents version 5.5.0 (5.5.0.233) <6C5CD2F7-C5F1-185A-AB9D-A4F85A222B2E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
                                               0x108c82000 -        0x108c93fff +com.adobe.HandlerGetProperties.framework HandlerGetProperties version 5.5.0 (5.5.0.233) <00E99DDE-3999-2A5A-FC44-78A39FB4467A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetPropert ies
                                               0x108cb5000 -        0x108cccff7 +com.adobe.HandlerHistory.framework HandlerHistory version 5.5.0 (5.5.0.233) <103A398D-8CF1-C0A0-26BD-2F0E163A6660> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
                                               0x108cfa000 -        0x108d44ff7 +com.adobe.HandlerInfo.framework HandlerInfo version 5.5.0 (5.5.0.233) <A6A76324-8EA0-9D14-408F-B46015DC6A23> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
                                               0x108dab000 -        0x108e04ff7 +com.adobe.HandlerMetadataEditor.framework HandlerMetadataEditor version 5.5.0 (5.5.0.233) <CBF125AE-629E-29A1-AEF3-BC2EC22C8EEA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataE ditor
                                               0x108ea4000 -        0x108f08ff7 +com.adobe.HandlerMediaBrowser.framework HandlerMediaBrowser version 5.5.0 (5.5.0.233) <006A5852-D72A-5D60-5AC2-19405B0103C2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowse r
                                               0x108fa3000 -        0x108fc7ff7 +com.adobe.HandlerMulticam.framework HandlerMulticam version 5.5.0 (5.5.0.233) <44E01CE5-8095-39E6-11B1-84CAD5EA0912> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMulticam.framework/Versions/A/HandlerMulticam
                                               0x10900c000 -        0x10909fff7 +com.adobe.HandlerProgramMonitor.framework HandlerProgramMonitor version 5.5.0 (5.5.0.233) <3C56A9C7-6F7A-5A03-040E-427DD5A8251B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMo nitor
                                               0x109188000 -        0x10933dff7 +com.adobe.HandlerProject.framework HandlerProject version 5.5.0 (5.5.0.233) <A3A857E5-38B2-90D6-976D-39942D2AF282> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
                                               0x109561000 -        0x109653ff7 +com.adobe.HandlerSourceMonitor.framework HandlerSourceMonitor version 5.5.0 (5.5.0.233) <F77BFAB1-B451-5867-351E-227B56DF9971> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMoni tor
                                               0x10976a000 -        0x109961ff7 +com.adobe.HandlerTimeline.framework HandlerTimeline version 5.5.0 (5.5.0.233) <2566D6F0-B97D-0DBF-F1CB-DFB59A51ADDB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
                                               0x109b89000 -        0x109bf0ff7 +com.adobe.FontEngine.framework FontEngine version 5.5.0 (5.5.0.233) <5653082D-C8EC-6814-B95B-EA31F22C5BA8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
                                               0x109c8f000 -        0x109cbffff +com.adobe.TitleLayer.framework TitleLayer version 5.5.0 (5.5.0.233) <9A824CAE-2AD4-951B-5153-FBBA99334C5C> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
                                               0x109e71000 -        0x109e7ffe7 +com.adobe.TitleImageManager.framework TitleImageManager version 5.5.0 (5.5.0.233) <18A87CD0-8F6D-D144-5396-2079BD83B2BF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
                                               0x109e9b000 -        0x109f3cff7 +com.adobe.TitleCharacterFactory.framework TitleCharacterFactory version 5.5.0 (5.5.0.233) <CD346A2C-4445-81B3-8358-D32D62014C58> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFa ctory
                                               0x109fa7000 -        0x10a0d7fef +com.adobe.TitleCG.framework TitleCG version 5.5.0 (5.5.0.233) <268CE1D6-CC83-ABE8-3512-D975185B6495> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
                                               0x10a1b8000 -        0x10a52bff7 +com.adobe.TitleLayout.framework TitleLayout version 5.5.0 (5.5.0.233) <0B2E5685-EB52-304A-1F99-79B238F7D3A8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
                                               0x10ac86000 -        0x10ad03fff +com.adobe.TitleRenderer.framework TitleRenderer version 5.5.0 (5.5.0.233) <59A508B7-246B-9A4A-2134-32D49944F5EB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
                                               0x10adcf000 -        0x10b61ffef +com.adobe.premiere.HandlerTitler 1.0 (1.0) <E42EDE8F-0043-42EF-DC49-B92826A273B8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
                                               0x10c12f000 -        0x10c272fef +WRServices ??? (???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                               0x10c2be000 -        0x10c2eeff7 +com.adobe.HandlerTools.framework HandlerTools version 5.5.0 (5.5.0.233) <F696F050-A0F8-E24F-8399-113D07FE76EE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
                                               0x10c38e000 -        0x10c3cdfff +com.adobe.HandlerTrim.framework HandlerTrim version 5.5.0 (5.5.0.233) <6606604C-4939-7757-017C-137198942A28> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTrim.framework/Versions/A/HandlerTrim
                                               0x10c430000 -        0x10c43fff7 +com.adobe.HandlerVSTEditor.framework HandlerVSTEditor version 5.5.0 (5.5.0.233) <8D9DE50E-CAE8-F4E9-0B2A-606D7BE7B7FB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerVSTEditor.framework/Versions/A/HandlerVSTEditor
                                               0x10c462000 -        0x10c47dfff +com.adobe.CSXSManager.framework CSXSManager version 5.5.0 (5.5.0.233) <53573694-8690-6DB0-3723-2BCDBA05E5F2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
                                               0x10c4a5000 -        0x10c642fff +com.adobe.PlugPlug 2.5.0.232 (2.5.0.232) <09F6FBA4-E768-BDFB-35AE-C7EB8EBA2D1A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                                               0x10c6f0000 -        0x10c715fff +com.adobe.PrRegistration.framework PrRegistration version 5.5.0 (5.5.0.233) <04E2D249-FB99-72D0-7E7F-FEEA3F838391> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrRegistration
                                               0x10c735000 -        0x10c810fff +com.adobe.premiere.frontend 1.0 (1.0) <E680FB53-18A0-A451-CC31-D822D801C2FD> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
                                               0x10c935000 -        0x10c956fff +com.adobe.premiere.startup 1.0 (1.0) <C3D52AF2-DC03-DA59-C18C-4EE4297E87FA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
                                               0x10c972000 -        0x10ca58fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
                                               0x10cab0000 -        0x10cd88fe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libxerces-c-3.0.dylib
                                               0x10cf02000 -        0x10cf29ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.40804) <AC47EA6A-1549-A7DA-EDF8-ABE11C38D179> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/mc_enc_dv.framework/Versions/8.5/mc_enc_dv
                                               0x10cf3d000 -        0x10cf3dff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
                                               0x10cf40000 -        0x10cf96fff +com.adobe.GPUFoundation.framework GPUFoundation version 5.5.0 (5.5.0.0) <9813E17D-CC20-4054-C41C-0270CDF8F21F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
                                               0x10d0f4000 -        0x10d1aafff +com.adobe.exo.framework exo version 5.5.0 (5.5.0.233) <D3E299AD-5454-F010-8474-07477382A092> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/exo.framework/Versions/A/exo
                                               0x10d2d8000 -        0x10d327fff +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.5.0 (5.5.0.233) <251CF852-5711-300B-310D-D9E8B22E1BF5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
                                               0x10d39f000 -        0x10d3cbff7 +com.adobe.amefoundation.framework amefoundation version 5.5.0 (5.5.0.0) <AD58F2FB-D65B-9EA0-4CD0-8FD87E594524> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
                                               0x10d415000 -        0x10d43ffff +com.adobe.ameproperties.framework ameproperties version 5.5.0 (5.5.0.0) <DB927F22-7B0D-8BB5-6CCD-E0AB802D2850> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
                                               0x10d492000 -        0x10d4b3fff +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <57E822F5-271D-A9EE-A92C-88C8835DCC68> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                               0x10d4c2000 -        0x10d4c8fff +com.adobe.AppServices.framework AppServices version 5.5.0 (5.5.0.0) <2C59D2D1-83C8-7936-04C9-49213A0DB39F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
                                               0x10d4d6000 -        0x10d52efeb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1263) <3CCEC733-BC2D-63D5-7DD6-FA2616C67B9E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                               0x10d574000 -        0x10d57aff7  com.apple.agl 3.0.12 (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                               0x10d581000 -        0x10d5dcff7 +com.adobe.dvametadata.framework dvametadata version 5.5.0 (5.5.0.233) <93EBD415-0B36-8AA3-65A8-8F88EA5A2B08> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                                               0x10d669000 -        0x10d771ff7 +com.adobe.dvametadataDB.framework dvametadataDB version 5.5.0 (5.5.0.233) <E4C27C90-3DA3-D86D-84BD-C6BBA721E9DC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
                                               0x10d7bd000 -        0x10d856ff7 +com.adobe.dvametadataUI.framework dvametadataUI version 5.5.0 (5.5.0.233) <5F774FE0-9337-452D-680D-F10FEF247087> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                                               0x10d901000 -        0x10d920ff7 +com.adobe.dvastoryparser.framework dvastoryparser version 5.5.0 (5.5.0.233) <58197FBF-A24E-CB32-F65F-4D4A94CD2250> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
                                               0x10d93e000 -        0x10d982fff +com.adobe.DynamicLinkMedia.framework DynamicLinkMedia version 5.5.0 (5.5.0.0) <33DD3195-BD13-EF42-9289-2C2C2CCC7D14> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                                               0x10da06000 -        0x10da6aff7 +com.adobe.QT32Client.framework QT32Client version 5.5.0 (5.5.0.0) <9DEACCB0-5BB0-0EEB-793F-C29BC5FDEAED> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
                                               0x10daf1000 -        0x10dc5efe7 +com.adobe.Display.framework Display version 5.5.0 (5.5.0.0) <FAACC489-C954-154E-5F7E-CDC57F8B971A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Display.framework/Versions/A/Display
                                               0x10df76000 -        0x10dfdbfff +aif_core ??? (???) <CCF73A5E-ED9B-5409-27FC-44E12098C191> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                                               0x10dfff000 -        0x10e234ff7 +aif_ogl ??? (???) <3C8F8D5E-081D-F87A-AE75-2566681F3275> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                                               0x10e34e000 -        0x10e36dfff +image_runtime ??? (???) <B3AC8DB1-4754-1FF6-098E-10DEC1C9F146> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                                               0x10e392000 -        0x10e44ffef +com.diaquest.pro4.omf 1.0.0.1022 (1.0.0.1022) <C735F37D-4D03-1648-4A2E-F94E65070BD0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
                                               0x10e477000 -        0x10e490feb +libtbb.dylib ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libtbb.dylib
                                               0x10e4a1000 -        0x10e4a7feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libtbbmalloc.dylib
                                               0x10e4ae000 -        0x10e4b2ff8 +com.adobe.ape.shim adbeape version 3.1.74.12761 (3.1.74.12761) <09559AEB-61DE-8DE8-4315-BFA0A7D6394B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                               0x10e4b7000 -        0x10e533ff7 +com.adobe.PProDynamicLinkServer.framework PProDynamicLinkServer version 5.5.0 (5.5.0.233) <3C9B3F90-D179-A09D-8474-1A38E192BBB6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkS erver
                                               0x10e613000 -        0x10e61afff +com.adobe.dvacaptioningui.framework dvacaptioningui version 5.5.0 (5.5.0.233) <977BE5B5-125D-F563-4B30-1047A76CAF2E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
                                               0x10e6d9000 -        0x10e6e1fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                                               0x10f183000 -        0x10f1a9fff  GLRendererFloat ??? (???) <490221DD-53D9-178E-3F31-3A4974D34DCD> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                                               0x10f300000 -        0x10f327ff7 +com.adobe.ExporterQuickTimeHost.framework ExporterQuickTimeHost version 5.5.0 (5.5.0.0) <D45F2F8A-D919-06FE-84BB-388F519EF872> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQu ickTimeHost
                                               0x10f3e9000 -        0x10f3ebfef  com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                               0x10f3f6000 -        0x10f3f7fff  com.digidesign.fwfamily.halplugin 8.0.5 (8.0.5f60) <CC39A2C7-050D-D34A-04A1-6174615032D7> /System/Library/Extensions/DigidesignFireWireAudio.kext/Contents/PlugIns/DGFWHALPlugIn.bu ndle/Contents/MacOS/DGFWHALPlugIn
                                               0x10f5e4000 -        0x10f777fe7  GLEngine ??? (???) <53A8A7E8-4846-D236-F3D9-DA3F2AF686D8> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                                               0x10f7a8000 -        0x10f7acfff  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <917E3DC8-E34D-B130-F61F-50808466E674> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                                               0x10f7b1000 -        0x10f7b7ff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f13) <36EA935F-F962-23B1-7965-4960D6625982> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                                               0x121000000 -        0x12141cfff  com.apple.ATIRadeonX2000GLDriver 1.6.36 (6.3.6) <EBE273B9-6BF7-32B1-C5A2-2B3C85D776AA> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
                                               0x121468000 -        0x1214dcff3 +com.adobe.amt.services AMTServices 4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00) (4.0.0.21) <1B6C37A0-570C-14D0-52A3-87C835F530BB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                                               0x12157c000 -        0x1215f4fef +com.adobe.adobe_caps adobe_caps 4.0.42.0 (4.0.42.0) <7AAC7875-787B-A4BA-F319-2B4425511ED4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                                               0x1223f1000 -        0x1223f7fff +com.adobe.ExporterCoreAudio.framework ExporterCoreAudio version 5.5.0 (5.5.0.0) <60755676-3CCD-97F0-4AF4-29A122170694> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCoreAu dio
                                               0x1231ad000 -        0x1231afff7 +com.adobe.Motion.framework Motion version 5.5.0 (5.5.0.0) <2D12B8CD-AAE0-74EB-29BD-5BA4CDFC60B1> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
                                               0x1231b2000 -        0x1231cbfff +com.adobe.QTParser.framework QTParser version 5.5.0 (5.5.0.0) <679FD2AE-66ED-4D51-707F-D349C47869B5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                                               0x1231e4000 -        0x123204ff7 +com.adobe.ape adbeapecore version 3.1.74.12761 (3.1.74.12761) <48D74CFC-E9C7-143A-F971-2C7F0ACF7602> /Library/Application Support/Adobe/APE/3.101/adbeapecore.framework/adbeapecore
                                               0x124a91000 -        0x124a93ff7 +com.adobe.Opacity.framework Opacity version 5.5.0 (5.5.0.0) <E2236FBC-05A9-8496-3A9B-E04A7B3B2060> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacity
                                               0x12536b000 -        0x12539efe7 +com.digidesign.digidesign.DigiCoreAudioPlugIn 8.0.5 (8.0.5f60) <284E1902-775A-27DF-8607-1CAE73066D30> /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio
                                               0x12552f000 -        0x12554bfff +com.adobe.VXMLPresetReader.framework VXMLPresetReader version 5.5.0 (5.5.0.0) <2C11ABD2-D24F-223F-ED7F-833966A39708> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VXMLPresetReader.framework/VXMLPresetReader
                                               0x125585000 -        0x125594ff7 +com.adobe.PremiereFiltersMetaPlugin.framework PremiereFiltersMetaPlugin version 5.5.0 (5.5.0.0) <64AC313F-2B3A-3AD1-3544-23A3FA783004> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/Premiere FiltersMetaPlugin
                                               0x1255ad000 -        0x1255bffe7 +com.adobe.TransitionsMetaPlugin.framework TransitionsMetaPlugin version 5.5.0 (5.5.0.0) <4F37A87D-2BC3-3955-5FBB-F42A2F5DD946> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsM etaPlugin
                                               0x125700000 -        0x125773fff +com.adobe.PlayerMediaCore.framework PlayerMediaCore version 5.5.0 (5.5.0.0) <43DD9C7A-61C7-2394-3EB1-0A8EEDF1C3C9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
                                               0x1257ec000 -        0x125822ff7  com.apple.AVCVideoServices 1.0 (42) <542C7C48-9C21-33F9-FF51-ABFAEBE33B6E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
                                               0x12585a000 -        0x12587bfef +com.adobe.AudioVideoIO.framework AudioVideoIO version 5.5.0 (5.5.0.0) <8B305308-47D6-3FB2-DB1F-9E958FE27560> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVideoIO
                                               0x12594d000 -        0x12595cfef +com.adobe.AudioConverter.framework AudioConverter version 5.5.0 (5.5.0.0) <39E0D4E5-DCEF-3F03-1565-C4B0E16B9B10> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
                                               0x125997000 -        0x125b89ff7  com.apple.audio.codecs.Components 2.0.3 (2.0.3) <9C486CBC-47B6-6703-EE2A-34F28C1FE023> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
                                               0x125bfa000 -        0x125c3ffff +com.adobe.ImporterQuickTime.framework ImporterQuickTime version 5.5.0 (5.5.0.0) <D134C964-8B10-12E8-BACB-21A43995E6EE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQuickT ime
                                               0x125c89000 -        0x125d6afff +com.adobe.IPPMPEGDecoder.framework IPPMPEGDecoder version 5.5.0 (5.5.0.0) <298699E4-39BB-E81E-ACD5-F0AE69A33D7B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/IPPMPEGDecoder.framework/IPPMPEGDecoder
                                               0x125f93000 -        0x125fbbfef +ServiceManager-Launcher.dylib 236.0.0 (compatibility 2.5.0) <DBEE8529-7074-635B-2CAD-DF7BA597D909> /Library/Application Support/Adobe/CS5.5ServiceManager/lib/ServiceManager-Launcher.dylib
                                               0x12a384000 -        0x12a38afe7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <87272933-FB21-81D0-00E6-92BC3D7583FB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
                                               0x12de98000 -        0x12dec5ff7 +com.redgiantsoftware.Looks3_AE 1.4.3 (1.4.3) <75EC3A67-4CC3-FB25-B56E-1BE94C2F81FF> /Library/Application Support/Adobe/Common/Plug-ins/CS5.5/MediaCore/MB Looks/Looks3_AE10.plugin/Contents/MacOS/Looks3_AE10
                                               0x12e1c3000 -        0x12e1dbff7 +com.adobe.ExporterMPEGPreview.framework ExporterMPEGPreview version 5.5.0 (5.5.0.0) <EC248166-E8C8-0F6E-8F33-7408514B1754> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEG Preview
                                               0x12e3e4000 -        0x12e732fe7 +com.redgiantsoftware.MBLooksRenderLibCPU 1.4.3 (1.4.3) <007127FB-36B6-BD1D-D363-E5E048BEEA47> /Library/Frameworks/LS3RendererCPU.framework/Versions/A/LS3RendererCPU
                                               0x12e8fe000 -        0x12e90dffd +com.mainconcept.mc_enc_mpa 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_enc_mpa.framework/mc_enc_mpa
                                               0x12e987000 -        0x12eb99fef +com.Redgiant.AfterEffects.MagicBullet.Colorista_II 1.0 (1.0) <E8227557-B3AE-9EBA-339A-8FCA6B2EBF8B> /Library/Application Support/Adobe/Common/Plug-ins/CS5.5/MediaCore/Magic Bullet Colorista/Colorista_II_x64.plugin/Contents/MacOS/Colorista_II_x64
                                               0x12ec0f000 -        0x12ef69ff7 +com.redgiantsoftware.ColoristaRenderer 1.5 (1.5) <0CBFDEEF-B589-5F32-DC3A-5AD7AF38AAEE> /Library/Frameworks/ColoristaRenderer.framework/Versions/A/ColoristaRenderer
                                               0x12f3c0000 -        0x12f4d2fef +com.mainconcept.mc_enc_mp2v 8.6 (8.6.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_enc_mp2v.framework/mc_enc_mp2v
                                               0x12f527000 -        0x12f5fcff3 +com.mainconcept.mc_mux_mp2 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_mux_mp2.framework/mc_mux_mp2
                                               0x130045000 -        0x130046ff7 +com.adobe.PProAEFilter.Bevel_Edges ??? (1.0) <7507D0FD-FD6E-B46C-D738-39FF90D2C472> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/Bevel_Edges
                                               0x130054000 -        0x130055fff +com.adobe.PProAEFilter.Mosaic ??? (1.0) <B5B1AFB7-7947-747D-0352-1D57909982FB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
                                               0x1300b7000 -        0x1300bcfff +com.adobe.PProAEFilter.Twirl ??? (1.0) <CA624D6A-C123-3D23-1DC3-526D125086E3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
                                               0x1300ef000 -        0x1300f3ff7  libFontRegistryUI.dylib ??? (???) <763B8E8F-8602-2096-7CC8-CEE1F4248028> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                                            0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
                                            0x7fff80015000 -     0x7fff80015ff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                            0x7fff800ad000 -     0x7fff80192fef  com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                            0x7fff80193000 -     0x7fff801e2fef  libTIFF.dylib ??? (???) <5DE9F066-9B64-CBE4-976A-CC7B8DD3C31A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                                            0x7fff801e3000 -     0x7fff80208ff7  com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                            0x7fff80209000 -     0x7fff8024cff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                            0x7fff802b5000 -     0x7fff802bcfff  com.apple.OpenDirectory 10.6 (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                            0x7fff8060a000 -     0x7fff8062bfff  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62> /usr/lib/libresolv.9.dylib
                                            0x7fff806c3000 -     0x7fff806d9fef  libbsm.0.dylib ??? (???) <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
                                            0x7fff806da000 -     0x7fff80797fff  com.apple.CoreServices.OSServices 359 (359) <8F509D8D-4C94-9A1C-3A87-5B775D9F6075> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                            0x7fff80a35000 -     0x7fff80a5dfff  com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                            0x7fff80a9d000 -     0x7fff80aa3ff7  com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                            0x7fff80ab8000 -     0x7fff80ac9ff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717> /usr/lib/libz.1.dylib
                                            0x7fff80aca000 -     0x7fff80b6afff  com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                            0x7fff80ba0000 -     0x7fff80ba3ff7  libCoreVMClient.dylib ??? (???) <E03D7C81-A3DA-D44A-A88A-DDBB98AF910B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                            0x7fff80ba4000 -     0x7fff8159eff7  com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                            0x7fff815ab000 -     0x7fff816cafe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
                                            0x7fff816cb000 -     0x7fff81717fff  libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
                                            0x7fff81953000 -     0x7fff81b14fef  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
                                            0x7fff81b15000 -     0x7fff81bc5fff  edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                            0x7fff81bc6000 -     0x7fff81c19ff7  com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                            0x7fff81c1a000 -     0x7fff81c37ff7  libPng.dylib ??? (???) <4815A8F2-24A0-E783-8A5A-7B4959F562D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                                            0x7fff81c38000 -     0x7fff81c74fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A> /usr/lib/libcurl.4.dylib
                                            0x7fff81c75000 -     0x7fff81e33ff7  com.apple.ImageIO.framework 3.0.4 (3.0.4) <6212CA66-7B18-2AED-6AA8-45185F5D9A03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                                            0x7fff81efa000 -     0x7fff81fb3fff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
                                            0x7fff81fe4000 -     0x7fff82025fff  com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                            0x7fff82026000 -     0x7fff82063ff7  libFontRegistry.dylib ??? (???) <4C3293E2-851B-55CE-3BE3-29C425DD5DFF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                            0x7fff82064000 -     0x7fff8206fff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <5CA110A2-0712-F774-E7CF-AA7A2A106DAC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                            0x7fff820d3000 -     0x7fff8211dff7  com.apple.Metadata 10.6.3 (507.15) <2EF19055-D7AE-4D77-E589-7B71B0BC1E59> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                            0x7fff8211e000 -     0x7fff8211eff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                            0x7fff828b4000 -     0x7fff82931fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
                                            0x7fff82948000 -     0x7fff8294afff  com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                            0x7fff8294b000 -     0x7fff82950fff  libGIF.dylib ??? (???) <95443F88-7D4C-1DEE-A323-A70F7A1B4B0F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                                            0x7fff82951000 -     0x7fff8298cfff  com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                            0x7fff8298d000 -     0x7fff82a0bff7  com.apple.CoreText 151.10 (???) <54961997-55D8-DC0F-2634-674E452D5A8E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                                            0x7fff82a0c000 -     0x7fff82b23fef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <1B27AFDD-DF87-2009-170E-C129E1572E8B> /usr/lib/libxml2.2.dylib
                                            0x7fff82b24000 -     0x7fff82b26fff  libRadiance.dylib ??? (???) <76C1B129-6F25-E43C-1498-B1B88B37163B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                                            0x7fff82b51000 -     0x7fff82b66ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                            0x7fff82b82000 -     0x7fff82becfe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                            0x7fff82cee000 -     0x7fff82d21ff7  libTrueTypeScaler.dylib ??? (???) <69D4A213-45D2-196D-7FF8-B52A31DFD329> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                                            0x7fff82d52000 -     0x7fff82e87fff  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <E5D7DBDB-6DDF-E6F9-C71C-86F4520EE5A3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                            0x7fff82e88000 -     0x7fff82ea8ff7  com.apple.DirectoryService.Framework 3.6 (621.11) <AD76C757-6701-BDB5-631E-1CB77D669586> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                                            0x7fff82ea9000 -     0x7fff832edfef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                            0x7fff83558000 -     0x7fff8356cfff  libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                            0x7fff8359d000 -     0x7fff8365efef  com.apple.ColorSync 4.6.6 (4.6.6) <BB2C5813-C61D-3CBA-A8F7-0E59E46EBEE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                            0x7fff836a3000 -     0x7fff836a9ff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                            0x7fff83764000 -     0x7fff837a1ff7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <F743389F-F25A-A77D-4FCA-D6B01AF2EE6D> /usr/lib/libssl.0.9.8.dylib
                                            0x7fff837a2000 -     0x7fff837e3fef  com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                            0x7fff837e4000 -     0x7fff837e8ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                                            0x7fff837e9000 -     0x7fff8386eff7  com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                            0x7fff8386f000 -     0x7fff83870ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <53299948-2554-0F8F-7501-04B34E49F6CF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                            0x7fff83927000 -     0x7fff8393bff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <63C87CF7-56B3-4038-8136-8C26E96AD42F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                            0x7fff8393c000 -     0x7fff83a7afff  com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                            0x7fff83a7b000 -     0x7fff83a88fe7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                            0x7fff83fba000 -     0x7fff83fd3fff  com.apple.CFOpenDirectory 10.6 (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                            0x7fff84023000 -     0x7fff84026ff7  com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                            0x7fff84027000 -     0x7fff8403efff  com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                            0x7fff8403f000 -     0x7fff8409ffe7  com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                            0x7fff84390000 -     0x7fff843abff7  com.apple.openscripting 1.3.1 (???) <2243C17C-EE36-D5B6-3A3E-8258973FF789> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                            0x7fff843f7000 -     0x7fff84491fe7  com.apple.ApplicationServices.ATS 275.16 (???) <4B70A2FC-1902-5F27-5C3B-5C78C283C6EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                            0x7fff84492000 -     0x7fff84492ff7  com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                            0x7fff84493000 -     0x7fff8460afe7  com.apple.CoreFoundation 6.6.5 (550.43) <31A1C118-AD96-0A11-8BDF-BD55B9940EDC> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                            0x7fff84621000 -     0x7fff84d1dff7  com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                            0x7fff84e17000 -     0x7fff84e1cfff  libGFXShared.dylib ??? (???) <1D0D3531-9561-632C-D620-1A8652BEF5BC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                            0x7fff84ef2000 -     0x7fff84ef7ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                            0x7fff84f44000 -     0x7fff851c6fe7  com.apple.Foundation 6.6.7 (751.62) <6F2A5BBF-6990-D561-2928-AD61E94036D9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                            0x7fff851d4000 -     0x7fff85508fef  com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                            0x7fff85622000 -     0x7fff85631fef  com.apple.opengl 1.6.13 (1.6.13) <516098B3-4517-8A55-64BB-195CDAA5334D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                            0x7fff856b0000 -     0x7fff856b6ff7  IOSurface ??? (???) <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                            0x7fff856b7000 -     0x7fff85700fef  libGLU.dylib ??? (???) <1C050088-4AB2-2BC2-62E6-C969F925A945> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                            0x7fff85910000 -     0x7fff85957ff7  com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                            0x7fff85958000 -     0x7fff859d7fe7  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                            0x7fff859d8000 -     0x7fff85aacfe7  com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                                            0x7fff85aad000 -     0x7fff85b02ff7  com.apple.framework.familycontrols 2.0.2 (2020) <F09541B6-5E28-1C01-C1AE-F6A2508670C7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                            0x7fff85b03000 -     0x7fff85b8ffef  SecurityFoundation ??? (???) <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                            0x7fff85b90000 -     0x7fff85b91ff7  com.apple.TrustEvaluationAgent 1.1 (1) <040B71B1-F8BD-1605-057E-E80DBDE1FE59> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                            0x7fff85b92000 -     0x7fff85bc3fff  libGLImage.dylib ??? (???) <7F102A07-E4FB-9F52-B2F6-4E2D2383CA13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                            0x7fff85bc4000 -     0x7fff863cefe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                            0x7fff8645b000 -     0x7fff8647efff  com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                            0x7fff8647f000 -     0x7fff8647fff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                            0x7fff86580000 -     0x7fff86583fff  com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                            0x7fff86584000 -     0x7fff86921fe7  com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                            0x7fff869ba000 -     0x7fff86cb8fff  com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                            0x7fff86cf3000 -     0x7fff86da8fe7  com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                            0x7fff86e38000 -     0x7fff86e4efe7  com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                            0x7fff87e81000 -     0x7fff87e81ff7  com.apple.Carbon 150 (152) <19B37B7B-1594-AD0A-7F14-FA2F85AD7241> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                            0x7fff87ed8000 -     0x7fff87ee6ff7  libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
                                            0x7fff87ee7000 -     0x7fff87ef9fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
                                            0x7fff87f52000 -     0x7fff87f7dff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <8AB4CA9E-435A-33DA-7041-904BA7FA11D5> /usr/lib/libxslt.1.dylib
                                            0x7fff880df000 -     0x7fff881a0fff  libFontParser.dylib ??? (???) <A00BB0A7-E46C-1D07-1391-194745566C7E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                            0x7fff881a1000 -     0x7fff885e8fef  com.apple.RawCamera.bundle 3.7.1 (570) <5AFA87CA-DC3D-F84E-7EA1-6EABA8807766> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                                            0x7fff8875b000 -     0x7fff887a3ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                            0x7fff887a4000 -     0x7fff8885aff7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
                                            0x7fff8885b000 -     0x7fff88a19fff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <4274FC73-A257-3A56-4293-5968F3428854> /usr/lib/libicucore.A.dylib
                                            0x7fff88a1a000 -     0x7fff88a41ff7  libJPEG.dylib ??? (???) <B9AA5816-8CCB-AFCB-61FD-3820C6E8219D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                                            0x7fff88a88000 -     0x7fff88ba2fef  libGLProgrammability.dylib ??? (???) <8A4B86E3-0FA7-8684-2EF2-C5F8079428DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                            0x7fff88ed1000 -     0x7fff88faefff  com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                            0x7fff890e2000 -     0x7fff89172fff  com.apple.SearchKit 1.3.0 (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                            0x7fff89173000 -     0x7fff893fcff7  com.apple.security 6.1.2 (55002) <4419AFFC-DAE7-873E-6A7D-5C9A5A4497A6> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                            0x7fff8957c000 -     0x7fff8957cff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                            0x7fff89656000 -     0x7fff89665fff  com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                            0x7fff89666000 -     0x7fff89666ff7  com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                            0x7fff89667000 -     0x7fff896a4fff  com.apple.LDAPFramework 2.0 (120.1) <16383FF5-0537-6298-73C9-473AEC9C149C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                                            0x7fff896fc000 -     0x7fff896fdfff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
                                            0x7fff897d4000 -     0x7fff897d8ff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
                                            0x7fff897e8000 -     0x7fff89837ff7  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <01B370FB-D524-F660-3826-E85B7F0D85CD> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
                                            0x7fff89838000 -     0x7fff89872fff  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <7982734A-B66B-44AA-DEEC-364D2C10009B> /usr/lib/libcups.2.dylib
                                            0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
                                        Model: iMac10,1, BootROM IM101.00CC.B00, 2 processors, Intel Core 2 Duo, 3.06 GHz, 8 GB, SMC 1.52f9
                                        Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB
                                        Memory Module: global_name
                                        AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.14.6
                                        Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
                                        Network Service: AirPort, AirPort, en1
                                        Serial ATA Device: WDC WD1001FALS-40U9B0, 931.51 GB
                                        Serial ATA Device: HL-DT-ST DVDRW  GA11N
                                        USB Device: Hub, 0x05ac  (Apple Inc.), 0x9136, 0x24300000 / 4
                                        USB Device: LaCie Rugged FW/USB, 0x059f  (LaCie), 0x100c, 0x24310000 / 9
                                        USB Device: Hub, 0x05ac  (Apple Inc.), 0x9137, 0x24340000 / 5
                                        USB Device: Apple LED Cinema Display, 0x05ac  (Apple Inc.), 0x9236, 0x24343000 / 8
                                        USB Device: Display iSight, 0x05ac  (Apple Inc.), 0x8508, 0x24342000 / 7
                                        USB Device: Display Audio, 0x05ac  (Apple Inc.), 0x2912, 0x24341000 / 6
                                        USB Device: little disk (button), 0x059f  (LaCie), 0x1006, 0x24100000 / 3
                                        USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0x24400000 / 2
                                        USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0x26400000 / 3
                                        USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0220, 0x26420000 / 4
                                        USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0x26500000 / 2
                                        USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000 / 2
                                        USB Device: ShuttleXpress, 0x0b33  (Contour Design, Inc.), 0x0020, 0x06200000 / 3
                                        USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
                                        USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0x06110000 / 4
                                        FireWire Device: Mbox 2 Pro, DIGIDESIGN, Up to 400 Mb/sec
                                        FireWire Device: Hard Drive Quadra, LaCie, Up to 800 Mb/sec
                                        • 18. Re: PrPro 5.5 crashing EVERY time.
                                          Jon Chappell Level 3
                                          This crash was caused by Magic Bullet Looks. It's probably better to contact Red Giant about this issue rather than Adobe.
