9 Replies Latest reply on Jul 1, 2011 2:31 PM by flashbuilder_cool
    Error executing CFC. Parameter index out of range (2 > number of parameters, which is 1)
    flashbuilder_cool
      My CFC component is defined as:
      <cffunction name="updateNote" output="false" access="remote"  returntype="void" >
           <cfargument name="notedetails" required="true" type="string" >
           <cfargument name="notename" required="true" type="string" />
           <cfquery name="qupdateNote" datasource="notes_db">
                 UPDATE
                     notes
                 SET
                     notes.notedetails=<CFQUERYPARAM CFSQLTYPE="CF_SQL_VARCHAR" VALUE="#ARGUMENTS.notedetails#">,
                 WHERE
                     notename="<CFQUERYPARAM CFSQLTYPE="CF_SQL_VARCHAR" VALUE="#ARGUMENTS.notename#">"
          </cfquery>
      </cffunction>
      In Flash builder when I test the operation I get this error:
      "There was an error while invoking the operation. Check  your server settings and try invoking the operation again.
      Reason:  Server error Unable to invoke CFC - Error Executing Database Query. Parameter  index out of range (2 > number of parameters, which is 1)."
      Im really quessing that this is something small but right now its causing me to pull my hair out of my head!! Argg. Tried a bunch of things but I know thik im stuck.
      Help would be very very appreciated.
