3 Replies Latest reply on Jun 28, 2011 6:11 PM by NoMan'sLand
    How to avoid the event has been repeated many times in the background
    shotterrss Level 1
      Application, the main screen is divided into two containers:left and  right container,
      The right side of the container is divided into two containers:top and  bottom container,
      There is a button in the left container.
      Click the button, the container at lower right will using ModuleManager  load Module,  The following container load of the right of the screen  has been monitoring the container above the action.
      Problem:
      When you click the button repeatedly to load the container in the lower  right, it will create multiple instances, and can not be freed  immediately. When the above container do an action or event, there are  multiple instances of monitoring exist.
      The background will be repeat the action or event many times.
      How to avoid the event has been repeated many times in the background?
