4 Replies Latest reply on Jun 28, 2011 3:58 AM by Gusgsm
    volltonauszug
    acbraun Level 1
      guten morgen,
      ich habe ein logo in cmyk angelegt. es ist zweifarbig. jetzt möchte der drucker einen volltonauszug haben. was muss ich machen?
      danke für die rückantwort, mfg acb
        • 1. Re: volltonauszug
          Gusgsm Level 2
          1. Would you please post in English —the language of this international forum? That would help everybody to help you with the issue.
          2. You do not say which software you have made your logo with and, then, it would be a good idea posting in the forum devoted to that piece of software.
          Best regards
          Gustavo (Posting from Madrid).
          • 2. Re: volltonauszug
            acbraun Level 1
            Hi and thanks for response,
            I created a logo in illustrator cs4, cmyk modus. the printer would like the information of the spottone, hope I translate correctly,
            greetings, acbraun
            • 3. Re: volltonauszug
              Gusgsm Level 2
              Hello,
              You have defined your color in CMYK but now you want it to be spot colour, right?
              OK, if so:
              1. Create or select a new spot colour swatch. Let's suppose it is Pantone Coated 300 (that is Pantone 300 C).
              2. Selec any instance of the colour used in the document for FILLS (Menu Select - Same - Fill colour). Click the spot colour Pantone 300 C in the swatch palette.
              3. Do the same with the STROKES: (Menu Select - Same - Stroke colour). Click the spot colour Pantone 300 C in the swatch palette.
              4. That should replace the use of the unwanted colour. From then onwards, use the spot colour intne swatches palette.
              5. Use the Illustrator forum to make these questions as they can help you much better than here.
              Best regards,
              Gustavo
              • 4. Re: volltonauszug
                acbraun Level 1
                super. thank you so much!!!!!
