1 Reply Latest reply on Jun 28, 2011 6:31 AM by UbuntuPenguin
    Data Binding Issue
    rabinprithvi Level 2
      To learn more about data binding i just commented the bindable metadata tag in Employee VO class .
      Data Binding is working in case 1 and not in case 2.
      Any suggestion is appreciated.
      Case 1 : Works Fine
      EmployeeVO Class
      /*[Bindable]*/
      public class EmployeeVO
           public var employeeName:String;
           public function EmployeeVO(name:String)
                this.employeeName = name;
      EmployeeView MXML
      [Bindable]
      private var employeeVO:EmployeeVO = new EmployeeVO("John");
      private function changeEmployee():void
           employeeVO = new EmployeeVO("Jack");
      <s:TextInput id="t1" text="{employeeVO.employeeName}" editable="false"/>
      <s:Button label="Change Employee" click="changeEmployee()"/>
      Case 2 : Not Working
      EmployeeVO Class
      /*[Bindable]*/
           public var employeeName:String = "John";
           public function EmployeeVO()
                //empty constructor
      EmployeeView MXML
      [Bindable]
      private var employeeVO:EmployeeVO = new EmployeeVO();
           employeeVO = new EmployeeVO();
           employeeVO.employeeName = "Jack"
      I debuged the application  and came to a conclusion that data binding will occur for the first time even when bindable metadata tag is absent.
      But not thereafter.
      Can someone please throw more light on this.
        • 1. Re: Data Binding Issue
          UbuntuPenguin Level 4
          The property "employeeName" isn't bindable so when you change it from null to something else, the view isn't going to refresh.  In case one, I assume what is happening is that the name of the employee is getting set, then the bindings attached to text field update the view to the property on your object.
          To clarify for yourself, in example one pass "Jack" to the employee constructor, then set the employee name to "Michael" and look at what the view shows.
