14 Replies Latest reply on Nov 15, 2006 12:13 PM by Kronin555
    Simple text field
    atsidi
      I want to call a javascript if User clicks on a button and the text field is empty.
      here is the button and the text field:
      <cfinput type="file" name="custCartFile">
      <cfinput type="submit" name="submit" value="Add Image">
      Trint
        • 1. Re: Simple text field
          Dan Bracuk Level 5
          required="yes" is easier
          • 2. Re: Simple text field
            atsidi Level 1
            I tried that and got "error in submit text"
            Can you give me the exact context?
            • 3. Re: Simple text field
              jdeline Level 1
              You don't have a text field. You have a type="file" and a type="submit".
              • 4. Re: Simple text field
                Dan Bracuk Level 5
                My mistake. You have to check it on your action page.
                form page
                <form action="actionpage.cfm" enctype="multipart/form-data" method="post">
                <input type="file" name="inputFile" size="45">
                action page
                <cfif len(InputFile) is 0>
                no file, write code to handle it
                </cfif>
                • 5. Re: Simple text field
                  atsidi Level 1
                  How do I present the "custCartFile" and "custCartThumb" which are the input file entry boxes?
                  Ok, do I put it like this?
                  <cfif len(custCartFile) is 0>
                  noImage(); <<<this is a java function. displays message to add imagefile
                  </cfif>
                  <cfif len(custCartThumb) is 0>
                  noThumbnail(); <<<this is a java function. displays message to add thumbfile
                  </cfif>
                  • 6. Re: Simple text field
                    atsidi Level 1
                    All I want is for a message box to pop up and remind if no imagefile or thumbnailfile were selected.
                    Trint
                    • 7. Re: Simple text field
                      Kronin555 Level 1
                      Coldfusion runs on the server. Javascript runs on the browser. If you want a popup warning _before_ they submit it, it needs to be written in javascript (both the testing and the popup). If you want them to submit it, then get back a popup, you can do the testing in coldfusion and write the popup in javascript.
                      • 8. Re: Simple text field
                        atsidi Level 1
                        Ok, but I'm new to Coldfusion and don't know the syntax for doing the cfif correctly. I get an error message "custCartFile" not defined when I do this:
                        </cfif
                        How can I use that test correctly (syntax) so that I don't get an error message?
                        Trint
                        • 9. Re: Simple text field
                          Kronin555 Level 1
                          Until the form is submitted, custCartFile isn't defined.
                          Also, noImage() is a Javascript function, not a java function.
                          So, you can do:
                          <cfif isDefined("FORM.custCartFile") and len(custCartFile) is 0>
                          • 10. Re: Simple text field
                            MrBonk Level 1
                            The easiest way is to return the javascript function from the onSubmit event of your form. onSubmit = "return your_function()". That way, when your user clicks your submit button, your script can check whatever you want to check *before* the form is actually submitted.
                            Like this:
                            <script type="text/javascript" language="javascript">
                            function check_file_field()
                            var file_field = document.getElementById("flFileField");
                            if(file_field.value.length == 0)
                            alert("Select a file first!");
                            return false;
                            else
                            return true;
                            </script>
                            <cfform action="#cgi.script_name#" method="post" name="frmTest" preloader="no" onsubmit="return check_file_field()">
                            <cfinput type="file" id="flFileField" name="flFileField">
                            <cfinput type="submit" name="btnSubmit" value="Go">
                            </cfform>
                            • 11. Re: Simple text field
                              atsidi Level 1
                              MrBonk,
                              Since this <cfinput type="file" is already within a <cfform action, I used "onClick="return check_file_field()" at the end of this:
                              <cfinput type="submit" name="submit" value="Add Image" onClick="return check_file_field()">
                              and gives me the message "Select a file first!" whether I select a file or not!
                              Please help.
                              Trint
                              • 12. Re: Simple text field
                                Kronin555 Level 1
                                Did you happen to change the name of the file field that is being checked in the check_file_field() function?
                                • 13. Re: Simple text field
                                  atsidi Level 1
                                  Yes, it looks like this now:
                                  var file_field = document.getElementById("custCartFile");
                                  alert("You are required to select an Image");
                                  return false;
                                  else
                                  return true;
                                  Trint
                                  • 14. Re: Simple text field
                                    Kronin555 Level 1
                                    You need to give the custCartFile input field an id of custCartFile in order for that javascript code to work.
                                    <cfinput type="file" name="custCartFile" id="custCartFile">
                                    it's the id value that the javascript function "document.getElementById()" is checking for.
