My configuration is as follows
- ColdFusion Enterprise 8,0,1,195765
- Windows XP SP3
- built-in webserver on port 8500
- ColdFusion Builder 1.0.0.271911 plug-in
- Eclipse comes from Flash Builder 4.5 standalone installation
I can use the line debugger without error but whenever I add a Watch Expression, I get the following error EVERY time I step over a line.
An internal error occurred during: "com.adobe.rds.eclipse.debugger.expression".
com.adobe.rds.client.eclipse.debugger.core.model.CFMLDebugTarget.getProcessor()Lcom/adobe/rds/services/debugger/DebuggerEventProcessor;
Anyone encountered this or know of a fix/workaroud?
It looks like you're running CFB1 without the update
Checkout http://kb2.adobe.com/cps/846/cpsid_84607.html
If you have Flash Builder 4.5, did you buy this on it's own? As from what I
know if you buy CFB 2 you get FB4.5 Standard as part of the package.
I installed FB4.5 seperately from CFB (installed as a plugin into FB4.5 standalone). I did seperate trial downloads and got the license keys later, hence, no all-in-one CD/DVD.
When I do a check for updates, it tells me that no updates are available. I did have CFB2 installed for a while but I ended up uninstalling it. Chances are good that the CFB1 uninstall, CFB2 install, CFB2 uninstall, CFB1 reinstall is the real source of this problem. I'm thinking of doing a complete gut of everything eclipse related and then starting from scratch with eclipse helios followed by FB4.5 plugin and CBF1 plugin and finally, the updates.
I'll report back after I finish.
Rod
You can install the CF1 Updater as a standalone install:
http://www.adobe.com/support/coldfusion/downloads_updates.html#cfb
