10 Replies Latest reply on Jun 29, 2011 9:54 AM by MSTG2000
    Video Isssue.. large black borders?
    MSTG2000
      hey there folks,
      I just finished a video, saved in WMV format, and made sure it was saved with the actual size as the project media..
      but, I seem to be getting a big black border around the video?
      Resizing the window leaves a sizable margin around my video, and that's not going to look good blown up full size or projected onto a screen.
      any ideas?
        • 1. Re: Video Isssue.. large black borders?
          What is your source video?
          What is your project setting?
          What is your output setting?
          • 2. Re: Video Isssue.. large black borders?
            MSTG2000 Level 1
            in basics, the video being saved is not what's being shown in the preview window.
            preview window has video edge to edge (horizontally) but premiere is adding a big black area on the sides when saving as wmv
            shouldnt the monitor preview be what is being saved?
            • 3. Re: Video Isssue.. large black borders?
              MSTG2000 Level 1
              in the image i uploaded.. the "monitor" preview is what is showing the blue-tinted area.  but premiere is adding the area hilighted in red
              • 4. Re: Video Isssue.. large black borders?
                MSTG2000 Level 1
                saved the video as a FLV and have no issues.. but i want it as a wmv, which has the cropping issue
                • 5. Re: Video Isssue.. large black borders?
                  You still are not providing information
                  If you lay a postcard (your file) on an 8x10 picture frame (your project) you will have a border
                  You still need to describe what you are using
                  Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037?tstart=0
                  What is a CODEC... a Primer http://forums.adobe.com/thread/546811?tstart=0
                  What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037?tstart=0
                  Report back with the codec details of your file, use the programs below
                  For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
                  For Mac http://mediainfo.massanti.com/
                  Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
                  • 6. Re: Video Isssue.. large black borders?
                    MSTG2000 Level 1
                    General
                    Complete name                    : C:\Users\Matt\Desktop\FINAL - please crop the video down.wmv
                    Format                           : Windows Media
                    File size                        : 113 MiB
                    Duration                         : 4mn 0s
                    Overall bit rate mode            : Constant
                    Overall bit rate                 : 3 923 Kbps
                    Maximum Overall bit rate         : 6 659 Kbps
                    Encoded date                     : UTC 2011-06-28 18:56:11.431
                    Video
                    Format                           : VC-1
                    Format profile                   : AP@L3
                    Codec ID                         : WVC1
                    Codec ID/Hint                    : Microsoft
                    Description of the codec         : Windows Media Video 9 Advanced Profile
                    Duration                         : 4mn 0s
                    Bit rate mode                    : Constant
                    Bit rate                         : 6 479 Kbps
                    Width                            : 1 600 pixels
                    Height                           : 900 pixels
                    Display aspect ratio             : 2.35:1
                    Original display aspect ratio    : 16:9
                    Frame rate                       : 25.000 fps
                    Chroma subsampling               : 4:2:0
                    Bit depth                        : 8 bits
                    Scan type                        : Progressive
                    Compression mode                 : Lossy
                    Bits/(Pixel*Frame)               : 0.180
                    Stream size                      : 186 MiB
                    NumberOfFrames                   : 6012
                    Audio
                    Format                           : WMA
                    Format profile                   : Pro
                    Codec ID                         : 162
                    Codec ID/Info                    : Windows Media Audio
                    Description of the codec         : Windows Media Audio 10 Professional - 128 kbps, 44 kHz, 2 channel 16 bit 1-pass CBR
                    Duration                         : 4mn 0s
                    Bit rate                         : 128 Kbps
                    Channel(s)                       : 2 channels
                    Sampling rate                    : 44.1 KHz
                    Bit depth                        : 16 bits
                    Stream size                      : 3.68 MiB (3%)
                    • 7. Re: Video Isssue.. large black borders?
                      MSTG2000 Level 1
                      Project Settings.. I am unable to alter for some reason..
                      DV NTSC
                      29.97 frames/second
                      Frame size: 720 x 480
                      pixed aspect: d1.dv ntsc (0.90911)
                      fields: lower field first
                      display format: 30fps drop-frame
                      • 8. Re: Video Isssue.. large black borders?
                        Video
                        Height                           : 900 pixels
                        Project
                        Your project and video do not match... I also think your file said 25fps (can't see if from this reply screen) and your project is 29.97
                        I'm not sure how you create a custom project (check the help file) but you have what looks like a mismatch
                        • 9. Re: Video Isssue.. large black borders?
                          the_wine_snob Level 9
                          Unfortunately, in PrE, one cannot create a "custom" Preset to match odd footage, like in PrPro, where one can choose the Desktop Preset, and then adjust most parameters.
                          Some have created a few "semi-custom" Presets for PrE, but those do not work for everyone.
                          I have submitted a Feature Request for a Custom/Desktop Preset for PrE, but so far, I have not seen that in PrE. Maybe PrE 10?
                          • 10. Re: Video Isssue.. large black borders?
                            MSTG2000 Level 1
                            OK, after experimenting with settings.. I found that it IS indeed a ratio thing.  Instead of a 16:9 widescreen, I saved in a more traditional, more-square, ratio and the video is now edge-to-edge.. though far too tall for my tastes, with lots of empty space at the top and bottom.. which there was a way to crop top and bottom out
