1. Re: TOC - Check Marks
lizroy Sep 15, 2014 12:07 PM (in response to Dale Whale)Dale, were you ever able to find a way to modify the check marks? I have received a similar request.
2. Re: TOC - Check Marks
Lilybiri Sep 16, 2014 5:24 AM (in response to Dale Whale)That is not possible with the default TOC, sorry. You should have to create a custom one.
3. Re: TOC - Check Marks
lizroy Sep 16, 2014 1:23 PM (in response to Lilybiri)So, I have created a custom TOC. I built it out of an image, click boxes, and text. However, I am now trying to simulate the same functionality as the status flags in the stock TOC. Right now I have the check marks showing up if the user goes through the slides in order, but I can't figure out how to show the check marks if they jump around. For example, if the user has viewed slides 1, 2 and 3, then they jump back to slide 1, the check marks are no longer next to slides 2 and 3 in the custom TOC. Any suggestions on how I could make this happen? Thank you for your help!
4. Re: TOC - Check Marks
Lilybiri Sep 16, 2014 2:09 PM (in response to lizroy)I don't know how you worked it out... have some ideas about a dashboard/menu that could help you, where I explain how to handle not-in-sequence visits. One of them can be found here:
