6 Replies Latest reply on Jun 28, 2011 2:25 PM by mattrichard
    How to catch UncaughtErrors from a loaded SWF?
    mattrichard Level 1
      From the documentation (http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/events/UncaughtEr rorEvent.html), uncaught errors in a child swf should bubble up to the loaderInfo of the top-level swf.  I can't seem to get that behavior to work.  Here's the code for a small sample Flex app:
                        xmlns:mx="library://ns.adobe.com/flex/mx">
           <fx:Script>
                <![CDATA[
                     private function uncaughtErrorHandler(event:Event):void {
                          event.preventDefault();
                          trace("caught error");
                     override protected function createChildren():void {
                          systemManager.loaderInfo.uncaughtErrorEvents.addEventListener(UncaughtErrorEvent.UNCAUGHT_ERROR, uncaughtErrorHandler);
                          super.createChildren();
           </fx:Script>
           <s:SWFLoader source="B.swf" />
      </s:Application>
      B.swf is a blank page compiled in Flash CS5 (targetting AS3 and Flash 10) that throws an ErrorEvent in frame 1 (throw new ErrorEvent(ErrorEvent.ERROR, true, true);).  When I run the app, the error caused in B is not caught.  What am I doing wrong here?
      Matt
        • 1. Re: How to catch UncaughtErrors from a loaded SWF?
          Flex harUI Adobe Employee
          Throw an Error from the main app to be sure your handler works, then throw
          an Error from B (not an ErrorEvent) and see what happens.
          • 2. Re: How to catch UncaughtErrors from a loaded SWF?
            mattrichard Level 1
            Per your sugesstion, I tried throwing an error (throw new Error("A");), and it was not caught either.  Am I registering for the uncaught errors in the wrong way?  I pretty much copied and pasted straight from the documentation.
            • 3. Re: How to catch UncaughtErrors from a loaded SWF?
              Look ok to me.  I assume you threw the error after you installed the
              handler.  Make sure you are on FP 10.1 or later.
              • 4. Re: How to catch UncaughtErrors from a loaded SWF?
                mattrichard Level 1
                According to Capabilities.version, my FP is WIN 10,2,152,26
                Edit: I just updated to 10,3,181,34 and my problem persists.
                Edit2: I have realized that I was stopping my debug run too soon (as soon as the IDE reported the error, I was stopping it).  If I allow the app to continue running after the error occurrs, the in-app error is caught successfully, but the error in B.swf is still not caught.
                Here's the changed source just to rule out the possibility that I did something dumb:
                     <fx:Script>
                          <![CDATA[
                                    trace(Capabilities.version);
                     </fx:Script>
                </s:Application>
                • 5. Re: How to catch UncaughtErrors from a loaded SWF?
                  blazejewicz Level 4
                  Hello,
                  using that page as guide:
                  http://help.adobe.com/en_US/FlashPlatform/beta/reference/actionscript/3/flash/events/Uncau ghtErrorEvent.html#includeExamplesSummary
                  (last sample on where to insert handlers) what about:
                  <s:SWFLoader id="swfLoader" init="swfLoaderInitHandler(event)" source="B.swf"/>
                  and:
                  protected function swfLoaderInitHandler(event:Event):void
                       if(!swfLoader.content) return;
                       swfLoader.content.loaderInfo.uncaughtErrorEvents.addEventListener(UncaughtErrorEvent.UNCAU GHT_ERROR,
                  protected function uncaughtErrorHandler(errorEvent:UncaughtErrorEvent):void
                       if(errorEvent.error is Error)
                            var e:Error = errorEvent.error as Error;
                            // my error is 1009 - it is expected here
                            const NULL_ERROR:uint = 1009;
                            if(e.errorID == NULL_ERROR)
                                 errorEvent.preventDefault();
                                 Alert.show(e.errorID+" "+e.message);
                            // else fall through
                  B is supposed to fail:
                  private var emptyObject:Object = null;
                  public function B()
                       flash.utils.setTimeout(throwErrorNow, 100);
                  protected function throwErrorNow():void
                       emptyObject.numericValue();
                  regards,
                  Peter
                  • 6. Re: How to catch UncaughtErrors from a loaded SWF?
                    mattrichard Level 1
                    Peter, thank you for your post!  I don't understand why the uncaught error is not bubbling up to the parent app's loaderInfo, but registering directly to the loaded SWF's loaderInfo (the loader also worked) fixed our problem.
                    Matt
