0 Replies Latest reply on Jun 29, 2011 7:41 AM by John@Lamma
    MVC coding - apply transitions etc. to UI components
    John@Lamma Level 1
      Hi maybe someone can help
      me to solve this this problem for me.  As I'm quite new to Flex I
      did the tutorials and looked at the code sampels but can not work out
      the code to apply transitions or effects to a UI such as a button or panel that is not stored
      in the main file.
      For example :
      <s:Fade target="{login}"/>
      works fine if the UI components with ID is within the same file.
      However if the UI component is stored in Components.LoginForm.
      I tried  <s:Fade target="{components.LoginForm.login}"/> but had no sucess.
      Looking through all the sample codes did hep to find any sample where the UI component i in a different file and action is somewhere else.
      My particular approach was for a login to a SQL Databases.
      Login state  call to UI  Login panel  - Dispatch event back to Main File
          MainFile   HTTPService  -> call to PHP -> Mysql
                           Login Fail  ->  execute Shake from main File to UI file
                           Login succes -> swithc state and fade Login panel from the UI component.
      thanks for any coding hints.
      John
