5 Replies Latest reply on Jun 29, 2011 11:43 PM by radzmar
    selections from drop down list into list box
    Brad Thurston
      Hello all, I have a ddlist that is filled from xml data. On select I would like selection to appear in the list box. I am not able to figure this out, can somone supply me with some direction.
        • 1. Re: selections from drop down list into list box
          radzmar Adobe Community Professional & MVP
          This simliest way is this script in the change:Event of the dropdown box:
          ListBox1.addItem(xfa.event.newText);
          • 2. Re: selections from drop down list into list box
            Brad Thurston Level 1
            That worked great. On a side note...is there something needed to get the a reset button to remove the data from the list box?
            • 3. Re: selections from drop down list into list box
              To clear the Listbox use:
              ListBox1clearItems();
              • 4. Re: selections from drop down list into list box
                Thanks much for the help. Still not able to clear the list box. Can you verify that I entered correctly?
                <?templateDesigner expand 1?></subform>
                         <field name="ResetButton1" y="82.55mm" x="117.475mm" w="28.575mm" h="6mm" relevant="-print">
                            <?templateDesigner isResetFieldsObject true?>
                            <ui>
                               <button highlight="inverted"/>
                            </ui>
                            <font typeface="Myriad Pro"/>
                            <caption>
                               <value>
                                  <text>Reset Form</text>
                               </value>
                               <para hAlign="center" vAlign="middle"/>
                            </caption>
                            <border hand="right">
                               <?templateDesigner StyleID apbx2?>
                               <edge stroke="raised"/>
                               <fill>
                                  <color value="212,208,200"/>
                               </fill>
                            </border>
                            <bind match="none"/>
                            <event name="event__click" activity="click">
                               <script contentType="application/x-javascript">xfa.host.resetData(); ListBox1.ClearItems();</script>
                            </event>
                         </field>
                • 5. Re: selections from drop down list into list box
                  The correct syntax is clearItems(); not ClearItems();
