2 Replies Latest reply on Jun 29, 2011 12:44 PM by VeenaChezhian
    MXMLC ANT task not including AIR libraries
    VeenaChezhian Level 1
      Hi Guys,
      This is the MXMLC ant task which I am using the compile my test app. If i set the static-link-runtime-shared-libraries="true" , the AIR libraries gets merged into my output swf. But when this attribute is set to false, I dont see the AIR libraries added to my SWF file. As a result when I run the AIR version fo my project, I dont see the application launch right. I have so many RSL in my project and I wanted to have static-link-runtime-shared-libraries="false". Is there a way to have AIR libraries include in my output file and still have this static-link-runtime-shared-libraries="false".
      <mxmlc
          file="${project.name}/src/Test.mxml"
          output="${build.mxmlc.dir}/Test.swf"
           <load-config filename="${air.config}"/>
           <source-path path-element="${project.name}/src" />
           <source-path path-element="${flex.frameworks.dir}/libs/air"/>
          <runtime-shared-library-path path-element="${flex.frameworks.dir}/libs/framework.swc">
                      <url rsl-url="${rsl.dir}/framework_3.2.0.3958.swz"/>
                      <url rsl-url="${rsl.dir}/framework_3.2.0.3958.swf"/>
          </runtime-shared-library-path>
          <runtime-shared-library-path path-element="${flex.frameworks.dir}/libs/datavisualization.swc">
                      <url rsl-url="${rsl.dir}/datavisualization_3.2.0.3958.swf"/>
         </mxmlc>
      My RSL are compiled using COMPC task and the AIR libraries are included into them using the below attributes of compc task.
      <source-path path-element="${basedir}/src" />
      <source-path path-element="${flex.frameworks.dir}/projects/airframework/src" />
      <source-path path-element="${flex.frameworks.dir}/projects/air/ServiceMonitor/src" />
      I am really stuck with this problem and not able to get my release build launch right. Again, any light on this problem will be of great help.!
        • 1. Re: MXMLC ANT task not including AIR libraries
              <mxmlc
              </mxmlc>
          This also seems to work. AIR libraries are included in my output SWF. It all happens right when I have static-link-runtime-shared-libraries="true" . Why? Why does that not work when i have static-link-runtime-shared-libraries="false"  ??
          • 2. Re: MXMLC ANT task not including AIR libraries
            BTW, I am on Flex 3.2 SDK
