7 Replies Latest reply on Dec 29, 2015 3:57 AM by pipiludaship6126065
    [VBA] Runtime Error 35869 when trying to relink image
    Cookie4ddict
      Hi Folks!
      I'm opening an indesign document and searching for an existing image. I know the link of the image is index number 9. After finding the image I try to relink it. Every time I tried I got the same Runtime error which tells me, the ressource can't be created with the given URI.
      Here you can see my testing code:
      Option Explicit
      Dim myIndesign As InDesign.Application
      Dim myDocument As InDesign.Document
      ' Starts InDesign and opens document
      Function IndesignStartup()
          Set myIndesign = CreateObject("InDesign.Application")
          Set myDocument = myIndesign.Open(ActiveWorkbook.Path + "/20102127_8439_Risiko_analyseXL.indd")
          ChangeMasterSpreads
      End Function
      ' Changes adress on master spread
      ' and image on next master spread
      Function ChangeMasterSpreads()
          Dim myMasterPage As InDesign.MasterSpread
          Dim textFrames As InDesign.textFrames
          Dim textFrame As InDesign.textFrame
          Dim imageMasterPage As InDesign.MasterSpread
          Dim imageLink As Link
          Set myMasterPage = myDocument.MasterSpreads.FirstItem
          Set textFrames = myMasterPage.textFrames
          Set textFrame = textFrames.Item("adress")
          textFrame.contents = "Test for replacing adress"
          Set imageLink = myDocument.Links.Item(9)
          MsgBox (ActiveWorkbook.Path + "\lauterbach.jpg")
           imageLink.Relink (ActiveWorkbook.Path + "\lauterbach.jpg")
          imageLink.Update
      End Function
      Thanks for trying to help me!
      With kind regards,
      Steffi
