8 Replies Latest reply on Jul 4, 2011 12:16 AM by Abhay_flex
    Problem with mx:repeater
    Abhay_flex
      I am not able to get repeater to work. I have a flex mobile application where in I have created a view component. In this view component, I have to use repeater for dynamic radio button list. I have defined mx namespace ( see below ) but it is not prompting the repeater component when I start typing <mx:
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      overlayControls="false" title="Title" initialize="initData()">
      <fx:Declarations>
      <s:RadioButtonGroup id="radiogroup1"/>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      // Initialize initDG ArrayCollection variable from the ArrayCollection.
      public function initData():void {
      </fx:Script>
      <s:VGroup x="305" y="164" width="402" height="202" gap="10" paddingLeft="20" paddingTop="20">
      <s:RadioButton width="140" label="Button 1" groupName="radiogroup1"/>
      <s:RadioButton width="151" label="Button 2" groupName="radiogroup1"/>
      </s:VGroup>
      </s:View>
      I also tried to use the repeater in actionscript, even there, I am not seeing mx.core.Repeater.  Is that a library version issue ?
        • 1. Re: Problem with mx:repeater
          Karl_Sigiscar_1971 Level 3
          You can use the SkinnableDataContainer, specify and itemRenderer and set the autoDrawBackground property to true or false in your renderer.
          • 2. Re: Problem with mx:repeater
            Abhay_flex Level 1
            Do you have an example / smaple code  ?   also is this an alternative to using Repeater ?
            • 3. Re: Problem with mx:repeater
              Yes, this is an alternative.
              Using <mx:Repeater> was already not best practice in Flex 3. It was best using <mx:List> for performance reasons. You had to use <mx:Repeater> only if you wanted to get rid of the background color in item renderers, but this is now possible with the new autoDrawBackground item renderer property.
              <s:SkinnableDataContainer itemRenderer="com.mycompany.MyItemRenderer">
                  <s:layout><s:VerticalLayout horizontalAlign="center"/></s:layout>
                  <s:ArrayCollection>
                      <fx:Object firstName="Deepa" lastName="Subramaniam" phoneNumber="415-555-1111" />
                      <fx:Object firstName="Glenn" lastName="Ruehle" phoneNumber="415-555-2222" />
                      <fx:Object firstName="Ely" lastName="Greenfield" phoneNumber="415-555-3333" />
                      <fx:Object firstName="Alex" lastName="Harui" phoneNumber="415-555-4444" />
                      <fx:Object firstName="Ryan" lastName="Frishberg" phoneNumber="415-555-5555" />
                  </s:ArrayCollection>
              </s:SkinnableDataContainer>
              MyItemRenderer.mxml
              <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                  height="20"
                                  autoDrawBackground="false">
                   <fx:Script>
                        <![CDATA[
                             import com.
              mycompany.EmbeddedAssets;
                   </fx:Script>
                   <s:layout>
                        <s:HorizontalLayout />
                   </s:layout>
                   <s:BitmapImage source="{data.source}"/>
                   <s:Spacer width="10" />
                   <s:Label text="{data.label}"/>
              </s:ItemRenderer>
              • 4. Re: Problem with mx:repeater
                Another alternative is DataGroup:
                <s:DataGroup itemRenderer=...>
                    <s:dataProvider>
                        <mx:ArrayList>
                            <s:Button/>
                            <s:Button/>
                            <s:Button/>
                        </mx:ArrayList>
                    </s:dataProvider>
                </s:DataGroup>
                • 5. Re: Problem with mx:repeater
                  Abhay_flex Level 1
                  oK..THNX ..Let me try that out.  btw, how do I get the itemrenderer to display a radio button in the radiobutton group ?
                  I am not able to get this to work : here is my code-
                  application mxml
                  <s:ArrayCollection id="rad">
                  <s:source>
                  <fx:Object label="Sub Feature 1" data="f1"/>
                  <fx:Object label="Sub Feature 2" data="f2"/>
                  <fx:Object label="Sub Feature 3" data="f3"/>
                  <fx:Object label="Sub Feature 4" data="f4"/>
                  <fx:Object label="Sub Feature 5" data="f5"/>
                  <fx:Object label="Sub Feature 6" data="f6"/>
                  </s:source>
                  <s:DataGroup id="sfList" x="305" y="168" width="402" height="209" itemRenderer="MyItemRenderer1" dataProvider="{rad}">
                  </s:DataGroup>
                  MyItemRenderer1.mxml
                  height="20"
                  <s:layout>
                  <s:BasicLayout/>
                  </s:layout>
                  <s:RadioButton value="{data.label}" groupName="radiogroup1"/>
                  </s:ItemRenderer>
                  It shows me only 1 radio button with no label
                  • 6. Re: Problem with mx:repeater
                    Abhay_flex Level 1
                    I was able to get it to work using s:SkinnableDataContainer
                    application
                    <s:source>
                    <fx:Object label="Sub Feature 1" grp="radiogroup1"/>
                    <fx:Object label="Sub Feature 2" grp="radiogroup1"/>
                    <fx:Object label="Sub Feature 3" grp="radiogroup1"/>
                    <fx:Object label="Sub Feature 4" grp="radiogroup1"/>
                    </s:source>
                    <s:SkinnableDataContainer id="sfList" x="305" y="168" width="402" height="209" itemRenderer="MyItemRenderer1" dataProvider="{rad}"/>
                    item renderer
                    <s:RadioButton label="{data.label}" groupName="radiogroup1"/>
                    But all the radio buttons are not part of same group evenif I am providing same groupname in the item renderer. Why could that be ?
                    • 8. Re: Problem with mx:repeater
                      Abhay_flex Level 1
                      Yep ! Exactly what I was looking for.  Thanks.
                      In my dataprovider, I was setting groupname as a value, and a reference was what I needed.
                      so
                      <fx:Object val="One" gr="{radiogroup1}" />
                      instead of
                      <fx:Object val="One" gr="radiogroup1" />
