0 Replies Latest reply on Jun 30, 2011 4:19 AM by vaishali.shah
    Help needed with datagrid used as a tooltip
    vaishali.shah
      I am showing a datagrid as a tooltip. The code for the same is given at the following location
      http://www.jusfortechies.com/flex/datagrid_tooltip.php
      The problem i am facing is the my vertical scroll policy is set to true. Since the tooltip is not fixed i cannot scroll down the items in the datagrid. I need to fix the position of the tooltip.
      ToolTipManager.createTooltip helps you to create a tooltip and fix it position by setting the x and y coordinate but this method takes only String as an argument and i have a datagrid.
      Can some one please help out.
      Regards,
      Vaishali
