1 Reply Latest reply on Jun 30, 2011 4:34 AM by [Jongware]
    image/text position in text frame
      i am using textframe for placing images and also the text.
      whn i place the text/ images by default the images are aligned to the top of the text frame, i need to set it to bottom of the textframe.
      is there any possible setting for the actuive document/ app so that by default the contents should be aligned to the bottom
        • 1. Re: image/text position in text frame
          Look in the object that defines vertical positioning: textFramePreferences, and you will see that it has both Document and Application as possible parents.
          app.activeDocument.textFramePreferences.verticalJustification = VerticalJustification.BOTTOM_ALIGN;
          will set the default for new text frames to bottom. You can also use
          app.textFramePreferences.verticalJustification = VerticalJustification.BOTTOM_ALIGN;
          to set it as a global preference for all of your new documents, but somehow that sounds like a Bad Idea.
