10 Replies Latest reply on Aug 12, 2011 3:00 AM by aimaob
    Embedded font does not show up on Android
    aimaob
      I am using CS5.5 and have added the following to my class:
      [Embed(source = "C:\\Windows\\fonts\\Kinds_Plain.ttf", fontFamily = "KidsPlain", embedAsCFF = "false")]
      It works when running on the desktop.  The text typed is in this font.  But when I packaged and installed the app on my Android device, the text typed is changed to the default font.
      Any help is appreciated!
      Thanks in advance,
      aimaob
        • 1. Re: Embedded font does not show up on Android
          relaxatraja Level 5
          C:\\Windows\\fonts\\Kinds_Plain.ttf  Is this the same path you used to show on android?
          use just like:
          [Embed(source = "Kinds_Plain.ttf", fontFamily = "KidsPlain", embedAsCFF = "false")]
          and attach the file with the swf while packaging.
          • 2. Re: Embedded font does not show up on Android
            aimaob Level 1
            Thanks for you reply!
            I have tried it and packaged the font together with the rest of the files.  It still does not work.
            The library class file with the Embed statement is under a directory com/directory/directory and I have put the font file in the same directory of this class file.  The main class file resides in another directory.  In my main class file, I use the import statement to import the library class file.
            Compilation is fine and the font shows up when running on the desktop.  Somehow, it still does not work on Android.  Is there something I am missing?  Should all files reside in the same directory in order for it to work?
            • 3. Re: Embedded font does not show up on Android
              relaxatraja Level 5
              Are you publishing with flash cs5.5 then embed your font within your flash file.
              • 4. Re: Embedded font does not show up on Android
                aimaob Level 1
                Oops!  I forgot to embed it in CS5.5.
                I also created a class "Kids" (Text -> Font Embedding -> ActionScript),  and removed the Embed statement from the code.
                I write the following code to set up the messageArea:
                private var kidsPlainFont:Font = new Kids();
                private var textFormat:TextFormat;
                private var messageArea:TextField;
                textFormat = new TextFormat();
                textFormat.font = kidsPlainFont.fontName;
                messageArea.defaultTextFormat = textFormat;
                addChild(messageArea);
                Again, it works on the desktop but does not work on the Android device.  What am I missing?
                • 5. Re: Embedded font does not show up on Android
                  Joe ... Ward Level 4
                  When you input text in a text field, the runtime positions a native text input control over the Flash TextField object. Since native controls can't use embedded fonts, the closest system font is used. On Android (but not iOS) you can use TLF to create a text input control that is entirely drawn in Flash and thus can use embedded fonts during input. (I'm not sure if the Flex components support this on mobile, though, so you might still have to make your own if using Flex.)
                  • 6. Re: Embedded font does not show up on Android
                    aimaob Level 1
                    Yes, this looks like this is the problem.  I created a TLFTextField and ran into another problem and have posted my message on Action Script 3 Discussions which I think this problem is more relevant to AS3 in general.
                    • 7. Re: Embedded font does not show up on Android
                      aimaob Level 1
                      I have written the following test program to use TLFTextField:
                      import fl.text.TLFTextField;
                      import flashx.textLayout.formats.TextLayoutFormat;
                      import flashx.textLayout.elements.TextFlow;
                      [Embed(source = "Kids_Plain.ttf", fontFamily = "Kids", embedAsCFF = "false")]
                      var kids:Class;
                      var myFormat:TextLayoutFormat = new TextLayoutFormat();
                      myFormat.fontFamily = "Kids";
                      myFormat.fontSize = 24;
                      var tlfTextField:TLFTextField = new TLFTextField();
                      tlfTextField.x = 50;
                      tlfTextField.y = 50;
                      tlfTextField.width = 200;
                      addChild(tlfTextField);
                      var myTextFlow:TextFlow = tlfTextField.textFlow;
                      myTextFlow.hostFormat = myFormat;
                      myTextFlow.flowComposer.updateAllControllers();
                      tlfTextField.appendText("Testing this");
                      I am using CS5.5, have added the Flex library path, and chosen "Merge into code".
                      It runs perfectly on the desktop, but not on the Android.  I have already included the Kids_Plain.ttf file in the apk.  The text shows but the font is the system default font.
                      • 8. Re: Embedded font does not show up on Android
                        aimaob Level 1
                        Finally got it working with FontDescription.  The code is as follows:
                        import flash.text.engine.FontDescription;
                        import flash.text.engine.ElementFormat;
                        import flash.text.engine.TextBlock;
                        import flash.text.engine.TextElement;
                        import flash.text.engine.TextLine;
                        [Embed(source = "Kids_Plain.ttf", fontFamily = "Kids", embedAsCFF="true")]
                        var Kids:Class;
                        var fd:FontDescription = new FontDescription();
                        fd.fontLookup = flash.text.engine.FontLookup.EMBEDDED_CFF;
                        fd.fontName = "Kids";
                        var elementFormat:ElementFormat = new ElementFormat(fd);
                        var string:String = "This is a test";
                        var textBlock:TextBlock = new TextBlock();
                        var textElement:TextElement = new TextElement(string, elementFormat);
                        textBlock.content = textElement;
                        var line:TextLine = textBlock.createTextLine(null, 100);
                        line.x = 50;
                        line.y = 50;
                        addChild(line);
                        • 10. Re: Embedded font does not show up on Android
                          aimaob Level 1
                          It works on AIR2.6 running Android, but not AIR2.5.  Better open a new post since this question is tagged as answerd.
