35 Replies Latest reply on Jun 10, 2018 5:26 AM by derekb1039
    Error when saving audio file
    tacocorp Level 1
      I am having an issue when trying to save an audio file.  Looking for some help on what might be causing the problem.  With the audio file highlighted, I select Save As and title the file.  When I hit OK, this error comes up..The file is in use by another application and cannot be overwritten.  I am saving the file name as something new so it is not trying to overwrite a file with the same name.  Also there is not another Audition opened in the background or any other programs that could cause "another application" error.  Thanks for your help.
        • 1. Re: Error when saving audio file
          Charles VW Adobe Employee
          Hi TacoCorp,
          Can you post more information?   What's posted isn't enough info.
          What OS are you on, what type of drive are you saving to (local, FW, USB, network, etc), what file type are you trying to save as, are you able to save a Session file to that location?
          thx.
          • 2. Re: Error when saving audio file
            tacocorp Level 1
            Sorry about that.  I am using Windows 7.  I am trying to saving the file to a drive on the local network saving as a .wav.  I am occasionally able to save a file to that location but it seems like it will only save after the computer has been restarted and the first file is fine.  After that, the error comes up.
            • 3. Re: Error when saving audio file
              Thanks for the added info.   I ask because we're tracking a similar issue that was reported through the normal tech support channels.
              Please let us know if any of the following apply to you (I understand if any of this doesn't make sense or if you don't have access to the information)
              1. File length doesn't make a difference (try save a file of only a few samples)
              2. You have not had this issue with Adobe Audition 2.0 and Cool Edit Professional 2000, it has never worked in Audition CS5.5
              3. You can save the file to the local workstation drive and then copy it using Windows Explorer to the network share with no issues.
              4. You are using Windows Storage Server 2003 in a Raid 10 array for your storage server.
              5. Active Directory and the workstations have the proper permissions to read and write to the network shares.
              6. The workstations running Adobe Audition CS5.5 are running Windows 7 Profession 32bit and have Active Directory Login
              7. You are able to save to the local drive and copy the file to the same network share via Windows Explorer
              8. Toggling the saving of Metadata and Markers doesn't make a difference
              9. You are able to save as other formats (try AIFF, MP3, and a SESX session)
              10. Running Audition as Administrator makes no difference
              11. Running Audition in XP compatibility mode makes no difference
              12. Turning off the writing of .pkf files doesn't make a difference
              Also, if you're able to do so, try installing "Unlocker" (http://www.filehippo.com/download_unlocker/) to see what app is reported to still be holding on to the file.
              • 4. Re: Error when saving audio file
                tacocorp Level 1
                Thank you for the reply.  Here is what I determined.  Sorry I couldn't answer all your questions.  I'm don't know everything about computers and networks, just enough to be dangerous.
                File length doesn't make a difference (try save a file of only a few samples) I tried record length of a few seconds to five minutes and it happens on all different file lengths.
                You have not had this issue with Adobe Audition 2.0 and Cool Edit Professional 2000, it has never worked in Audition CS5.5 We have one computer that has Audition 2.0 and have no problems with that.  Previously used CoolEdit and no problems with that either.
                You  can save the file to the local workstation drive and then copy it using  Windows Explorer to the network share with no issues.  Saving to the local computers hard drive works everytime and then I am able to copy that file to the desired network drive.
                You are using Windows Storage Server 2003 in a Raid 10 array for your storage server. Sorry do not know
                Active Directory and the workstations have the proper permissions to read and write to the network shares.  Yes
                The workstations running Adobe Audition CS5.5 are running Windows 7 Profession 32bit and have Active Directory Login.  Yes.  They are Windows 7 32 bit.  Not sure about Active Directory Login
                You are able to save to the local drive and copy the file to the same network share via Windows Explorer.  Yes
                Toggling the saving of Metadata and Markers doesn't make a difference.  Sorry do not know
                You are able to save as other formats (try AIFF, MP3, and a SESX session). Able to save MP3's to the notwork drive.  only .wav are having issues
                Running Audition as Administrator makes no difference.  No difference
                Running Audition in XP compatibility mode makes no difference.  Tried that and still had same issues
                Turning off the writing of .pkf files doesn't make a difference.  Sorry not sure how to do that
                I hope this helps and I apologize for not being able to answer all your questions.
                Best regards
                • 5. Re: Error when saving audio file
                  Thanks for all the information, unfortunately, I didn't see any magic bullets in the responses.  Did you get a chance to try this:
                  • 6. Re: Error when saving audio file
                    Right-click on My Computer, and you'll see a screen that looks like this:
                    Go ahead and take a screenshot of that and post (you can private msg it to me if you prefer).
                    You can toggle this option in the Save As Dialog:
                    This is in Preferences > Media & Disk Cache:
                    • 7. Re: Error when saving audio file
                      phillocascio
                      Charles
                      I am having this issue as well with the AU5.5 and Windows 7. One of the tech support guys helped me with my ticket, and asked me to do all of the above as well, it does not fix the issue. The worst part is, it is completely random. I am saving a mixdown file (defaulted to .WAV unless you can tell me how to change that). I want the mixdown saved as an MP3. Sometimes to the same directory, sometimes not. All on a laptop local hard drive. Completely random. Sometimes it saves without an error, sometimes not.
                      • 8. Re: Error when saving audio file
                        Admiral Cook Level 1
                        I'm having the same problem with Save Selection As, but not always.
                        By repeating save steps it goes fine.
                        There are no any rules on when it happens. I'm usually working with WAVs, different lengths, saving to local disk, using Win7x64, latest Audition.
                        • 9. Re: Error when saving audio file
                          Fa310tx Level 1
                          Same problem, here...
                          It happens with regular File - Save As and batch.
                          I can turn right around and delete the files with windows explorer and resave and it usually works.
                          I'm also using windows 7 pro (32-bit) in an active directory environment (saving .wav over network - saving local worked every time).
                          Interestingly enough, I saved 3 mixdowns and had problems with 2 of them.  I opened unlocker and haven't had a problem with like 8 in a row.
                          I blame windows 7 (I've found multiple network file problems with windows 7), but I haven't had the problem with AA3.
                          JJ
                          • 10. Re: Error when saving audio file
                            SteveG(AudioMasters) Adobe Community Professional
                            Fa310tx wrote:
                            I blame windows 7
                            Well, I run CS5.5 on XP. And no, I've never had any of these problems at all. So my money says you're right...
                            As far as my experience of W7 in general is concerned, so far all I've found out is that it messes with a load of stuff that it has absolutely no right to. How anybody at all can use it with an internal (integrated) sound device is a complete mystery to me - there have been so many posts about this now that I lost count ages ago. Seems that the only way to run it is with an external ASIO device, and then you still seem to be left with all these file-save anomalies.
                            My guess is that this is all to do with parameters being passed to the OS, and the OS either not recieving them, or ignoring them, depending on... well your guess is as good as mine, quite frankly. And people say it's random; well what a pain. Random faults are about the hardest there are to pin down.
                            • 11. Re: Error when saving audio file
                              _durin_ Adobe Employee
                              Hi Phil,
                              Most of the posters on this thread are experiencing this issue when saving to a network drive.  This is the first report I've heard of this sort of issue when saving on the local hard drive.  Can you provide a screenshot or the specific error message you're receiving?
                              In order to save a mixdown to a specific file format, view the mixdown in the Waveform view, then select File > Save As...  In the dialog that pops up, you can select MP3 by clicking the button to the right of the Format: box.
                              • 12. Re: Error when saving audio file
                                I do, too, but there may be a way for Audition to catch this problem and work around it.  Except for Phil, it seems most users who have reported this problem in the forums and directly through tech support or e-mail have been attempting to save to an location on an Active Directory Windows network on Windows 7.  (Has anyone experienced this on Windows Vista?)
                                Since it's intermittent and random, AND at least one of you has noted that the problem hasn't appeared since running unlocker - a tool that interferes with the standard process and may be prevent or reduce possible race conditions that cause this - it seems likely we can trace this using the Windows debugger tools IF we can reproduce the problem.  So far, I haven't had any luck but I may just need to setup a private Active Directory-based network that I have absolute control over.
                                • 13. Re: Error when saving audio file
                                  phillocascio Level 1
                                  Durin
                                  Here is the screen shot. Occasionally there is another error that contains the phrase "or the disk is full" which makes no sense. It's got plenty of space on it.
                                  I discussed the case this morning with Mohit and we created another admistrator log-in. The issue did not repeat itself, as I tested mixdowns with this new login. However this weekend would be the real test of it.
                                  Phil
                                  • 14. Re: Error when saving audio file
                                    Thanks, Phil.  I look forward to hearing your results over the weekend - it should provide some guidance on tracking this down internally.  I won't have a chance to dig into it too much until next week, but will keep you all up to date on what we find.
                                    • 15. Re: Error when saving audio file
                                      Durin
                                      I am still having problems, even after tech support suggested trying logging on as a different user. I did that, and the problem has been appearing when trying to save files, "save as" command when trying to save bits of a file, and "save selection as" command. New errors have appeared as well. I am attaching three errors. This is getting very frustrating.
                                      • 16. Re: Error when saving audio file
                                        Thanks, Phil.  I'm spending this week digging into this issue exclusively.  So far, I have not had the problem but will be tackling it from different angles.
                                        The different error messages you've provided are helpful.  Just so I'm clear, you receive these errors at completely different times, correct?  They didn't come up one-after-the-other as part of the same failed Save attempt?
                                        For others who experience this issue, are you also running Win7 or Vista?  I don't believe I've received any reports of this occurring under XP, which is helpful.
                                        I'll be back with new questions.  Thanks again for your persistence and help.
                                        Durin
                                        • 17. Re: Error when saving audio file
                                          Durin
                                          *I'm running the program on Windows 7 on a brand new laptop
                                          *The error messages usually happen when I'm trying to save a file after
                                          I've changed it, or saving a mixdown. Either saving it as a .wav or
                                          mp3, doesn't matter.
                                          *In every case, the error message appears sometimes 1,2,3 or more times in
                                          a row.
                                          *However, I can always save the file the way I want it, if I keep trying to
                                          save it enough times. Eventually, the error message goes away and I can
                                          save the file.
                                          *Sometimes, I dont get an error message.
                                          *I can save 2 files in a row with no problem, then the message will appear
                                          for the next 4 files.
                                          *I've tried saving the file to a different folder,, even the desktop. That
                                          doesnt solve it either.
                                          Let me know if you have any more questions, I'd be happy to help....
                                          Phil LoCascio
                                          Colts Neck, NJ
                                          phillocascio@gmail.com
                                          (301) 332-7220 c
                                          http://www.linkedin.com/pub/phil-locascio/7/762/9a3
                                          • 18. Re: Error when saving audio file
                                            TheJackAttack Level 1
                                            I wonder how much ram is on these systems or whether the disk cache is set to some non audio external drive.
                                            • 19. Re: Error when saving audio file
                                              Durin
                                              Thanks for your help on this. Back in town so I can help you with info on
                                              laptop.
                                              The error messages are sometimes one after the other, sometimes different,
                                              some the same. Completely random. But I can always save the file after a
                                              certain number of tries. Sometimes it saves it without error, sometimes it
                                              takes 6 times!
                                              The error (when it happens) always happens when saving either the session,
                                              or a file that has been edited. Usually I need to convert mixdowns from wav
                                              to mp3 and thats when it happens. Also sometimes when editing and saving an
                                              mp3 by itself.
                                              The laptop is running Win 7, a Toshiba satellite C655-S5212 Hard Drive
                                              Toshiba MK3275GSX with 8GB RAM. I'd be happy to share desktop if you need
                                              to poke around.
                                              Phil LoCascio
                                              Colts Neck, NJ
                                              (301) 332-7220 c
                                              • 20. Re: Error when saving audio file
                                                Wanted to follow-up on the issues reported in this thread.
                                                There are two different issues being reported, with similar symptoms but slightly different causes.  In general, when writing to audio files, Audition first writes the audio data and closes the file, instructing a separate library to store the metadata.  This library re-opens the file, writes the correct metadata blob for the file type, then closes the file once more.  When systems or network shares have an automated synchronization or backup service, there may be timing collisions where the backup process starts before the metadata library has finished its operation, resulting in a write failure.
                                                Write Failure when saving over Windows Active Directory Shared Folder
                                                This issue appears to be introduced with changes in Windows Vista/7 network sharing AND changes in Audition's writing of metadata to files.  We have introduced a fix for CS 6 that should prevent this problem from occurring, but IT administrators may be able to minimize this risk for other applications which may open and close a file multiple times by reducing the delay between recognition of a write/save operation and initiation of the sync process.
                                                Write failure when saving to a local drive
                                                We easily reproduced this problem with Safe Copy Backup, but I suspect other synchronization services like DropBox might be affected as well.  Many of these tools offer a variable preference to allow some delay before synchronizing files, which would solve the problem with the appropriate value.  You may also want to ensure you save to a non-monitored location, or disable the writing of metadata when exporting.
                                                We will investigate the possibility of writing audio data and metadata in the same operation, which should minimize or prevent this problem from occuring, although I'm doubtful this solution would be completed for CS 6.
                                                Thanks for everyones help in troubleshooting this.  It was a tough one to track down, but it's very satisfying to have solved the mystery.
                                                Durin
                                                • 21. Re: Error when saving audio file
                                                  Mark49883
                                                  Is there a solution to this? I have spent hours editing 24 tracks of WAV files, and when I go to save every file gets "file in use" error. This is saving to an external USB drive from Windows 7. I have DropBox installed, but it is not monitoring that drive at all, much less the directory. I also stopped DropBox and tried to save again... same problem.
                                                  This is a huge bug... how can I save my modified WAV files??
                                                  • 22. Re: Error when saving audio file
                                                    dib pwnt
                                                    I'm not completely sure if I am having the same problem as the rest of the fellas. I have Audition version 5.5 (6 if you prefer) and some files will save all the way to 99% and stop. This creates a seperate file with a "~$" tag at the front of it. I have to use the task manager to shut down audition because it would sit there forever otherwise. I normally work with wav files. For some reason these files will not be deleted no matter what I do. The even crash my explorer.exe.. File lengths are generally an hour long. *Edit Some of the files, not all, have at least 300 cue markers in them at one point.
                                                    I AM on Windows 7 like most of the gents here. 64 bit. Quad-core processor, 12 gb of ram.
                                                    I have a sneaking suspicion that this is a windows 7/my IT departments fault. Anyone but Adobes. I love Audition... Just wish I could save my work proper.
                                                    • 23. Re: Error when saving audio file
                                                      It does sound like another process is preventing the file from being completely written.  As a quick test, does this happen if you uncheck the "Save markers and metadata" option in the save dialog?  If so, look for any automate backup or sync services as these often grab a file the instant it is closed by an app, even if the app is technically not finished with it.
                                                      • 24. Re: Error when saving audio file
                                                        Fa310tx Level 1
                                                        I will say that I haven't had the problem since I've stopped using "Save markers and metadata".
                                                        Pretty much the only time I actually want to save that stuff is if it's a sesx.
                                                        JJ
                                                        • 25. Re: Error when saving audio file
                                                          dib pwnt Level 1
                                                          I just tried to save without using "Save markers and metadata" checked. Still froze at 99%. I was hoping that would solve my problem, but alas, its never that easy... This is frustrating.
                                                          *Edit
                                                          I have two hard drives in my computer. I'm thinking im going to move the audio I'm working on to the C drive and see if I have any problems with it then. I'm also contemplating unchecking "Add marker changes to undo history" (even though I love that function) to see if the problem persists even still.
                                                          • 26. Re: Error when saving audio file
                                                            I had this problem for a while under XP when the secondary drive started to go bad.  The SATA chip would be intermittant and cause the hang.  Once I changed the destination drive to a different firewire drive the problem stopped.  I salvaged the drive and scrapped the enclosure.  I have not been able to replicate the issue on my x64 Win7 machines but I do not have automated backup on the network either.
                                                            • 27. Re: Error when saving audio file
                                                              Mark000111222
                                                              OK folks, it has been a year and a half since this was first reported... is there a fix for Audition? I cannot (ever) save WAV files to my external USB 1TB disk drive... goes to 99% done, then "The file is in use by another application and cannot be overwritten". Does not matter if I choose to save metadata or not, same problem. Every other app I have works fine with this external drive.
                                                              Windows 7 SP1 Home Premium, 64 bit
                                                              Audition CS5.5 "Version 4.0 build 1815"
                                                              • 28. Re: Error when saving audio file
        GrizzlyAK Level 1
        Durin/Charles,
        I'm having a similar problem in Au CS6. In my case, I have one or more clips edited together on a work track that I then mixdown to a new (slef-consistent) file (which opens in Editor). I then Save As that file to a new file name (such as ADR_01.wav), and then back in Multitrack, drag that new file from the Files panel onto another (dialog) track on my timeline. After editing all the individual pieces for each 'shot', and creating an ADR_xx.wav file for that particular shot, I then have a single file for each shot that I edit together on a single track synced with picture. I can then edit the various ADR_xx.wav clips on the track easily, but always have the master clips (in pieces from various takes) to rework if I need to, and then create another ADR_01.wav file as needed.
        THAT is where I get this error. When I want to change ADR_01.wav, I change the master clips, Mixdown those to a new file (again), and try to Save As to ADR_01.wav. However, I first go to the files panel and Close Selected Files on the old existing ADR_01.wav. I assumed that closing the file this way, even if old copies are still on the timeline (and marked as 'offline') that I'd be able to rewrite the file on disk. However, I get the 'OK to Overwrite?' dialog, and then the error referenced by the OP. System diagnostics show that only Audition has the file open (still), even after closing it in the Files panel. Am I not understanding how the Files panel works, or is this still a bug?
        The reason I want to do this, is because I already have the originally created ADR_xx.wav files on a dialog track and synced to picture, and I just want to update the underlying file (data) for all the ADR_01.wav clips (and if necessary, relink the media). It's not quite the same as opening a clip in Editor, editing it, and then Saving it again, although it should be. But I can't update the file because Au won't close it? I (think I) have tried to delete all old versions of the original ADR_01.wav clips before saving the new mixdown, but that didn't seem to make a difference. The alternative is to create new files with new names and create many more unnecessary files on disk and in my project.
        Any advice would be appreciated.
        Cheers,
        Shane
        • 29. Re: Error when saving audio file
        Interesting. Here, even on a fast disk system (all SSD), Audition can take a significant amount of time sometimes to 'clear' closed files from wherever the information about them is stored. But the 'okay to over-write?' message is absolutely normal, even when the files are closed. Whenever, under any circumstances, you try to save a file with the same name as one in the same location, you will get this; it's generated by the OS, even though it might look like an Audition message. I'm not entirely sure about what happens with off-line clips from the file (I don't ever work like this) but my understanding is that this shouldn't affect the outcome of an over-write; it's only actual files open in the files panel that should be completely unavailable.
        • 30. Re: Error when saving audio file
        I'll test this - I suspect that it's fine now. But, the 'fix' if there is one will be in a later generation, not in Audition CS5.5.
        • 31. Re: Error when saving audio file
        GrizzlyAK Level 1
        I've had to work around this, after a lot of unsuccessful troubleshooting, by creating new copies of the files. This has to be a case of Au not releasing file handles and properly (timely) closing files, since I know that the system thinks that Au is the ONLY app with the file open. In my case, this is on a regular HDD in an internal bay (i.e., not USB). I've changed my workflow because I don't expect a fix to CS6 (or apparently any time soon).
        • 32. Re: Error when saving audio file
        ryclark Adobe Community Professional
        It's strange that there haven't been more reports of this. Most of us don't seem to have the problem. So there must be something different about your set up or your workflow that is causing this problem.
        One thought that I had when re-reading your original post was that after closing the unwanted file had you updated the session .sesx file before trying to do your Save As? It may be that if the file is closed but still recorded in the .sesx file as being needed in the session that the Audition overwriting error message comes up. The .sesx file is just a form of XML and can be opened and examined using any app that reads .xml files.
        • 33. Re: Error when saving audio file
        GrizzlyAK Level 1
        Yeah, I thought that too ryclark. I did try it both ways, before saving the session and after - same either way. It's odd. I suspect that Au is programmed in such a way that there are lot of background processes in the interface, to focus maximum attention on the job at hand - playing audio uninterrupted including the processing of multiple CPU intensive effects real time. It does that very well (in my limited experience with DAWs). Perhaps releasing file handles and other housekeeping is pushed down in the stack of priorities. One thing I haven't tried is letting Au sit for a while (hour or two) after closing a file before trying to rewrite it. That might at least tell me if it is a timing issue, or just a unreleased lock. Closing and opening the file (after saving the session with the file closed) lets me rewrite the file, as you might expect. I can't imagine the OS holding a lock on a file after the app releases it. We'd be hearing a lot more about this if that were the case, me thinks.
        • 34. Re: Error when saving audio file
        Foxtrot1_1 Level 1
        This problem still exists.
        • 35. Re: Error when saving audio file
        derekb1039
        I had the same problem immediately after I installed Audition 5.5 on my PC (Windows 7 Ultimate 64 bits, freshly installed), to be one of the 'external editors' for audio files in my DAW of choice, which happens to be REAPER 5.9 (fresh install, also). E.g. I'd select an audio file in REAPER and click key E on my keyboard to open that file in Audition (it does that without a hitch); I'd perform some kind of editing on the file in Audition and try so save its edited content from File>Save menu item in Audition. Previous setups like this worked without a hitch: Audition just blinks and the edited audio file shows as edited in its original track in REAPER. This time (with both programs reinstalled) I started getting the dreaded "This file is in use by another application and cannot be overwritten" error messages. Turns out there is a setting in REAPER's Preferences where an audio file you "send" to Audition for editing has to be put into 'offline' status by checking the specific box in REAPER's preferences window (from menu bar "Options">"Preferences">"Media"). The label for that specific box in REAPER goes "Set media items to offline when application is not active". Obviously, when an audio file is edited in Audition and a Save attempt is made, it is Audition that is presently active, not REAPER. That's why a simple save command will work fine, no error messages. BTW, with that setting in REAPER checked, the audio file image in REAPER changes to a grey rectangle with an "offline" watermark label on it as soon as I click on Audition's window, making it the active application. To recap: whatever other program you may have open alongside Audition and the very same audio file happens to be open in the other program (one of many such situations), make sure the other program has an editable setting allowing you to put that audio file into 'offline' status, so that Audition has exclusive privilege (i.e. "The file is not in use by another application and can therefore be overwritten") to manipulate that audio file - including being able to save it to disk.
