0 Replies Latest reply on Jun 30, 2011 8:37 PM by adalem63
    please help me on a form i push the submit button and all i get is a page with the following code wh
    adalem63 Level 1
      <?php
      //--------------------------Set these paramaters--------------------------
      // Subject of email sent to you.
      $subject = 'Results from Contact form';
      // Your email address. This is where the form information will be sent.
      $emailadd = 'allenadalem62163@live.com';
      // Where to redirect after form is processed.
      $url = 'http://www.karenwebster.info/confirmation.html';
      // Makes all fields required. If set to '1' no field can not be empty. If set to '0' any or all fields can be empty.
      $req = '1';
      // --------------------------Do not edit below this line--------------------------
      $text = "Results from form:\n\n";
      $space = ' ';
      $line = '
      foreach ($_POST as $key => $value)
      if ($req == '1')
      if ($value == '')
      {echo "$key is empty";die;}
      $j = strlen($key);
      if ($j >= 20)
      {echo "Name of form element $key cannot be longer than 20 characters";die;}
      $j = 20 - $j;
      for ($i = 1; $i <= $j; $i++)
      {$space .= ' ';}
      $value = str_replace('\n', "$line", $value);
      $conc = "{$key}:$space{$value}$line";
      $text .= $conc;
      $space = ' ';
      mail($emailadd, $subject, $text, 'From: '.$emailadd.'');
      echo '<META HTTP-EQUIV=Refresh CONTENT="0; URL='.$url.'">';
      where do i put this and what am imissing
