6 Replies Latest reply on Jul 4, 2011 4:35 AM by praveen mds
    Text file output
    praveen mds Level 1
      var a = this.getAnnots();
      var Report = new Report();
      for(i=0; i<a.length; i++){
          if ( a != null ) {
              var p = a[i].getProps();
              for ( o in p )
              Report.writeText( o + " : " + p[o] );
      Report.save("/c/temp/myreport.pdf");
      This script gets the property of all annotations in a pdf file and makes it as a pdf output.
      How to get the report file in txt format?
      Praveen
        • 1. Re: Text file output
          Bernd Alheit Adobe Community Professional & MVP
          Look at the method saveAs.
          • 2. Re: Text file output
            praveen mds Level 1
            Report.saveAs("/c/temp/myreport.txt", "com.adobe.acrobat.plain-text");
            Dear Bernd
            Is the right way to proceed? its not working for me.. what i'm doing wrong.
            Praveen
            • 3. Re: Text file output
              Where are you running that script?
              Are you getting any conosle errors?
              • 4. Re: Text file output
                Use this:
                app.openDoc("/c/temp/myreport.pdf");
                this.saveAs("/c/temp/myreport.txt", "com.adobe.acrobat.plain-text");
                • 5. Re: Text file output
                  praveen mds Level 1
                  Thanks Bernd,
                  When i execute this; Before opening the specified pdf, it saves my current file opened in acrobat as txt format.
                  i tried closing my currect file, it also not helps me. As acrobat takes time to open the file, it executes the next step.
                  this.closeDoc()
                  And its seems too complex, making a report to pdf and then to txt format. its better to have a direct txt file report.
                  Any suggestions?
                  • 6. Re: Text file output
                    praveen mds Level 1
                    I'm running it with Batch sequence,
                    This is my fine tuned script
                    var b = this.documentFileName;var d = b.slice (0, -4);
                     if ( a != null ) {
                          var p = a[i].contents;
                          var q = a[i].rect;
                          var r = a[i].page;
                          Report.writeText( "Contents: "+p+"    Page: "+(r+1)+"     XY_Coordinates: "+q );
                    Report.save("/c/temp/"+d+"_report.pdf");
                    this.closeDoc()
                    All i need is the should be report in text format, rather than pdf.
