7 Replies Latest reply on Jul 1, 2011 2:41 PM by koomeet
    Premiere Pro CS5 crashes just after media is loaded
    koomeet
      Hello
      I have HUUUGE problem with PrPro CS5.
      I have project file - lot of work is already done but lot of more left.
      When I try to open my project file it loads fine. But then when it is loading all media files (at the bottom left corner) just when i get message "all media loaded" application crashes.
      I've found information that older nvidia drivers may be the issue but unfortunately new driver is not helping.
      I have also foundd informotion that VST plug in is problem - how can I disable them in PrPro?
      Whats strange i have other projcet with the same type of video files recorded at DSLR and they load fine. But this project is much bigger.
      I often had a problem with crashing of PrPro while importing video files to project - sometimes i had to try few times to make it happen (crash otherwise) but later project worked fine, but this time it is not. I have no idea is this connected with the crashes wafter loading media files but i think it is.
      Got deadline on sunday and already spent over 4 hours instead of working on trying to find solution..... This situation is getting me broken - really.
      If anybody could help me I be grateful
      regards
      Tomek
        • 1. Re: Premiere Pro CS5 crashes just after media is loaded
          Colin Brougham Level 6
          Have you tried creating a new project and importing your existing one into it? That has, on occasion, rescued broken projects.
          Seem to recall that VST plug-ins are automatically disabled or "blacklisted" if they don't work, but I don't think that's probably the problem anyway--those would be loaded during startup of the application, and that's where you'd see the crash. Of course, if you're using one of the VST plug-ins in your sequence, that could be a possibility. Try importing the project into a new one, and see how that goes, first.
          • 2. Re: Premiere Pro CS5 crashes just after media is loaded
            koomeet Level 1
            Thx for tip. Unfortunately it has not helped.
            Well it worked for a moment but when i saved new project and i tried to load it the same problem occured. What is strange when i try to import it again PrPro cashes even if 10 minutes earlier it worked for a moment.
            • 3. Re: Premiere Pro CS5 crashes just after media is loaded
              OK, let's determine if it's the project or the media itself...
              With Premiere Pro closed, change the name of the folder(s) containing your media; just add a character to the name so you can quickly change it back. For example, if your folder is called "Footage" just name it "Footage1". Create a new project, and import the original project into it; Premiere will ask where the footage is, but just hit Skip All. Obviously all your footage will be represented by the "Media Offline" placeholder, but you should be able to test whether the project is stable or not. If it is, there is something screwy with one of the media files, or it's possible that the media cache database has been corrupted and needs to be cleaned. If the project still causes the program to crash, it's something with the project file itself.
              Try that, and we'll go from there.
              • 4. Re: Premiere Pro CS5 crashes just after media is loaded
                koomeet Level 1
                1. I changed the name of media folder
                2. I started new project and imported old one (skipping the media)
                It worked
                3. I linked one of the folder with media files and it is istill working even when i save it and load it. But I already have similar situation and later it crushed again. Let's hope that this time it is gonna work.
                Colin i really appreciate all of your help!
                I think that something wrong with media files and they are crushing the project but at the moment i am going to be optimist and try to work on it with hope that it would not crush anymore.
                • 5. Re: Premiere Pro CS5 crashes just after media is loaded
                  Glad to hear! I suspect it's probably not the media itself, but the cache files that are created as a result of importing media. If you delete all the PEK, CFA, and any other cache files that are associated with the media while your project is closed, and then reopen the project and let the files be recached, you might be OK. The media cache files and database can flake out, seemingly at random, and lead to issues like the ones you're describing.
                  Hope you can meet your deadline!
                  • 7. Re: Premiere Pro CS5 crashes just after media is loaded
                    koomeet Level 1
                    yes, all updates were installed.
