Created five slides, cupla' buttons, no images; 1024x768. Opened (created) a new, blank project (800x600) and tried to import the XML; it failed. Opened (created) a new, blank project (1024x768) and tried to import the XML (again); it failed. Here's the pop-up window screen-cap:
Adobe® Captivate® Version 5.5.0.257
Adobe eLearning Suite 2.5
Windows 7 Professional (x64) SP 1 (build 7601)
2.67 GHz Intel Core i5 M 560
3952 Megabytes Usable Installed Memory
ATI FirePro M5800
161.56 GB Hard Drive Free Space
Microsoft Office 2010 Version 14.0.6026.1000
Adobe Acrobat Version 10.1.0.534
Adobe Bridge CS5.1 CS5.1
Hi there
I stand to be corrected on this, but I believe the XML import and export likely work just like the Export of Captions and Closed Captions.
The way that one works is like this: You export the captions and closed captions. You make changes. You then import the captions and closed captions back into the SAME project you exported from.
I think the XML works the same way. You would export the XML, massage it and import it back into the SAME project.
Give that a go and see if it works for you.
Che
...Copy link to clipboard
Hi there
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Rick gives you the appropriate answer (as always), just want to add that you shouldn't change the name of the exported XML-file neither...
Lilybiri
