7 Replies Latest reply on Aug 15, 2006 4:40 PM by Newsgroup_User
    HTML styles - TD width and height
    amit_s
      Does anyone have an HTML style writen so when I export HTML from Firworks it writes the the TD width and height in the TD tag. example <td width="700" height="300".....
      thanks
        • 1. Re: HTML styles - TD width and height
          Level 7
          Sorry - I don't understand your question....
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "amit_s" <webforumsuser@macromedia.com> wrote in message
          news:ebsug7$7n2$1@forums.macromedia.com...
          > thanks
          • 2. Re: HTML styles - TD width and height
            amit_s Level 1
            At it's defalt stage Fireworks produces tables that contain <td> tags, that do not set a width and height tags isnide the <....>. Imageready does! In Imageready, you can set a prefernce to include W&T statment, and working in Fireworks, I would like to the same thing.
            In other words: Fireworks produces tags that look like this <td....> I would like to have Fireworks produce tags that look like this: <td width="100" height="100"......>, so a cell width and height is always included. what is the simplest way of doting this. (I thought that I need to set a HTML style, but if there is another way please let me know)
            thanks
            • 3. Re: HTML styles - TD width and height
              Level 7
              Fireworks includes the height and width of the objects inside the table
              cell's.
              Linda Rathgeber [PVII] **Adobe Community Expert-Fireworks**
              Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
              CSS Newsgroup: news://forums.projectseven.com/css/
              Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
              • 4. Re: HTML styles - TD width and height
                Level 7
                No, you don't want that, in all honesty. Using dimensions on cells is
                pretty much an exercise in frustration since the cells never wind up with
                those dimensions anyhow, or when they do, it's where you forgot you used
                them and now don't need it to be that size any longer. Those numbers are
                minimum widths/heights. Table cells can easily be forced wider/higher by
                content elsewhere, particularly when you use a graphics editor to write the
                HTML.
                The best solution is to learn how to create stable HTML tables, and then you
                can use FW to just create your graphics while you build the page in DW.
                news:ebt7sl$ij7$1@forums.macromedia.com...
                > that do
                > in
                > would
                > is the
                > but if
                > thanks
                • 5. Re: HTML styles - TD width and height
                  amit_s Level 1
                  I understand that you might think this is not the way to go, and it may well not be, but I work within a corporate environment where my coders want the TD to have W&H, and it is an option in Imageready, so how can I make it happen in Firworks, becuase the code Fireworks produces now, does not have it.
                  thanks agian, everyone!
                  • 6. Re: HTML styles - TD width and height
                    Level 7
                    You can't. Fireworks simply does not have that option.
                    • 7. Re: HTML styles - TD width and height
                      Level 7
                      You need to educate your coders to proper HTML and tables, then....
                      "Linda Rathgeber **Adobe Community Expert**" <lightly@sc.rr.com> wrote in
                      message news:ebtlco$3ta$1@forums.macromedia.com...
                      >> not have it.
