0 Replies Latest reply on Jul 2, 2011 12:43 PM by RUDRAPRATAPSINGH
    Flex UI and Restful Web Service deployed on same tom cat container.
    RUDRAPRATAPSINGH
      Hi folks,
          I have a deployment, where I have a RestFul Web Service [b](war[/b]) and a Flex UI [b](war)[/b] on the same Tom Cat Server.
          I can access the flex UI
                  [b]http://10.10.10.10:8080/configuration-ui/[/b]
          I can also access the RestFul web service
                  [b]http://10.10.10.10:8080/restendpoint/[/b]
          So bottom line is that every thing is working fine individually.
          [b]  The Problem:[/b]
                When I try accessing the RestFul Web Service within the Flex UI. It says Internal Server Error. What's the issue ?.  BTW, I am trying to access the RESTful web service from the Flex UI by using the ip. Should work right ?.
                BTW : Is it okay to deploy both the Flex UI and the RESTful Web Service wars on the same tom cat container ?. What is this issue I am running in to.
      _SM
