6 Replies Latest reply on Jul 18, 2011 3:57 PM by Flex harUI
    transcoding parameter 'embedAsCFF' is not supported...tried everything! Help!
    SPGAnne Level 1
      HELLLLPPPPP!!!!   I give up.  I think I've tried everything....
      I am trying to move from Flex 3 to Flex 4.  I have a .css style sheet with this defined
      @font-face {
      src: url(/style/arial_font_embed.swf);
      fontFamily:
      "Arial";
      fontStyle: normal;
      fontWeight: normal;
      The arial_font_embed.swf had been created in Flash CS4 and has worked just fine in the old Flex 3 world for years.  I looked at the following locations to figure out what to do
      http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf69084-7f5f.html
      http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf69084-7f5f.html#WS02 f7d8d4857b16776fadeef71269f135e73-8000
      I added the
      embedAsCFF: true;
      to the .css, but then I get the error:
      transcoding parameter 'embedAsCFF' is not supported by 'flex2.compiler.media.MovieTranscoder'
      I thought maybe there is something wrong with how my old arial_font_embed.swf is built.  I tried using the fontswf utility that is in my folder
      Program Files (x86)\Adobe\Adobe Flash Builder 4.5\sdks\4.5.1\bin folder ( I am using eclipse 3.6.2 with FB4 as a plugin).  But my windows command console says "fontswf 'java' is not recongized as an internal or external command, operable program or batch file".  I tried typing in fontswf.bat (which is clearly in the directory) and still got that error.  Then I tried looking high and low to figure out how to create the .swf font embed file using FB4 to see if there were any parameters or publish settings I missed. Couldn't find anything.
      Then I tried following the instructions described here:
      http://blogs.adobe.com/tlf/2008/11/embedded-font-subsetting-using.html
      I built myself an app .mxml file and successfully built a .swf with the unicode ranges I wanted.  Then I tried using that as the src, and I still get the error
      I am at a loss about what to do.
      Please help.
