6 Replies Latest reply on Jul 5, 2011 3:50 PM by John T Smith
    New Build Problem
    FelixUnderwood Level 2
      A couple of weeks ago I got around to building a new rig with a 990X, Gigabyte Geurilla mo-board (the gamers sure are driving the desktop industry!), 24Gbs of GSkill Ram, 1k Watt PS, & a GTX-580. The other components don't matter at this point, because right now, when I power up the computer it runs for 2 secs. shuts down for 2 secs. fires back up for 2 secs, etc. I have swapped out power supplies, Ram, video cards, re-seated the CPU, and jumper-reset the BIOS. Clearly the problem lies within the moboard or CPU, but I'm open to any last ditch efforts before bringing on a 3rd party to get this thing running. I don't want to order a replacement CPU w/o knowing that that is, indeed the culprit. Most of the components were brand new from New Egg, except for the video card and PS, both of which came from an operational machine (and both were swapped out anyway to rule them out as the cause). So, the reason I'm posting this is because once before I had this same problem with my general purpose computer, that had been in operation for a couple of years and I posted this problem and Colin, from Brougham Media, suggested replacing the battery on the moboard. I was very skeptical, but it was the least expensive option for trying to diagnose the problem and just like all of his other solutions, it worked! Didn't work this time around, being that the moboard is brand new.
         So, would you recommend shipping back the moboard to Gigabyte for repair or would it be safe to order a replacement from New Egg, hoping that that's the most likely culprit and send the board I have now back to New Egg as defective? I'm hoping there's something you can suggest I try before going to either of those lengths.
        • 1. Re: New Build Problem
          When I built my wife's (non-editing) computer I did not properly mount the CPU cooler, and the computer would start and almost immediately stop
          It is very easy to mis-mount the CPU cooler, so I would check that as well as the CPU itself
          • 2. Re: New Build Problem
            John, thanks for that but I mounted the cooler twice using two different philosophies on how to apply heat sink. I will admit that's my least favorite part of building a computer. However, I don't believe 2 seconds is long enough to allow the CPU to over heat even with a poor heat sink compound job. I could see it shutting down that fast if there were no heat sink attached at all, but probably would run longer even if there were no heat sink compound used, but the heat sink attached. Especially since I've attached the heatsink twice now, being that I reseated the CPU, I doubt this is the problem.
            • 3. Re: New Build Problem
              At this point, since you have remounted everything and the problem persists, the only thing I can think of is a power connector that did not seat properly
              Otherwise, I'd say it is time for a new motherboard
              • 4. Re: New Build Problem
                Bill Gehrke Most Valuable Participant
                Felix
                I would remove the graphics card (an any other card) and its power connectors and see that if it changes anything.  Also unplug the keyboard/mouse. These normally will give you error beeps or someother error message if it stays on longer.  Also remove all but one stick of memory, if it persists substitute one of the other "good" memory modules for the one.  Check you manual to find out which is the first RAM socket.
                • 5. Re: New Build Problem
                  Problem solved. I called a local computer repair store, Intrex Computers, and described the problem. Told the guy all the steps I'd taken to diagnose. His response was, "Sounds like you have a short underneath the motherboard." I told him I had indeed gone from one Gigabyte model motherboard to another and needed to add some standoffs, but I was quite sure I didn't need to move any of the existing ones. When I asked him about the possibility of a bad motherboard he said that's extremely rare, so I decided to pull the moboard to see if I was dense enough to leave an old standoff. So I pull the board and sure enough found 10 standoffs where they were supposed to be. "Sure glad I'm not that dumb" I thought, though admittedly I was so anxious to put this time-consuming problem behind me, I was willing to embrace ignorance, which I've been forced to do thousands of times before if it meant finding the problem. So I go to put the motherboard back in and low and behold there's an errant screw, which was wedged in a corner near the motherboard, but not under it. Sooooo, let's just say that I didn't even catch that screw when I pulled the moboard the first time to reseat the CPU. But there's nothing else to explain the problem. The Intrex tech said it sounded like a short, and I found a loose screw (no snide comments, please. I've already thought of them!). Wow, when I was young, I was thrilled when my mother told me that I had IQ. I now have come to realize that she never said how much. Or in my case, how little!
                  • 6. Re: New Build Problem
                    Good that the MB was turning off quick enough that you didn't fry something!
