3 Replies Latest reply on Sep 14, 2011 11:24 AM by NUHistorian
    Mac OS 10.6.8: adoberesourcesynchronizer crashes on each re-boot
      Hello: I just notice this in my crash log:
      Process:         AdobeResourceSynchronizer [210]
      Path:            /Applications/Adobe Reader.app/Contents/Support/AdobeResourceSynchronizer.app/Contents/MacOS/AdobeResourceSyn chronizer
      Identifier:      com.adobe.AdobeResourceSynchronizer
      Version:         ??? (10.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [161]
      Date/Time:       2011-07-04 09:26:58.931 -0500
      OS Version:      Mac OS X 10.6.8 (10K540)
      Report Version:  6
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   com.apple.CoreFoundation      0x970aac13 CFSetGetValue + 83
      1   com.apple.CoreFoundation      0x970b0bb9 __CFRunLoopFindMode + 137
      2   com.apple.CoreFoundation      0x970daaae CFRunLoopRemoveSource + 158
      3   ...e.AdobeResourceSynchronizer 0x0002f937 CNetWatcher::Stop() + 97
      4   ...e.AdobeResourceSynchronizer 0x0000c16a CSynchronizerApp::shutdownNetChangeNotifier() + 46
      5   ...e.AdobeResourceSynchronizer 0x0000d34b CSynchronizerStartupGuard::~CSynchronizerStartupGuard() + 39
      6   ...e.AdobeResourceSynchronizer 0x0000d69c CSynchronizerApp::run() + 786
      7   ...e.AdobeResourceSynchronizer 0x0000c0cd main + 169
      8   ...e.AdobeResourceSynchronizer 0x0000c006 start + 54
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x99723382 kevent + 10
      1   libSystem.B.dylib             0x99723a9c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib             0x99722f59 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib             0x99722cfe _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib             0x99722781 _pthread_wqthread + 390
      5   libSystem.B.dylib             0x997225c6 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib             0x99722412 __workq_kernreturn + 10
      1   libSystem.B.dylib             0x997229a8 _pthread_wqthread + 941
      2   libSystem.B.dylib             0x997225c6 start_wqthread + 30
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000000  ebx: 0x970aabcc  ecx: 0x00000028  edx: 0x00000010
        edi: 0xbffff70c  esi: 0xbffff6d8  ebp: 0xbffff698  esp: 0xbffff660
         ss: 0x0000001f  efl: 0x00010283  eip: 0x970aac13   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x00000000
      Binary Images:
      Any reason why?
      Reader 10.0.3 works OK (for what I have used)...
      Cheers, Jim B
        • 1. Re: Mac OS 10.6.8: adoberesourcesynchronizer crashes on each re-boot
          I have something similar.
          On each boot, I get the message, "adoberesourcesynchronizer quit unexpectedly."  Removing it as a Login Item doesn't work for long because of the self-heal feature.
          How do I make this STOP?
          • 2. Re: Mac OS 10.6.8: adoberesourcesynchronizer crashes on each re-boot
            3threecushion Level 1
            Hello: I just found this in the forum…
            Good luck…
            Put “ “ around the name “Adobe Reader.app”  as UNIX does not allow spacese in names..
            Cheers, Jim B
            Re: How to disable AdobeResourceSucker?
            AdobeResourceSucker came back even though it is clearly disabled in my Login Items. Probably Adobe Reader is launching it, since that is the only other Adobe thing I have installed.
            Here is how to make sure it will never come back.
            In a Terminal window, cd to the correct the correct directory.
            $ pwd
            /Applications/"Adobe Reader.app"/Contents/Support
            Delete the sucker forever
            $ sudo rm -rf AdobeResourceSynchronizer.app
            You will be asked for your admin password. If you have never used sudo to do something, this is not a good command to try as your first one, since getting it wrong could cause a lot of pain.
            Log out and log back in.
            Actually, it will come back next time you do an update of Adobe Reader, so you'll need to do this again then.
            • 3. Re: Mac OS 10.6.8: adoberesourcesynchronizer crashes on each re-boot
              NUHistorian Level 1
              Many thanks!  That's a great suggestion.  If only Adobe didn't update so often . . . (I do have it set to manual, not auto, update -- but still, one needs the updates from time to time.)
