10 Replies Latest reply on Jan 6, 2012 11:12 AM by Chantal Harvey
    Distorted picture while editing MP4 file in Adobe Premiere CS5
    mikim33
      hi,
      I am trying to edit an MP4 file in the Adobe Premiere CS5 and having a distorted picture every few seconds.
      When I am playing the original file using VLC or Media Player it looks OK.
      Untill now I didn't have problems with editing MP4 files.
      Did anybody had similar problem (and a solution )?
      I am adding the file info captured by MediaInfo:
      General
      Complete name                    : E:\tami\video\M4H04540.MP4
      Format                           : MPEG-4
      Format profile                   : Sony PSP
      Codec ID                         : MSNV
      File size                        : 17.5 MiB
      Duration                         : 16s 16ms
      Overall bit rate                 : 9 189 Kbps
      Encoded date                     : UTC 2011-07-01 07:14:25
      Tagged date                      : UTC 2011-07-01 07:14:40
      Video
      Format                           : MPEG-4 Visual
      Format profile                   : Advanced Coding Efficiency@L4
      Format settings, BVOP            : Yes
      Format settings, QPel            : No
      Format settings, GMC             : No warppoints
      Format settings, Matrix          : Default (H.263)
      Codec ID                         : 20
      Duration                         : 16s 16ms
      Bit rate mode                    : Variable
      Bit rate                         : 9 000 Kbps
      Maximum bit rate                 : 14.0 Mbps
      Width                            : 1 280 pixels
      Height                           : 720 pixels
      Display aspect ratio             : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 29.970 fps
      Color space                      : YUV
      Bit depth                        : 8 bits
      Scan type                        : Progressive
      Compression mode                 : Lossy
      Bits/(Pixel*Frame)               : 0.326
      Stream size                      : 17.4 MiB (99%)
      Audio
      Format                           : AAC
      Format/Info                      : Advanced Audio Codec
      Format profile                   : LC
      Codec ID                         : 40
      Duration                         : 16s 0ms
      Bit rate mode                    : Constant
      Bit rate                         : 64.0 Kbps
      Channel(s)                       : 1 channel
      Channel positions                : Front: C
      Sampling rate                    : 24.0 KHz
      Stream size                      : 125 KiB (1%)
      Miki
