1 Reply Latest reply on Jul 5, 2011 7:28 AM by _spoboyle
    ApplicationUpdaterUI
    _spoboyle Level 4
      previously i have had the ApplicationUpdaterUI workign with these settings
      appUpdater.isCheckForUpdateVisible = false;
      appUpdater.isDownloadUpdateVisible = false;
      appUpdater.isInstallUpdateVisible = false;
      now i want to user to choose whether they download the update or not so i use
      appUpdater.isDownloadUpdateVisible = true;
      and now no update takes place any ideas?
      I am updating directly via update-descriptor.xml rather than update-config.xml
        • 1. Re: ApplicationUpdaterUI
          _spoboyle Level 4
          this is actually related to my other issue http://forums.adobe.com/thread/873046?tstart=0
          if I include
          addEventListener(Event.CLOSING, onClose);
          private function onClose(event:Event):void
               for each (var window:NativeWindow in nativeApplication.openedWindows)
                    if (!window.closed)
                         window.close();
          then the update happens (but i then get the damaged file warning)
          if i remove the above code then i get no update process happening, unless i set the following,
