2 Replies Latest reply on Aug 18, 2006 10:23 PM by mariusvz
    baOpenFile to open folder on a mac
    martynrlee
      Hi All,
      Can anybody help me,
      Im trying to find a method of opening a folder from within a projector on a mac.
      Im currently using barunprogram ("explorer.exe", "foldername", false) on a pc - this works perfectly using the buddy api xtra
      I know i have installed this ok on a mac because im using it to access PDF files using the baopenfile comand.
      I think i need to open the Finder app on a mac in the same method i have used to open explorer on the pc
      this doesnt seem to work - i have also tried the openfile command with no luck either
      Is it possible to opena folder on mac from within a projector? - All help most appreciated.
      Thanks - Martyn.
        • 1. Re: baOpenFile to open folder on a mac
          Level 7
          > projector on a mac.
          Try baOpenFile("folderName", "normal") on Windows and
          baOpenFile("folderName") on the Mac.
          Andrew
          • 2. Re: baOpenFile to open folder on a mac
            mariusvz Level 1
            You can also try this, then you don't have to use up one of your buddy api functions... although I use it here just to get the path to the documents folder.
            open basysfolder("personal") with "finder.app"
            Hope this helps....
            BTW - it works the same on PC, just replace "finder.app" with "explorer.exe"
            Marius
