1 Reply Latest reply on Jul 13, 2011 9:20 AM by ozDiGennaro
    Ant Builds: Choose Configuration type : Ant Builder vs Program
    ThomasJames_T Level 1
      From the adobe documentation
      Create a builder
      1. In the Flex Package Explorer, select a project and then right-click (Control-click on Macintosh) to display the context menu and select Properties.
      2. Select the Builders properties page. If you’re using other Eclipse plug-ins, there can be more than one builder listed. Flash Builder provides a builder named Flex, which you cannot modify.
      3. Select New.
      4. In the Choose Configuration Type dialog box, select the appropriate configuration type. Flash Builder supports the program type. Select it and click OK to continue. From the new builder properties page, you define the builder properties and reference the Ant script (an XML file).
      5. Click OK to apply it to the project
      So in the configuration dialog I can also see 'Ant Builder' listed. But in paragraph 4 above it says "Flash Builder supports the program type"
      Question:
      What is the other option Ant Builder for then ? Does that require an install of Ant Builder into Flashbuillder 4.5 whereas Program option is natively supported ? Confused as there is little about the second option 'Ant Builder' in the help files.
      Appreciate reply, loosing my hair over this as per usual
      Thomas
