3 Replies Latest reply on Jul 6, 2011 4:14 PM by kokorito
    Flex + SQlite
    JasonBr42
      Hey there, I am trying to figure out how to insert each row of my arraylist into a new SQLite table.
      I tried this =
      for each (var item in myArrayList)
              dbStatement.execute("insert into Products values(?)", (item,));
      but it gives me a missing parenthesis error....
      Any ideas?
      Thanks!
        • 1. Re: Flex + SQlite
          kokorito Level 4
          you need to put the sql in the text property and then execute
          also, I've not seen a sql statement like that before, I've always done it like this
          dbStatement.text = "insert into Products (col1,col2,col3) VALUES(:col1,:col2,:col3)";
          dbStatement.parameters['col1'] = item.prop1;
          dbStatement.parameters['col2'] = item.prop2;
          dbStatement.parameters['col3'] = item.prop3;
          dbStatement.execute();
          assuming of course that you've already connected to and created the Products table
          • 2. Re: Flex + SQlite
            JasonBr42 Level 1
            Yeah, I think I mis-read somewhere that flex was able to simply accept a complex object array and create a table with it.
            So in looking at your suggestion there can you explain the following statement?
            is  Products (col1,col2,col3)  the label for each column
            and is VALUES(:col1,:col2,:col3)";   the arrays label for each colum to correlate the two?
            • 3. Re: Flex + SQlite
              kokorito Level 4
              sorry, yes the col1, col2 are the column names in the table, the values list :col1, :col2 are parameters that correspond to the columns
              then set their values in the dbStatement[':param_name'] =
              sql.text = "INSERT INTO Products (id,price) VALUES (:id,:price)";
              sql.parameters[":id"] = item.id;
              sql.parameters[":price"] = item.price;
              sql.execute();
