3 Replies Latest reply on Aug 5, 2011 1:28 PM by JLAFARGUE
    HELP with flowing form – changes effect the correct subform
    ParreLaws
      I've created a form that adds a subform of information. In this subform there is a radio button that automatically updates various text fields in the form. The problem I'm having is when I click the Add button and get a new subform of information and click the new radio button it changes the first set of text fields. Can someone assist me with making the radio buttons changes only the text fields in the new subform? Please see example below.
      This is the if statement I in the under change
      if
      (this.rawValue == "1"){
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct101.rawValue = "X"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct102.rawValue = "X"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct105.rawValue = "-"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct103.rawValue = null
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct104.rawValue = null
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct103.access = ""
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct104.access = ""
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct105.access = "protected"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct101.access = "protected"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct102.access = "protected"
      else if
      (this.rawValue == "2"){
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct103.rawValue = "X"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct104.rawValue = "X"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct105.rawValue = "X"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct101.access = "readOnly"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct102.access = "readOnly"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct103.access = "readOnly"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct104.access = "readOnly"
          form1.CashTransfer.FOneTMul.AcctSM.From.Acct105.access = "readOnly"
      else {
           form1.CashTransfer.FOneTMul.AcctSM.From.Acct101.rawValue = null
           form1.CashTransfer.FOneTMul.AcctSM.From.Acct102.rawValue = null
            form1.CashTransfer.FOneTMul.AcctSM.From.Acct105.rawValue = null
           form1.CashTransfer.FOneTMul.AcctSM.From.Acct101.access = ""
           form1.CashTransfer.FOneTMul.AcctSM.From.Acct102.access = ""
           form1.CashTransfer.FOneTMul.AcctSM.From.Acct105.access = ""
      Thanks for any assistance.
      Parre
        • 1. Re: HELP with flowing form – changes effect the correct subform
          rajesh9g
          Hi Parre,
                I suspect something might we referencing to the objects of your first subform. Can you please share with me the PDF that you are working on? i can make corrections and send you back.
                I have a sample implementation similar to your requirement, please refer to the link below and this should help you in fixing the bug
          https://sendnow.acrobat.com/m/g.ashx?i=HrFhIcY0lN4-AAXEY8wdCg&x=aEgw04LdgFDon-o9heLWnQ
          thanks,
          Rajesh
          • 2. Re: HELP with flowing form – changes effect the correct subform
            ParreLaws Level 1
            Hello Rajesh,
            Thank you for reviewing the attached PDF. Please know that any assistance
            would be greatly appreciated.
            Thank again,
            Parre
            To:     Parreshea Laws <pld1@ntrs.com>
            Date:   07/07/2011 12:55 PM
            Subject:        HELP with flowing form –
            Hi Parre,
            thanks,
            Rajesh
            • 3. Re: HELP with flowing form – changes effect the correct subform
              JLAFARGUE Level 1
              I don't see you using the index of the subform anywhere in your code.  LiveCycle might then default to the first instance of the subform.
              Try adding something like this to your code of the click event of your radio button:
              var i = parent.instanceManager.index;
              Then use i to index your subform.  It might look something like this if your subform you add is AcctSM.
              if
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct101.rawValue = "X"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct102.rawValue = "X"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct105.rawValue = "-"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct103.rawValue = null
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct104.rawValue = null
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct103.access = ""
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct104.access = ""
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct105.access = "protected"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct101.access = "protected"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct102.access = "protected"
              else if
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct103.rawValue = "X"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct104.rawValue = "X"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct105.rawValue = "X"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct101.access = "readOnly"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct102.access = "readOnly"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct103.access = "readOnly"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct104.access = "readOnly"
                  form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct105.access = "readOnly"
              else {
                   form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct101.rawValue = null
                   form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct102.rawValue = null
                    form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct105.rawValue = null
                   form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct101.access = ""
                   form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct102.access = ""
                   form1.CashTransfer.FOneTMul.AcctSM[i].From.Acct105.access = ""
