0 Replies Latest reply on Jul 7, 2011 12:42 AM by huangxinghui
    Container IndexChangedEvent problem
    huangxinghui Level 1
      i am using sdk3.5
      The container when set borderStyle="solid" and borderThickness="1",
      then invoke setChildIndex function, it will dispatch IndexChangedEvent, but the property oldIndex and newIndex are zero.
      because the contentPane is not null, so it does not handle the oldIndex and newIndex value
      now, my solution is set borderThickness="0", then it does work.
      part of Container.as Source Code:
      override public function setChildIndex(child:DisplayObject, newIndex:int):void
              var oldIndex:int;
              var eventOldIndex:int = oldIndex;
              var eventNewIndex:int = newIndex;
              if (contentPane) // it does not handle the oldIndex and newIndex value, so they are always zero.
                  contentPane.setChildIndex(child, newIndex);
                  if (_autoLayout || forceLayout)
                      invalidateDisplayList();
              else
                  oldIndex = super.getChildIndex(child);
                  // Offset the index, to leave room for skins before the list of children
                  newIndex += _firstChildIndex;
                  if (newIndex == oldIndex)
                      return;
                  // Change the child's index, shifting around other children to make room
                  super.setChildIndex(child, newIndex);
                  eventOldIndex = oldIndex - _firstChildIndex;
                  eventNewIndex = newIndex - _firstChildIndex;
              // Notify others that the child index has changed
              var event:IndexChangedEvent = new IndexChangedEvent(IndexChangedEvent.CHILD_INDEX_CHANGE);
              event.relatedObject = child;
              event.oldIndex = eventOldIndex;
              event.newIndex = eventNewIndex;
              dispatchEvent(event);
              dispatchEvent(new Event("childrenChanged"));
      why not handle when contentPane is exists?
      Thanks for any help.
      Huang.
