4 Replies Latest reply on Jul 13, 2011 5:12 AM by BaronKarza
    Open a Folder in Air 2.7
    BaronKarza
      Hello there,
      When Air 2.0 was released, it was possibile to do something like this (c:\mydirectory\mysubdirectory has to be there obviously):
      var file:File = new File("c:\\mydirectory\\mysubdirectory");
      file.openWithDefaultApplication();
      and the directory would be opened by using (for exampe) in windows the file explorer
      In air 2.7 this code throws an error (that is a security error, in fact if I open a temp directory created with createTempDirectory it works)
      "Illegal file path"
      Now, please, tell me how can I harm the user by simply opening a directory on his hard disk!
      How can I open a directory on his hard disk without getting this error?
      Thanks in advance
        • 1. Re: Open a Folder in Air 2.7
          blazejewicz Level 4
          I think that "Illegal file path" is usually thrown when wrong path is submitted to File constructor - not when using that file/directory. Your method works for me e.g when using quick test:
          var file:File = File.desktopDirectory;
          You could try also below solution that uses shell integration with Windows Explorer (Explorer.exe):
          var path:String = file.nativePath;
          var processInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
          var arguments:Vector.<String> = new <String>[path];
          processInfo.arguments = arguments;
          processInfo.executable = new File("c:\\Windows\\Explorer.exe");
          var process:NativeProcess = new NativeProcess();
          process.start(processInfo);
          (above version requires "desktopExtended" and native installer on deployment due to use NativeProcess)
          How to use Explorer.exe, e.g.:
          http://support.microsoft.com/kb/152457
          hth,
          kind regards,
          Peter
          • 2. Re: Open a Folder in Air 2.7
            BaronKarza Level 1
            Hi Peter,
            Thanks for you reply.
            Your example works because I think it's allowed to open the desktop directory
            Just try another one, on you hard disk c: for example and you'll see that "illegal file path"
            About the second solution, it's a nice one but I just wanted to stay more generic (however I think I will put an  "if you are on windows do this" ) and in the other case I will use a navigateToUrl...
            • 3. Re: Open a Folder in Air 2.7
              blazejewicz Level 4
              I'm able to do that just following your snippet "as is":
              I could open "C:\mydirectory\mysubdirectory" (otherwise I would not answer with first post). Are you able to read that directory at all? (that is has your account enough privileges to read/write that directory?)
              regards,
              Peter
              • 4. Re: Open a Folder in Air 2.7
                BaronKarza Level 1
                Hi Peter,
                After some time I discovered that when I switched to Air2.7 I forgot to copy the airglobal.swf to his proper location under "Common/Configuration/ActionScript 3.0/AIR2.6/"
                I do not know if it was this that created the problem or simply that that day (the day I wrote my previous message) I had flash in "guru meditation"...
                However right now all works like it should.
                Thanks again
