0 Replies Latest reply on Jul 7, 2011 5:47 AM by helbards
    [VB][CS5]How split text frame to two other frames.
    helbards
      main
      Function main()
          Set myInDesign = CreateObject("InDesign.Application")
          myInDesign.ScriptPreferences.UserInteractionLevel =         idUserInteractionLevels.idInteractWithAll
          If myInDesign.Documents.Count <> 0 Then
              If myInDesign.Selection.Count > 0 Then
                  Select Case TypeName(myInDesign.Selection.Item(1))
                      Case "TextFrame":
                          Set srcText = myInDesign.Selection.Item(1)
                          srcBounds = srcText.GeometricBounds
                          If srcText.Contents = "" Then
                              MsgBox ("X")
                              Exit Function
                          End IF
                          Set newText = srcText.Duplicate
                          newText.GeometricBounds = Array(srcBounds(0)         + 10, srcBounds(1), srcBounds(2) + 10, srcBounds(3))
                          srcText.GeometricBounds =         Array(srcBounds(0), srcBounds(1), srcBounds(0) + 10,         srcBounds(3))
                          Rem Belove lines do not work
                          Rem srcText.Texts.Item(2).Delete
                          Rem newText.Texts.Item(1).Delete
                      Case Else
                          MsgBox ("X")
                  End Select
              Else
                  MsgBox ("X")
              End IF
          Else
              MsgBox ("X")
          End If
      End Function
      So my problem is that InDesign dont see .Texts and its members. Why ??
      Message was edited by: helbards
