2 Replies Latest reply on Jul 7, 2011 10:38 AM by Jim_Simon
    Encode ProRes From Tape
    HaltonLee
      Can I encode from video tape (not from camera) and make ProRes file, both 422 and 4444?  I use to use Final Cut for this but...well, you know.
        • 1. Re: Encode ProRes From Tape
          Colin Brougham Level 6
          What do you mean by "encode from video tape?" Do you mean capture? I think you can, if you have the appropriate hardware, e.g. a third-party capture card, and FCP installed. Obviously, this is only available on the Mac, which I'm assuming you're using since you referred to FCP.
          Or do you mean something else?
          • 2. Re: Encode ProRes From Tape
            Jim_Simon Level 9
            One of the key differences between Premiere Pro and Final Cut Pro is native editing.  Whereas FCP often required the conversion of the original media to ProRes, PP is quite happy using the media in it's native form.  Since ProRes is a lossy compression standard, skipping that step has it's merrits.
