16 Replies Latest reply on Jul 8, 2011 9:44 AM by Colin Brougham
    FCP XML to Premiere Different Frame Rate
    dwhillans Level 1
      Hello,
      I have imported an FCP 7 XML into Premiere 5.04. When my sequence was in FCP it was at a frame rate of 23.976 at 720P. When it came into Premiere, though, it had changed to 59.94 fps at 720P.
      I wonder how this has happened and if there is any way to change it back to 23.976 fps? Or should I just leave it as is?
      I tried copying all of the clips within the 59.94 fps sequence into a new sequence that was 23.976, but this resulted in partial frame gaps (like a quarter of a frame missing). Sometimes you wouldn't even notice this during playback, but other times you do. So I assume this is not the best way to change it back to 23.976.
      Thank you.
        • 1. Re: FCP XML to Premiere Different Frame Rate
          Jim_Simon Level 8
          From what camera did the clips originate?
          • 2. Re: FCP XML to Premiere Different Frame Rate
            dwhillans Level 1
            The clips came from a Panasonic HVX-200.
            • 3. Re: FCP XML to Premiere Different Frame Rate
              Jim_Simon Level 8
              OK.
              And they were definitely shot at 720p/24?  (If yes, is that Native 24?)
              • 4. Re: FCP XML to Premiere Different Frame Rate
                dwhillans Level 1
                I believe it was recorded at 720P 24PN, so yes Native.
                This is the raw MOV info. It shows that it is 60P, but that the frame rate is 23.98.
                FCP seemed to recognize this automatically, and when I take one of the raw clips in Premiere and create a new sequence it also recognizes the 23.98 fps. But somehow in the XML import it got changed?
                • 5. Re: FCP XML to Premiere Different Frame Rate
                  Jim_Simon Level 8
                  I see your clips are MOVs.  That's not normal.  The camera actually records MXF files.  Perhaps FCP messed things up when it converted the media.
                  I might suggest finishing this one project in FCP, then start new projects in PP using the native media.
                  Colin B. works a lot with this media, he may have an alternative suggestion.
                  • 6. Re: FCP XML to Premiere Different Frame Rate
                    dwhillans Level 1
                    When imported through FCP, these files were converted to DVCPROHD MOV files from the MXF files, since FCP does not like to work directly with MXF files.
                    • 7. Re: FCP XML to Premiere Different Frame Rate
                      Colin Brougham Level 6
                      I have a sneaking suspicion that these files are actually 24p-over-60. Premiere is probably doing pulldown removal (24p-over-60 is a 2:3 cadence), which is why they're showing up as 24p. Can you grab MediaInfo and run a report on one of the MOVs in Text Mode, and post the results here?
                      • 8. Re: FCP XML to Premiere Different Frame Rate
                        Jim_Simon Level 8
                        It actually looks like it's not doing that, which is why it opened up in a 60p sequence.
                        • 9. Re: FCP XML to Premiere Different Frame Rate
                          I mean pulldown removal on the footage; I suspect that FCP is hiding the actual frame rate in the sequence. PPro is being more literal. The MediaInfo report will tell more (or even seeing what PPro is detecting the clip as).
                          • 10. Re: FCP XML to Premiere Different Frame Rate
                            dwhillans Level 1
                            Hi Colin,
                            Here is the info:
                            General
                            Complete name                    : /Volumes/David Whillans 500GB/Ghana Documentary FCP/Final Cut Pro Documents/Capture Scratch/Day 2/A01_BusMirror_01.mov
                            Format                           : MPEG-4
                            Format_Commercial_IfAny          : DVCPRO HD
                            Format profile                   : QuickTime
                            Codec ID                         : qt
                            File size                        : 124 MiB
                            Duration                         : 21s 188ms
                            Overall bit rate                 : 49.2 Mbps
                            Encoded date                     : UTC 2009-06-26 15:49:49
                            Tagged date                      : UTC 2009-06-26 15:49:49
                            Writing library                  : Apple QuickTime
                            Original source medium           : Card A
                            com.panasonic.professionalplugin : 2009-05-05 07:17:50 -0400
                            org.smpte.mxf.identification.fil : 2009-05-05 11:17:50 +0000
                            com.panasonic.professionalplugin : 2009-05-05 07:18:11 -0400
                            com.panasonic.professionalplugin : Panasonic
                            org.smpte.mxf.package.material.p : 2009-05-05 11:17:50 +0000
                            com.panasonic.professionalplugin : B8TCA0255
                            org.smpte.mxf.identification.app : P2
                            com.panasonic.professionalplugin : AG-HVX200P
                            org.smpte.mxf.identification.app : Panasonic
                            org.smpte.mxf.package.material.c : 2009-05-05 11:17:50 +0000
                            org.smpte.mxf.identification.app : 0x060E2B34040101090E0E010101000001
                            com.panasonic.professionalplugin : 060A2B340101010501010D4313000000ECEA5B74564905F70080458228D2D24D
                            org.smpte.mxf.package.material.p : 0x060A2B340101010501010D4313000000ECEA5B74564905F70080458228D2D24D
                            org.smpte.mxf.package.material.p : 0021JO
                            com.apple.proapps.reel           : Card A
                            org.smpte.mxf.identification.app : 2.0
                            com.apple.proapps.originalFormat : DVCPRO HD 720p60
                            org.smpte.mxf.identification.gen : 0x9007CAD96EFF4741A0AF8763540BD0E6
                            com.apple.proapps.clipID         : 060A2B340101010501010D4313000000ECEA5B74564905F70080458228D2D24D
                            com.panasonic.professionalplugin : SHOOTING
                            Media/UUID                       : 75369709-6DCB-4DC0-A504-1B84D8A45AC8
                            Video
                            Format                           : DV
                            Codec ID                         : dvhp
                            Bit rate mode                    : Variable
                            Bit rate                         : 46.0 Mbps
                            Maximum bit rate                 : 97.7 Mbps
                            Width                            : 936 pixels
                            Original width                   : 960 pixels
                            Height                           : 702 pixels
                            Original height                  : 720 pixels
                            Display aspect ratio             : 16:9
                            Frame rate mode                  : Constant
                            Frame rate                       : 23.976 fps
                            Original frame rate              : 29.970 fps
                            Standard                         : NTSC
                            Color space                      : YUV
                            Chroma subsampling               : 4:2:2
                            Bit depth                        : 10 bits
                            Scan type                        : Progressive
                            Compression mode                 : Lossy
                            Bits/(Pixel*Frame)               : 2.922
                            Stream size                      : 116 MiB (94%)
                            Language                         : English
                            Audio #1
                            Format                           : PCM
                            Format settings, Endianness      : Little
                            Format settings, Sign            : Signed
                            Codec ID                         : sowt
                            Bit rate mode                    : Constant
                            Bit rate                         : 768 Kbps
                            Channel(s)                       : 1 channel
                            Channel positions                : Front: C
                            Sampling rate                    : 48.0 KHz
                            Bit depth                        : 16 bits
                            Stream size                      : 1.94 MiB (2%)
                            Language                         : English
                            Audio #2
                            Format                           : PCM
                            Codec ID                         : sowt
                            Bit rate                         : 768 Kbps
                            Bit depth                        : 16 bits
                            Language                         : English
                            Audio #3
                            Format                           : PCM
                            Codec ID                         : sowt
                            Bit rate                         : 768 Kbps
                            Bit depth                        : 16 bits
                            Language                         : English
                            Audio #4
                            Format                           : PCM
                            Codec ID                         : sowt
                            Bit rate                         : 768 Kbps
                            Bit depth                        : 16 bits
                            Language                         : English
                            Audio #5
                            Format                           : PCM
                            Muxing mode                      : DV
                            Muxing mode, more info           : Muxed in Video #1
                            Bit rate                         : 768 Kbps
                            Bit depth                        : 16 bits
                            Stream size                      : 0.00 Byte (0%)
                            Audio #6
                            Format                           : PCM
                            Muxing mode                      : DV
                            Bit rate                         : 768 Kbps
                            Bit depth                        : 16 bits
                            Audio #7
                            Format                           : PCM
                            Muxing mode                      : DV
                            Bit rate                         : 768 Kbps
                            Bit depth                        : 16 bits
                            Audio #8
                            Format                           : PCM
                            Muxing mode                      : DV
                            Bit rate                         : 768 Kbps
                            Bit depth                        : 16 bits
                            Menu
                            Language                         : English
                            • 11. Re: FCP XML to Premiere Different Frame Rate
                              dwhillans Level 1
                              Sorry. I probably didn't need to include all the audio info.
                              • 12. Re: FCP XML to Premiere Different Frame Rate
                                Thanks David; that looks pretty consistent with what I'm seeing in my test clips.
                                If you select one of these in your bin, and go to Clip > Modify > Interpret Footage, what is Premiere Pro reporting the frame rate as? Is the Remove 24p DV Pulldown box checked? (It's probably not, but just want to confirm.)
                                If your sequence in FCP was 24p, I'm guessing that there is something breaking down in the translation, or its just an unfortunate side effect of the nature of DVCPROHD 720p--which really only has 60p and 50p variants. The 24pN, 25pN, and 30pN variants are all sort of afterthoughts once solid state media became viable.
                                Wondering if it's possible to hack the FCP XML... hmm...
                                • 13. Re: FCP XML to Premiere Different Frame Rate
                                  dwhillans Level 1
                                  Hi Colin,
                                  You are right. The "Remove 24p DV Pulldown" is NOT checked.
                                  I will probably just have to continue editing at 59.94 or go back to FCP7.
                                  Thanks for your help.
                                  • 14. Re: FCP XML to Premiere Different Frame Rate
                                    But the clips showed up as 23.976, right?
                                    If you stick it out on PPro, be sure to file a bug report on this one: Adobe Feature Request/Bug Report Form
                                    • 15. Re: FCP XML to Premiere Different Frame Rate
                                      dwhillans Level 1
                                      Hi Colin,
                                      Yes, the clips showed up as 23.976 fps.
                                      As it turns out, I have had more problems now. I started working with the sequence as is now that is in Premiere (I didn't try to change the fps at all) and I was only able to get about 15 minutes into editing before Premiere crashes. And now I can't even continue.
                                      I will report this bug to Premiere.
                                      Thank you for your help.
                                      • 16. Re: FCP XML to Premiere Different Frame Rate
                                        The FCP -> PPro conversion can be a little flaky. Sometimes, certain elements like FCP's Slug don't translate properly. Other times, there appear to be weird phantom edit points that don't show up visually in the sequence, but they're regarded as such by the software, and that can bomb out. The few times I've had to do FCP XML transfers, I've ended up piecemeal copying parts of the transferred sequence into a fresh sequence, and had no problems. Depending on the length and complexity of your edit, that might not be feasible.
                                        If you can reproduce where the crash/failure occurs, that can help you isolate the borked part of the sequence; sometimes you can find little bits and pieces of stuff there that, once cleared out, will let the sequence worked. Sometimes, you can turn off the video (punch out the eyeballs in the sequence track headers) and you'll be able to get to the problem point without the program crashing.
                                        Sorry it's not going more smoothly!
