If you resize the images that are in the RH source folder(s),
then it will pick them up and that is your problem. It will pick
them and then show them at the old dimensions thus distorting them
horribly.
If the images are a standard size or a limited number of
sizes, then using a multi line find and replace tool such as FAR or
ReplaceEm can help you. Look at the code and you will see what
needs to change.
If you have some images that are X by Y that need to change
and some that are X by Y and do not need to change, you have
another factor to allow for.
You sure you want to change them? :-)
Back up your project before playing around, just in case.
