1 Reply Latest reply on Jul 9, 2011 4:14 PM by Cage Sh
    Runtime not found (No such file or directory)
    Cage Sh Level 1
      I use flexmonkey sample build.xml to run my application, which I build well in windows
      But when I build it in unix, I got this error:
      what file it is looking for?
      [flexunit] Executing 'flex3_sdk/bin/adl' with arguments:
      [flexunit] '/var/jenkins/workspace/flexmonkey/deploy/calculatortest-app.xml'
      [flexunit]
      [flexunit] The ' characters around the executable and arguments are
      [flexunit] not part of the command.
      [flexunit]
      [flexunit] Runtime not found (No such file or directory)
       [flexunit]
       [flexunit] Stopping server ...
       [flexunit] End of test data reached, sending acknowledgement to player ...
       [flexunit] Closing client connection ...
       [flexunit] Closing server on port [1024] ...
        • 1. Re: Runtime not found (No such file or directory)
          Cage Sh Level 1
          adl [-runtime runtime-directory] [-pubid publisher-id] [-nodebug] application.xml
          -runtime runtime-directory Specifies the directory containing the runtime to use. If not specified, the runtime directory in the same SDK as the ADL program will be used. If you move ADL out of its SDK folder, then you must specify the runtime directory. On Windows, specify the directory containing the Adobe AIR directory. On Mac OSX, specify the directory containing Adobe AIR.framework
          I do not understand where is the "the runtime directory in the same SDK as the ADL program will be used"
          is it Flexsdk/runtimes/air/linux?
