1. Re: AME and exporting chapter points
Bill Hunt Jul 8, 2011 4:47 PM (in response to Pijetro)Are these Encore Chapter Markers?
2. Re: AME and exporting chapter points
Pijetro Jul 8, 2011 5:11 PM (in response to Bill Hunt)The chapter markers are DVD chapter markers within PPro...Not to be confused with the sequence markers.
They are recognized when brought into Encore...Sometimes.
3. Re: AME and exporting chapter points
JSS1138 Jul 9, 2011 12:59 AM (in response to Pijetro)What exactly is wrong with the problem markers? Are they missing entirely? In a different spot? Differently named?
4. Re: AME and exporting chapter points
Pijetro Jul 9, 2011 10:14 PM (in response to JSS1138)There are no problem markers.
The problem is, they don't appear at all.
No rhyme or reason.
Sent from my kid's iPod, 'cause I can't afford one.
5. Re: AME and exporting chapter points
Jeff Bellune Jul 10, 2011 6:46 AM (in response to Pijetro)What version?
In CS5, the simplest explanation is that you didn't start with the MPEG2DVD preset for export. If you start with the generic MPEG2 preset, then an .xmpses file isn't created and En won't see the chapter markers.
Beyond that, check your Media Preferences in Pr. Make sure both XMP options are checked. I didn't take the time to test the effect of having one or both unchecked, but with both of them checked the MPEG2DVD preset produced chapter markers in En on my system using CS5.
-Jeff
6. Re: AME and exporting chapter points
Pijetro Jul 10, 2011 8:10 AM (in response to Jeff Bellune)I understand everything everybody is suggesting....Very much appreciated.
But when i open up an AME, i import several PPro sequences simultaneously.
I click and drag all the Formats within the AME window simultaneously.
I click and drag all the Presets within the AME window simultaneously.
I set the encoding parameters simultaneously...
All outputs are the same.
The only break in the chain is naming the output files..
And as i said..For some reason, and i don't know why, when my encoded files get imported into Encore, then some of the timelines created don't recognize the chapter points.
Perhaps it's an Encore issue?
I've got some projects to do, but once they're complete, i believe a full uninstall is in order...
And perhaps even upgrade to 5.5....
