4 Replies Latest reply on Jul 9, 2011 4:35 AM by Ned Murphy
    Not a number??
    0slimjimmy0
      if (this.hitTest(_root.enemy))
        _root.health--;
      When this happens, instead of incrementing health by 1, it says NaN. I've had this problem for a really long time and tried to find out what's wrong, but I can't. If anyone else can help, that would be appreciated a lot. Thanks.
      P.S: I'm using CS4.
        • 1. Re: Not a number??
          What says NaN?  How is health defined in the _root?
          • 2. Re: Not a number??
            0slimjimmy0 Level 1
            Health says NaN.
            code in frame: text.Life = "Health: " + health
            the health variable is in the Life text properties.
            • 3. Re: Not a number??
              a textfield's text property is always a string (even if it looks like a number to you).  you can cast it as a number, if that's reasonable:
              _root.health=Number(sometextfield.text);
              // this will also cause an NaN error if sometextfield.text="hi", for example.
              // but if the text property looks like a number to you, flash will handle the conversion without problem.
              // and you can then treat _root.health as a number.
              but, if you use:
              _root.health=sometextfield.text
              and try something like:
              _root.health--
              you will always get an NaN error.
              • 4. Re: Not a number??
                Your explanation is not very clear.  You should use a variable for the health and a textfield for displaying it as a separate entity.  In the _root timeline declare the variable...
                var health = 100;    // or whatever value it starts at
                And if you plan to display the health value in a TextField, then create a TextField and assign it an instance name... let' say you name it "healthTxt" and it also lives in the _root timeline.  Then your code should look like...
                    _root.health--;
                    _root.healthTxt.text  = String(_root.health);
                and if all of that code happens to be on the _root timeline, get rid of all the unnecessary _root references.  You should not make a habit of throwing _root in front of everything in sight.  You should only use it if you are not on the _root timeline and have no other means of targeting it.
