1 Reply Latest reply on Jul 9, 2011 1:44 PM by kidelectric
    How to get properties of clickable photo on mouseclick?
    kidelectric
      I have a series of thumbnail images which are dynamically loaded/created in AS3 via an HTTPService call...
      I would like this photos to be clickable (or mouse over) in order to swap out the source of a main (larger) image.
      However, when I set a mouse event handler for the photo, it won't let me access the target photo's properties (such as source or id) the way I normally would, such as event.target.id
      When I attempt to do this, the event target is not the photo itself but the spark.skins.ImageSkin...
      The reason I am trying to pull the image.id is because I used it to store the index of that image which corresponds to an array of URL addresses to be able to fetch the full-size version... any ideas how I can do this? It worked with other element types (like Label), but not Image...
      private function onMousePhoto(event:MouseEvent):void {
      mainPhoto.source = currentPhotos[event.target.id]+
      "_m.jpg";
      private function flickrImageResult(re:ResultEvent):void {
      photoArray = re.result.rsp.photos.photo;
      var photoCounter:int = 0;
      for each ( var p:Object in photoArray ) {
      var photo:Image = new Image();
      currentPhotos[photoCounter] =
      "http://farm" + p.farm + ".static.flickr.com/" + p.server + "/" + p.id + "_" + p.secret;
      photo.source = currentPhotos[photoCounter]+
      "_t.jpg";
      photo.id = photoCounter.toString();
      photo.useHandCursor =
      true;
      photo.buttonMode =
      true;
      photo.addEventListener(MouseEvent.MOUSE_OVER, onMousePhoto );
      photoGroup.addElement(photo);
      photoCounter++;
