0 Replies Latest reply on Jul 10, 2011 12:50 AM by mackry88
    Calling .jsx functions from .js files using HTML Widget
    mackry88
      Hi there,
      I'm using the HTML Widget in a panel to load an html file along with some javascript files. Is there a way to call .jsx Adobe functions from a .js file? I've successfully been able to call an alert() of a .jsx file from the html but have not been able to do anything further than that.
      For example:
      .js file:
      var x = foo('bar');
      alert(x);
      .jsx file:
      function foo(x) {
          alert('This works');
          var dir = $.fileName;
          alert('This doesn't work because of $.fileName');
          return 'Directory: ' + dir;}
      So, ultimately I would like to have an HTML Widget in my panel, press a link that will call fiddle with the open document and layer, then return some values back to the HTML Widget's js file.
