1 Reply Latest reply on Jul 12, 2011 7:06 AM by Guriya Kalyani
    Setting background image on Flash Builder 4.5 application
    GSS1
      I would like to set a background image on my Flash Builder 4.5 application. Does anyone know how to do this? Haven't seen an example that does this. Flex 3 made this very easy to do, but not 4.5
        • 1. Re: Setting background image on Flash Builder 4.5 application
          Guriya Kalyani
          It is possible  to do it in Flex 4.5 and a lot more using skinning.
          Say, you have a project MyFlex, in the main.mxml of it :
          Type the below :
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             minWidth="955" minHeight="600" skinClass="<cursor_pos>">
               <fx:Declarations>
                     <!-- Place non-visual elements (e.g., services, value objects) here -->
               </fx:Declarations>
          </s:Application>
          At the cursor pos, invoke 'code-hint' and 'Create Skin'. You get a dialog to create the skin, give the name as 'abc' and finish
          In the generated abc.mxml, you can set the background image as :
          <!--- The default skin class for the Spark Application component.
                 @see spark.components.Application
                @langversion 3.0
                @playerversion Flash 10
                @playerversion AIR 1.5
                @productversion Flex 4
          <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
                  xmlns:fb="http://ns.adobe.com/flashbuilder/2009" alpha.disabled="0.5" alpha.disabledWithControlBar="0.5">
              <fx:Metadata>
              <![CDATA[
                   * A strongly typed property that references the component to which this skin is applied.
                  [HostComponent("spark.components.Application")]
              </fx:Metadata>
              <s:states>
                  <s:State name="normal" />
                  <s:State name="disabled" />
                  <s:State name="normalWithControlBar" />
                  <s:State name="disabledWithControlBar" />
              </s:states>
              <!-- fill -->
                  A rectangle with a solid color fill that forms the background of the application.
                  The color of the fill is set to the Application's backgroundColor property.
               <s:Image source="flex-icon.png" smooth="true" left="0" right="0" top="0" bottom="0" />
                  <!--- @copy spark.components.SkinnableContainer#contentGroup -->
                  <s:Group id="contentGroup" width="100%" height="100%" minWidth="0" minHeight="0" />
          </s:Skin>
          Refer the below blog for more details. Let me know if you still face issues
          http://blog.flexexamples.com/2009/03/22/setting-a-background-image-on-an-fxapplication-in- flex-gumbo/
