1 Reply Latest reply on Sep 20, 2013 8:58 AM by kjigs4it
    <a> tag is creating error in import XML in InDesign CS5.5
    kjigs4it
      Hi All,
      I am doing upgrade from InDesign CS2 to InDesign CS5.5.
      I have indt file. It has been designed using the CS2 and now converted that indt file into CS5.5 using InDesign CS5.5.
      But I am facing some serious issue while doing export to pdf in CS5.5 version.
      I am following below steps:
      1) Open indt file.
      2) File Menu --> Import XML... [This XML file contains <a href="website link"> html tag]
      3) XML Import Options [no change- defalut options selected]
      4) Ideally it should merge this XML data with the indt file but it is asking me for some input and showing me "Find:" dialog [Check below snapshot]
      I did some research and find out that I am getting this Find dialog because of the <a> tag in XML. when I removed the <a> tag from XML then it didn't give any dialog box and imported XML without any issue.
      I am getting that xml from system and I cant remove the <a> tag from xml manually.
      However I was not getting any error while doing import XML in CS2 version.
      Please can anybody help in this?
